Speaking of codes, I've copied from OC Forums some info pulled from Kingston Value Ram. The first set of numbers are off a 512MB stick which was purchased from Fry's and tested on the same P4 rig as the OCZ. Hit the same 255 at 2-2-2-6 with 3.6v and the second set of numbers was from a retail box at CC of 2x256 which I spotted but left at the store because of the high asking price. I was just interested in seeing if there were any locally and what info was on them so I could pass it along. The first KVR stick is pictured at OCF and has the name coding pattern as I've described below. Here is a link to that thread, see post #73 if you are interested in the picture of the KVR. It is not a great picture, but you can see the peculiar layout of the chip's coding.
http://www.ocforums.com/showthread.p...97#post3349097
The 512 stick:
Originally Posted by Diablo23RD
Sorry, I am bad in taking pics
Kingston B11444.02
D3208DW3T-5U 0449PT01
Copy of my post at OCF (2x256 set):
I found a set of 2x256 at a local Circuit City which match the pictures taken by Diablo except for some minor differences. I did not get them, again, because they were priced at $150 after sales tax for 2x256.
Note one item of interest. Usually the Kingston label is across the top and then the numbers below. These chips have the first set of numbers to the right of the Kingston label, so both the name "Kingston" and the first set of numbers are on the top. In many cases, the date is on the second line, and then the chip coding is on the third line. These chips have the coding on the left side of the 2nd row, which is actually across the bottom, then what appears to be the date, plus more coding to the right. All of the second group of numbers are across the bottom row of the chip.
The set I found was coded like this.
First row - label and numbers: KINGSTON 401137.05
then blank space with the circular Winbond "dimples" visible,
followed by the chip code & date: D3208DL5T-5 0416PT01
