Yeah I mainly just liked to have it there to show what command rate I was running. Thats about it since cpuz wont show it for my board.
I guess it doesnt matter that much really anyways, other then that the final version works great, thanks a bunch,
When i run this program , it told me that my chipset is not supported. my chipset is intel G965 and is it be supported by this program ?
Could you send a register dump (with cpu-z->last table->register.txt) at:
memset@hotmail.fr
Hi FELIX
Any fix for custom set DPI size in Vista, please fix it.
Can be beta, I'm willing to test.
THANKS FELIX !! you da MAN !! fuggen great tool ! one of the few things ever to work on my rig.... damn the 945 chipset & the cv115-2pv pll !! hahhahahaahaa
FELIX seems memtest 3.3 final is messed up on Asus Blitz Extreme once i flashed to 0804 bios
http://fileshosts.com/intel/Asus/Bli...me_151_all.png
Something I have noticed... after the computer resumes from Sleep, it will default back to the stock memory timings. You can verify this by pulling up MemSet, CPU-Z, etc. I was wondering if anyone else had seen this issue? I have tried 3.2, 3.3 Beta 1, 3.3 Beta 2, and 3.3 Final and they all do it?
Is this a known issue with MemSet?
-Thanks
Just want to say thanks bunch for your hard work and an excellent utility.
This app is suddenly HARD to get... any ideas what's up?
Would like to donate to you for all your hard work on this.
I know it has helped me Immensely.
So post or pm paypal info or somthing.
If your not acception donations ..a TY! Will have to do.
http://img.photobucket.com/albums/v101/godsa/Up.jpg
FELIX, I would like to ask about MCHbaredit. Seems like it checks the VendorID\DevID at startup. And it doesn't work on chipsets that are compatible with the supported one (i9XX) but it doesn't load - cause the VID\DevID doesn't match. Is there a key to bypass this check?
Would be very glad ;)
What is the VID/DevID on your system?
are these bugs?
i dont know if it's only on the bios settings
http://img217.imageshack.us/img217/7681/buguv9.gif
Q6600
Thermalright Ultra 120 Extreme
DFI Infinity 965S
Crucial Anniversary 2x1gb DDR2 667
Silverstone DA650
tnx
because your multiplier dropped lower than nominal. nothing to worry about.
FELIX VendorID of course 8086 - Intel. DevID I'll figure out. But it's from the i9xx family.
FELIX, The DeviceID is 2A00. ;)
It's Intel's 9xx family, but the program doesn't like its DevID. Would be glad to have this fixed :)
does it have any effect on the performance of the board?
we have same problem. i'm now using ABit IP35Pro.
already tried 3 different sets of ram but no luck :(
is there any fix for this issue? already tried different multi, even bios default
but still cant read the mems correctly :(
tnx
...you can't read memory timings or memory speed?
Hi guys, looks like a great program, I was wondering, now what do I do with it?
http://img222.imageshack.us/img222/853/memsetlu8.th.png
anything on there I should change? thats how it was when I launched the program.
Thanks for any advice.
hey FELIX any chance of memset working with X38 chipset?
+1 for X38.... :D
...already do, coming soon.
Curious to see whats timings Intel will give in the Extreme Tuning Utility software... :)
If someone can send a register dump of X38 at memset@hotmail.fr, thank.
What do I need to do?
Low speed, high bandwidth.
Lol, at Fugger and his wimpy Yorkfield system....
:shocked:
Ply
