mascaras: auto-tune does not work correctly, at least it didn't for me. It put my core about 50Mhz beyond my tested stability which instantly caused my system to lock up and reboot.
As long as you disable driver check via f8 during post you can overclock a single card with Rivatuner. If you are using Overdrive from the CCC you need not do that and you are limited to manually setting 730 on the core with the HD 3850. You can get both cards to OC though. The bench I posted earlier was 730|1000 for both cards done from the CCC.
I can't get my second card to OC correctly with Rivatuner. I set the clocks then when I apply it drops back to stock.
I am hoping W1zzard @ techPowerUp! releases a version of ATi Tool that allows me to get my second card well. I'd love to have access to boost the voltage too.
I thought people were saying you could get crossfire to run with either AI set to standard or disabled. Running a singe card I get a higher score with AI disabled. Looks like that may not be the case for crossfire, but thanks for giving it a try, I'll be getting my second card soon, so was curious.
To Crossfire work properly = catalyst AI standard
if you disable catalyst A.I = i think only 1 card score
yep , single card with catalyst A.I disable always give + score
why dont you OC with CCC your second card????
with a OC bios you can go to 1500mhz core and 1400Mhz memory
CCC using Bios 830Mhz/1200Mhz
http://aycu40.webshots.com/image/378...2384645_rs.jpg
regards
I really enjoy this community. :)
:toast:
http://img165.imageshack.us/img165/5...50ocweedt3.jpg
Got a new toy a 2 days ago...
http://img443.imageshack.us/img443/8...mark063dd6.jpg
No mods no nothing... right out of the box :D
Stock cooling too? Whats the temp @ load? Anyway, nice clock.
Arrived in my home last weeks but I try Yesterday....HIS HD3870 out of box no mood original bios in this card and litle tweak on my card....have some fun :) :)
http://img81.imageshack.us/img81/8021/oktq1.jpg
WOW KWSW!! what make is that and where did u buy it from!!! i want one!!
:up: Those are nice clocks KWSW! I've got my reference Gecube 3870 running at 957Mhz Core (actual) and 1233MHz RAM (actual) with the standard unfixed BIOS. Is there any chance you could extract the BIOS from your Turbo III OC'ed version and make it available to us? I would like to try it on my reference Gecube card :D Have you tried loading the OC'ed cards BIOS onto your reference Gecube 3870?
My 1st post here, hello world :>
I got an X-Turbo III too, this is its bios: http://www.fileshack.us/get_file.php...70XT10.073.bin
It seems I can't get over 891MHz stable with my card (on Vista 64, Maximus Formula 0907, C2D E6750@3.6GHz@1.5v, Black Dragon 2x2 @ 900 @ 5-5-5-18 @ 2.0v). I then tried removing its cool HSF to replace the thermal slime with AS5. No luck with this, still stuck at 891.
The bios version is 010.073 and CCC lets me go to 885/1200 maximum (I tried the oc beyond this limit using rivatuner).
Any suggestion? :>
sry for OT but i got the the same problem with Asus HD2400pro 256mb, maybe some1 can mod the bios to get over 860 core?
thx
Thanks for the file Ratatosk :up: Now I just need to work up the courage to flash it with the newer BIOS as I've never done that to a video card before :eek: It's weird that CCC only lets you go to 885/1200 because mine shows 885/1387 even though the BIOS is limited to 862Mhz core. Maybe the BIOS determines what speeds are available in the CCC??
As for you being unable to go over 891Mhz core speed, try manually raising the fan speed in Rivatuner to keep the temps down. If that doesn't help then the GPU needs more voltage so the only option is a voltmod.
The "760" BIOS from here-
http://www.iax-tech.com/video/3800biosmod/03.htm
Cards in my sig will do just over 17k in 06 support by a Q6600 @ 3.53GHz on Vista x64. XP would be plus 500-750pnts.
http://service.futuremark.com/compare?3dm06=4459470
do any of these BIOSes have a more aggressive fanspeed profile? i'm using stock cooling on my 3870's and want a new BIOS that forces 60% fanspeed, either when i start 3D clocks or at a certain temperature threshold. RivaTuner isn't so hot with CrossFire - i have to manually force fanspeed up and down before and after running 3D apps. i'd like fanspeed to be more aggressive when in 3D mode without having to run a third party app.
I just replaced my 8800GTS with a HD3870 and wanted to c how good it overclocks.
I installed rivatuner 2.06 but when I click on customize to overclock I don't have anything except for low level refresh settings, desktop schemes and diagnostic , I have the lastest CAT 7.12 installed.
Is anyone having similar problems? (I tried reinstalling both the driver and RT)
i need a more accurate OC tool hehe
thanks a million in advance :)
well ,here is my new baby in action (with no vmods or pencil) and only CCC...
room temp is 18c
Sapphire HD3870 + Thermalright HR-03 GT
http://img161.imageshack.us/img161/4...870fotojp3.jpg
HD3870(850/1200MHz) + ATI reference HSF at low speed
http://img171.imageshack.us/img171/3...testingwh4.jpg
HD3870(918/1250MHz) + Thermalright HR-03 GT + Scythe Kamakaze KKF92-01 73.6CFM(3800rpm)
http://img161.imageshack.us/img161/5...l925mhzib5.jpg
at 931/1300MHz
http://img161.imageshack.us/img161/7...6935mhzwi6.jpg
great temp with the HR-03. that's awesome. i still can't get RivaTuner to work with both my cards with an automatic fan profile. if there aren't any pre-made BIOSes with better fanspeed control, is there a BIOS editor out there so a nub like myself can try to mess with it? i'll probably sell my cards when the next gen comes out, so i really don't feel like spending $100 on aftermarket cooling for them. i just want a BIOS that forces 60% fanspeed when the GPU starts to warm up.
Opened Standart HSF with Blow Fan 2A ......after Flash Bios Mod :) :)
http://img183.imageshack.us/img183/7066/img1070ir7.jpg
VGPU mod 1.55volt.......:) :)
http://img510.imageshack.us/img510/9732/img1072jf9.jpg
3D Mark 05 Core 1015 / Memory 1370.....
http://img528.imageshack.us/img528/9366/05ki6.jpg
3D Mark 06 Core 1015 / Memory 1370.....
http://img185.imageshack.us/img185/1093/06nx1.jpg
