Priming for 3 hours is not good enough, i've had Prime fail after 6 hours. You need a minimum of 12 hours for dual prime Orthos + use Memtest86+ and The Windows versions, Super PI and other stress testing programs.Quote:
Originally Posted by cold_realms
The issue i mentioned about the NB and SB being hot were from the perspective of just building the PC and not used to the new hardware, it's normal for the NB and SB to be hot, in fact the new F4d bios appears to have dropped the temps...to the finger touch test that is.
My board appears functional in all respects, it works...when you have everything set to default. Overclocking...no go.
Again i have tried to set the FSB to 400x6 = 2.4GHz, it will not boot. You say you have the MCH and FSB voltages to deault, well i tried that + 0.2V up on both and it will not boot.
So i am going to RMA my G.SKILL ZX memory, sending it back Monday and G.SKILL say they will send me a HZ kit instead. So we'll see if things get any better.
Personally i think it's the memory, either that or my CPU are absolute crap at overclocking.
