That's a hella-long list. :D
Thanks.
Thanks.
Just a little quarrel with this line;
HyperX PC 3200AK2 (2-3-2-6-1T) (KHX 3200AK2) --chip--> Winbond CH-5
My own set contains Infineon CE-6 - i'll provide a picture if i can find my digi camera. :?
My set od KHX PC3200A contains CE5 when I took off the heatspreaders ;) But they suck to OC :(
Yes please! I've got also that mem, but one thing is for sure, no winbond chips!Quote:
Originally Posted by Fayt_Leingod
My ram:
http://www.xtremesystems.org/forums/...id=36252&stc=1
Just to let you know i havent disappeared - my mum has the digi camera. ill see if i can get em done by a weeks time.
Ok, thnx :)
I have a 1GB stick of Corsair Value Select VS1GB400C3 (see the pic below), it can do 240@3-3-3-8 at 2.8V (at 2.6V it can do 234MHz). It definitely don't like CAS 2.5 because I was able to manage only to 205@2.5-3-3-8. Looser timing (xx-4-4-8) does not impove OC result. Changing subtiming with A64tweaker does not help too.
I am wondering, what chips I have on the stick ? I guess it can be Powerchip or Nanya?
After reading some review I have a conclusion that the chips on my Corsair VS1GB400C3 are actually MICRON 5B-D though they don't look like other 5B-D but the small 4 character like HKDZ on the chips and characters of oveclocking point to this conclusion.
Not even Corsair tracks the ICs on VS sticks, so GL with the IC identifying :)Quote:
Originally Posted by Binh
i am highly confused by all these rams, yet no one ever links to where you can buy the products. can someone please link me to a good set of either 2x512 or 2x1gb sticks that will do 300mhz+- for a dual core opteron/ DFI LANPARTY nF4 SLI-DR.
DDR600's not a highly wanted thing, and is costly to make, ergo hard to sell, hard to find.Quote:
Originally Posted by viper650
OCZ makes some 300 Mhz memory IIRC.
yeah, i meant that i would like them to do 300mhz OC'ed... ddr500 is fine, as long as i can hit 600 speeds.Quote:
Originally Posted by Wired-HoH
please also add my 100%Quote:
Originally Posted by Punisher!
Guys i've found 2*512 Alienware 2-2-2-5 memory sticks with headspreader.Does anyone know what chip they have?I don't know their speed..
Hi guy's!
I have 2 sticks of Samsung RAM PC3200 (2x512). Info on chips is:
SAMSUNG 543
K4H510838C-UCCC
It's some kind of value RAM, but does anyone know what is capable on???
And is Samsung UCCC chips is any good? What can i expect from this RAM?
Cheers
P.S. My 1st post on XS :D
Samsung UCCC chips are one of the best, and most common chips on 2gb kits (1gb sticks).
Funny thing is that I didn't know that they came in the 512mb flavors...
Well it took long enough, but i finally have pictures.
First and foremost i MUST appologise - I forgot about my mother's terrible digital camera.
Secondly - i just plain suck at photography.
Here's the barely visible infineon CE-6;
http://i17.photobucket.com/albums/b7...1/100_0206.jpg
(I'll definitely be doing a re-shoot when i get time inbetween studies, work, and fixing this damn computer :P)
Do they look the same from the side as mine?
http://www.xtremesystems.org/forums/...&postcount=629
Thnx
TWINX2048 XMS-PC3200C2PT Rev1.2 (2-3-3-6) : Nanya 5 Rev.B; they do 2-3-2-5-1T at 200 MHz with 2.6v; no CO results as I bough them to run them at 400MHz
Yeah they look alike - exactly alike, i can't tell. I just knelt down and had a look - poor lighting + rat's nest wiring job = makes it hard to tell. :PQuote:
Originally Posted by Comp-Freak
Not concrete at all. Lot #s are also needed to state what ICs they contain.Quote:
Originally Posted by scorp
Anxious to see the 1GB stick results!
what timings recomend for Corsair Value Select 2x512Mb 400Mhz, Chip VS32MB-5 PS1300505 Latency 2.5-3-3-8 Stock, i dont find the timings stable at 225Mhz ! The chips is VS32MB-5 PS1300505.
Mushkin PC3200 Level II, does it BH5 or BH6 ?
http://img.photobucket.com/albums/v2...t/DSCN3197.jpg
http://img.photobucket.com/albums/v2...t/DSCN3201.jpg
This is the 256/512MB-list, I guess you have a stick of 1GB, which does contain infineon chips.Quote:
