so can someone clarify, if you use opt for 3 way sli, there will know longer be any more room for any other pci cards ? thanks in advance.
i was just about the do the mod, and i noticed these pics point to two different resistors. this pic points to the one on the left:
http://img261.imageshack.us/my.php?i...1212121il9.png
and this points to the one on the left:
http://www.xtremesystems.org/forums/...3&postcount=16
which one is it?
MCP is northbridge temp
and i did the pencil mod according to the second picture in your post
EDIT: actually come to think of it the EVGA does have the nb temps in windows, its the striker2 that doesnt
im on a different pc at the moment but i think even in windows software like everest its under MCP if i remember correctly
someone correct me if im wrong
just did the mod and it seems to be working great. just a few questions. i set 1.3 in the bios and its being reported as 1.28 idle and load. it hasnt budged from that ever even during priming and occt. is that normal, because i noticed that for others it would increase from idle voltage when under load. is that more desirable?
edit: never mind, i take back what i said above. i just set it to 1.3625 in bios at 4ghz and idle voltage was 1.344. now that m running occt its at 1.352
managed to get 4x 1066 1GB EPP modules. so 4GB running 1066 5-5-5-15 with 1.8V fully stable with a revised SPD im workin on...again tRFC was key.
Will try to post pics tomorrow, also posted over at the EVGA forum asking them to add tRFC to bios.
These boards could be some much more if they had all the tweaks for the end user to play with
Pretty sure the Striker 2 has NB temp readouts man, maybe ya everest software or co doesn't support it...
Building a rig based on this mobo right now.
What's the best bios to use with an E8400 ? I have to redo the heatpipe, temps over 75°C on idle ( lol ) just installed windows added an extra fan that kept temps around 65°C level... but I've seen better here...
your probably right, ive been testing 5 different mb's in the last 2 weeks so i cant keep them straight.. lol
i probably shouldnt have even posted anything but i was trying to help the guy out.. all 5 mb's ive tested are completely different so i couldnt remember but it sure seems like i couldnt find nb temps in windows with the striker II but i dont have it anymore so your probably right (although as you said maybe its just the version of everst im using)..
as for bios i only used the 9650 with that mb so i had to use the new beta bios.. 1001 i believe.. but from what ive read since your using the e8400 dual core you should have alot more luck than i did with quadcore.. atleast for me the strikerII and yorkie quadcore wasnt all that much fun
if anyone's interested, i took the 3x Raptors out of RAID 0 and disconnected power and just left one running and bingo, OCCT stable at 475*8! next step is see if the 3 drives plugged in cause the problem (not enough power) or if putting them in raid causes the problem (mobo is too weak).
Feedback welcome.
Interesting.......
What size is your power supply? More important, how much power can the rails deliver (Amperage)??
how old is your power supply???
this will tell you the mcp temps. Its not free but it kiks a$$
http://www.lavalys.com/forum/index.php?showtopic=2872
I have an Enermax Noisetaker EG710AX-VE(W) (24P). It's 600W and 35A total.
It's about 3 years old.
I was thinking to replace it with this, but not sure I'm getting the best bang for my buck.
http://www.newegg.com/Product/Produc...82E16817703009
if anyone is interested....
EK JUST posted the new 780i NB waterblock on their site.
Clear...
http://ekwaterblocks.com/shop/produc...roducts_id=239
Acetal...
http://ekwaterblocks.com/shop/produc...roducts_id=241
Firstly, Thanks to GAR for his excellent guide.
OK I am wanting to know how to ensure MEDIASHEILD drivers are uninstalled.
ie. I was getting a random nvgts.sys error and yes I have a SATA DVD-RW, even at stock settings.
What I have done in an attempt to uninstall mediasheild is run the setup from original disk (XFX 780i v9.46) and de-selected mediasheild. Installer then said it would uninstall current drivers then install chipset drivers upon reboot.
Upon reboot it did not automatically install the chipset drivers but I was getting 'new hardware found' indicating the chipset drivers were successfully unistalled.
I then proceded to install the chipset drivers from disk minus mediasheild drivers.
Does this method ensure mediashield drivers are NOT present on my system ?
my 780i evga just died yesterday, i had my q6600 g0 at 3.7 1.5v, it was 100% stable for a week or so..then yesterday it just rebooted...and it would reboot nonstop while turning back on..it would go into bios sometimes..which i did..set everything at stock..etc..but that didnt work..it would keep rebooting nonstop, i was able to log into windows one last time..and to my desmise..windows was showing my quad core as a dual core..lol , then the mobo restarted agian..nonstop once again..so i was like :banana::banana::banana::banana: this..i got a rma ticket with newegg..im gonna send it tomorrow..and have them send me a new one.. i really dunno what happened it was so stable and working perfectly..
