if your pc was overclocked when installing windows,i would suggest you run everything at stock,other than maybe a little extra vcore and vdimm!!
yeah something was definitely wrong, because it would hang at "please wait" if I tried going straight to Bios17, the floppy drive would be on standby. So I tried going to 16 official release which worked then from their to 17. I don't know what happened but it worked so that's all that matters to me.
just noticed C1E&EIST are broken in BIOS 17
*fixed*
strange did a reflash and hard cmos reset via battery removal and C1E works fine again:up:
Its a WinXP Pro with service pack 3 splipstreamed Ace.
Settings seems to work now after the install but I have idle temps of 50-52 celcius. I am using an Ultra 120 with a push-pull config
ChuckM...check yer PM's!
yeah me too - performance 7 right now but was 6 on earlier configuration.
to tell the truth in the past 4 weeks (12 hours/day) i have done literally 100's of configs and kept them all on paper, often scribbles going in all directions and on both sides of the paper!
will go through the large stack of paper 'notes' in small towers around desk and post config settings that gave performance=6.
Im sure many overclockers out there know exactly what im talking about.
aztec : im using realtemp 2.68 as its the most accurate for quads and now shows up the swapped core bug in intel quads. (dont even ask me to load Uguru software although i have the Uguru clock installed) BTW I also tried CPUID but was a little concerned when it said my cpu was @ 295c/400+f
Update : IT lost the hard disk again at 400X7 with little voltage increases to everything compared to stock BIOS settings
This time the Windows installation went corrupt ... I'm suspecting it might be the Raptor-X's fault and not the mobo's
It did this when i was unraring a big file, rebooted and then it could not detect the hard disk anymore. This time with BIOS 14 so I dont really know the source of all this problems :(
My P35Pro died yesterday - first a Windows freeze, and when I powered down the board wouldn't power back up.
Pulled everything off the board, but the red LED that indicates power is on is flashing on and off and there's no LCD readout. Tried another PS but same flashing LED.
I suspect that the power regulator is gone, and the flashing LED is just the PS overcurrent protection going on and off.
Anyone seen anything like this - before the RMA goes in?
Since I upgraded to Vista 64bit Ultimate I have been having a nightmare of a time with random shut downs and crashes. Windows has been reporting them as NVIDIA driver issues.
I have tried driver cleaner pro and many 64bit drivers and just this week a fresh format new windows install and fresh drivers and its still crashing...
So I started to assume it was hardware based problem. So on a whim I installed XP 64bit and amazingly I am 100% rock solid stable.
This has all been done at stock for testing and I have BIOS 14 in right now.
I am wondering if this is possibly a MOBO related problem or not.
Also EVGA tech said that sometimes VISTA reports RAM problems as video card error so I have run memtest and at stock the g.skill is error free but with the slightest overclock the RAM fails test 6.
I updated to bios 14. CPU-Z however says bios10 for some reason. On the other hand uguru shows my cpu idle temps 10c lower (from 36c idle to 26c idle). I'm not sure what to make of that: here's what the inside looks like.
For those who asked about performce level 6.....
You guys haven't always run PL 6? Then again, these are my Dominator C3FD....My Team run PL5. I'll have to look into this unlocking the MCHBAR thing.
http://img352.imageshack.us/img352/1037/p6ys6.png
http://img352.imageshack.us/img352/1...1dd681b2d1.jpg
The Team Xtreem
http://img144.imageshack.us/img144/9254/p5mg1.th.png
Wonder if I could unlock it to PL4?
http://www.xtremesystems.org/forums/...postcount=6582
______________________________
ABIT IP35 Pro Motherboard
M629B17.ZZZ Rebels Haven Mod BIOS
E8400 8X500 1.40V
Danger Den Water Cooled
2x1Gig Super Talent PC6400 5-5-5-15
EVGA 7800GS
WD SATA 120GB
Antech 550W
