wow,thats alot of options with the 775 side of things:shocked:
i wish i had 20 chips to play with:D
Been a way from my 775 rig a little too long. The PSU went and I sold my RAM aswell for needed cash at the time.
Got 2300mhz cas 8 ram on the way and a corsair 850HX, will all be here early next week, that and 4c mornings here, I can't wait to get back to pushing the X3360.
Also some nice results going on here. Giving me alot to read through :p
Well now it's time to figure out which ram to use and tune the system for some pie....
first up was a stick of some nice Mushkin Redline... xp2-8000 4-5-4-11
so i ran it on auto just to see what it did....
here is the results of aobut 20min of playing...
good for 3rd place...(out of 5 :ROTF:)
http://img.techpowerup.org/100612/3380-pi-9251.jpg
pff my Q9550 just gets to hot vid of 1.1375 and now im at 1.28 v and it gets to 70 when small ffting... its such a hot chip i have a prolimatech megahalems now with my Z600 it already hitted 70 at 1.24 so its such a sick hot chip
its fun to play :up:
here's my first 5Ghz+ on the USB3P on W7x64 it was easy with this chip just on normal ambient temp and my water cooler its a pity i lost my XP32 install it would have been nice to try there
ambient on my room is 22C winter here
http://img15.imageshack.us/img15/20/p10406811.jpg
http://img194.imageshack.us/img194/6627/50061.jpg
Cheers :toast:
Sergio
i will give it my best, i am jsut trying to figure which ram to use....
seems like i can run @ around 540 fsb bench stable, so now i jsut got to find the
right multi and ram timings...
i wonder what would be faster @ 5.1ghz....
for the pie..
530 +/- with CL 4's
or
630 +/- at CL 6's
I see that the top spot is @
8sec 850ms
544mhz 1:1
4-4-4-10
so i might push that track for the next run.... :up:
PS -> love that cooler master, that is a very sweet rig!
I love me some awesome ram.
It will be good to be back benching the 775 rig again. Going to get some bags of ice and a coolbox for some below ambient cooling.
Could do 1.55v on plain water and still be in safe temps, I would hope the ice would be able to see me to 1.65v, will be nice to see where I get anyway. I'm not afraid of pushing everything the max.
I'm almost certain I've already told you but it needs another mention, your rig looks amazing. I love it.
I am running F8a, i was gonna update, but it was running so nice, any comments on the newer bios, anything that can help..
I do have a copy of XP sp3 that i was thinking of building a load on a spare
raptor i have laying around, i also was thinking of trying one of those
loads that benchzoner posted about a month ago...They were supposed to be slimed down for overclocking .. i grabbed most of what he posted...
I currently run Vista 64 Ult..
So do you think going to XP sp3 or serv 03 is the way to go for 2D, that is my only goal for these chips, is to run the 2D benchies...
I just recieved some sweet ram to try from a friend
What i have already
readline xp2- 8000 4-5-4-11
Dominator 10000 - 1250 5-5-5-18 (use this the most)
Patriot PC2-9200EL 5-5-5-15
some other stuff...
but i jsut got some....
Corsair 6400C3D rev 1.1 DDR800 cas 3-4-3-9
Teem Xtreme TXCC1024M1300HC6 DDR1300 cas6-6-6-18
Teem Xtreme TXDD1024M667C3-M DDR667 cas3-3-3-8
So many choices..... :shrug::shocked::shrug:
thanks in advance for any help..... :up:
The bios I use is F4-4, it can be a little touchy with bad OCs but it helps with SPI. Definitely use xp or 03serv for spi, ive used both and they pretty much run the same times so its not really going to matter which one you use. XP/03serv is usually worth a tenth or two in spi 1m and several seconds in 32m, although for wprime use vista 32, here it can be worth a few tenths over xp. For ram id use one of the teem xtrs., which ever clocks the highest cas4 or cas5.
Been working on my 4750 stable setup, love to see the gskills do 1600 CL6 at PL7 even at this CPU speed, so far been runing games and Some SPI32 and HYPERPI32 all day and its stable, also nice 3DM06, i finally found the combo this chip loves :)
http://img163.imageshack.us/img163/5...cr2pl7spi3.jpg
http://img19.imageshack.us/img19/608...cr2pl73dm0.jpg
Sergio :up:
