very nice andres, that is a solid oc on the cpu and the memory oc is awesome, it is nice to see such high speed and 1T:up:
thanks mate :up:
i was not passing memtest failed at 44% so i upped MCH to DRAM ref to .80 then passed.. went to game and BC2 made it reboot so i nothed vcore to 1.392 load and shoot blend and now im playing no issues will keep testing seems that this is hard for this mobo at this CPU speed but can do it
maybe with hypers is better dunno for now im pretty happy volts are kinda high but normal on giga, i had the same with the PIS 1200
Cheers :toast:
Sergio
andressergio,those are some great results there:thumb:
Well i did it guys :up::up::up:
this is my first full stable 4500 / 2000 1T setup :D
http://img227.imageshack.us/img227/6...cr1pl8linx.png
Cheers :toast:
Sergio
muy bueno Sergio, now i got the itch to get a xeon like you. This board sure got the potential.
Nice work Andre', and nice gflops too - still waiting on my USB3P to turn up...NNNGGGGHHH!!
Fantastic work Serg! Very inspiring.
After all those test passed gaming on BC2 or DIRT2 i get BSOD...so or its too much for P45 or need some more tweaking or maybe a better bios to support this fast mem
So i settled at 1600 6-9-6-24 for now
Cheers !
Sergio
That's still pretty good going, I always suspect things like PCI-E related bios options like PCI-E frequency and SB volts if I get BSOD in games, then again 6-6-6 at those speeds is a lot to expect for a p45 to handle, but it is a marvellous northbridge which continues to impress!
The bios are also still quite early maybe we can hope they make some improvements. I wonder how bandwidth on this board compares to other EP45T boards running at the same speeds - might be worth comparing and even swapping bios memory tables for better performance / higher clocks...
Still no parcel yet :(
damn sorry to hear mate
well for 1600 6-8-6-18 and tight timmings that is what i am i need 1,52 MCH for a solid OC, pases linx, game whatever
i also passed linx at 2000 1T on 1,52MCH but games will crash so...i will settle on this
i also saw other ppl on the EP45T UD3P that need 1.5+ and also on the EP45T USB3P
http://img443.imageshack.us/img443/1...cr2tweaked.jpg
Cheers mate best of lucks to get the mobo
Sergio
Guys
Each day im loving this mobo more and more, never thought that PL7 would be so easy...i decided to try today and look :D
http://img202.imageshack.us/img202/6...cr2spi32pl.png
http://img708.imageshack.us/img708/4...cr2everest.png
Just runing it on my 24/7 very happy !
Im starting to think they toned that board down some vs the older T boards. :confused:
1600 C6 PL8 daily timings
http://i131.photobucket.com/albums/p...s281/tight.png
1600 C6 PL7 same timings
http://i131.photobucket.com/albums/p...1/1600c6p7.png
Meaning like the way there setting up the bios for these newer boards, for one reason or other, having reduced bandwidth vs the older boards. The same as what they did with the bios for the ud3p, after f10b the reads were reduced and with higher latency.
its true about f10b but really i dont think its that your mem can do better than my PIS yours are hypers and mine not, gskill is kinda tough on bining, and costed me 100 $ less
this is also a nice setting i have but i cant do 6-6-4-18 PL7
http://img266.imageshack.us/img266/5268/captura2i.png
http://img62.imageshack.us/img62/956...cr1pl7cust.jpg
Cheers :up:
Sergio
The difference between my timings and yours should be pretty minimal, guessing less than 100mb, so I really dont think its the memory itself causing the difference. Heres an older one done at looser timings and really not much difference. :shrug: The trfc on the first run I posted was at 52.
http://i131.photobucket.com/albums/p...ss281/band.jpg
These are the sub timings on the first runs posted.
http://i131.photobucket.com/albums/p...ss281/subs.png
yes Hoss can be what you say remember this mobo is on second beta bios F2D i asked stasio to keep updating
i dont agree as 6-6-6-18 and that timmings will give me kinda same speeds, but my mem cant do it
Either way very happy never tought that PL7 can be done :up:
Thanks for your input Hoss
Hello guys; I used to hang around in this thread, but I've been away for a while.
Question is: I'm using F9a bios version. My computer is still running great, but I wanna know if im missing anything running this old bios. Ie... Did they ever get sleep to work correctly? I'm running 24/7 @4.0Ghz. Any super good bios upgrades? Something that I cant live without?
Thanks guys
