Version 1.15 - 24th August, 2019
- New: AMD Ryzen 3000 series support.
- New: Full multi-monitor DPI awareness support.
- Fix: Core Temp randomly freezes during startup.
- Fix: Improve AMD Zacate APU support.
Version 1.16 - 29th June, 2020
- New: Intel 10th generation CPU support (Cannon/Ice/Comet Lake)
- New: Package Power reading for AMD Zen based CPUs
- New: Very preliminary Intel Tigerlake support
- New: Preliminary AMD Renoir support
- New: AMD Picasso detection
- New: Intel Lakefield detection
- Fix: System hangs during ATI SMBus dump in AIDA64
- Fix: Crash when display DPI changes
- Fix: Crash when opening Settings dialog
- Fix: Main window incorrectly resized when display DPI changes
- Fix: High CPU usage on unsupported Intel CPUs
- Change: Expand available information on unsupported Intel CPUs
- Change: Improve stepping detection on supported Intel CPUs
- Change: Frequency detection changes for Nahelem/Westmere to make it consistent with newer Intel CPUs
Thanks for the update! I did always wonder why I was never able to get a reasonably accurate temperature because I use phase change cooling.
+1 ^
I've been using Coretemp for the last 12 or 13 years exclusively for CPU temps. When many say most temperature monitoring software doesn't read Ryzen accurately, I put my trust in coretemp.
Version 1.17 - 3rd April, 2021
- New: AMD Zen 3 and Zen 2 APU support
- New: Intel Rocket Lake support
- New: Preliminary Alder Lake support
- New: Very preliminary Meteor Lake support
- Fix: "Unsupported CPU" message when only some cores have HT enabled
- Fix: Epyc Rome/Threadripper 3rd gen Platform detection
- Fix: Gemini Lake platform detection
- Fix: Whiskey Lake codename
- Fix: Incorrect VID reporting on some Celeron/Pentium processors
- Fix: Crash on Intel Banias based (Pentium/Celeron M) processors
- Fix: Turbo multiplier detection on Nehalem/Westmere
- Fix: Bugs related to response to DPI changes
- Fix: VID reporting on some AMD Athlon64 processors
- Change: AMD Bulldozer based processors now display the amount of modules/threads instead of cores/threads
- Change: Improve accuracy of information on unsupported Intel CPUs
Version 1.18 - 4th December, 2022
- New: AMD Zen 4, Zen 3 APU and Zen 2 APU support
- New: Intel Raptor Lake and Alder Lake support
- New: TDP, TjMax, multiplier range detection on desktop AMD Zen platforms
- Fix: Address the kernel-mode driver vulnerability/exploitation issues
- Fix: Redesign Bclk detection on all AMD platforms starting from the Phenom series
- Fix: Workaround the Bclk detection issues on Intel Skylake and newer series
- Fix: Bclk detection on older Intel platforms, utilizing x2Apic configuration
- Fix: Thread count on Intel hybrid architectures (Raptor/Alder Lake)
- Fix: Improve support for multiple older AMD and Intel processors
- Fix: Base multiplier detection on AMD Zen processors
- Fix: Incorrect temperature on AMD Zen processors (missing -49C offset)
- Fix: Engineering Sample recognition on newer Intel processors
- Fix: Multiple minor bugs
- Change: Windows Vista 64-bit is no longer supported
Version 1.18.1 - 24th September, 2023
- Fix: Do not display TDP and TjMax for Zen and Zen+ CPUs
- Fix: Incorrect BCLK on legacy (Pre-Zen) AMD CPUs
- Fix: Check for updates feature
Version 1.19.5 - 21th September, 2025
- New: Support for Zen 4 AMD processors including ThreadRipper 7000 series, Raphael, Dragon Ridge, Genoa ES, Hawk Point, Phoenix
- New: Support for Zen 5 AMD processors including ThreadRipper 9000 series, Granite Ridge, Fire Range, Strix Halo, Strix Point, Krackan Point, Turin
- New: Per-CCD and per-core temperature readings for all generations of Zen based processors, most models supported
- New: TDP and TjMax detection on most Zen based processors
- New: Support for Intel processors including Sapphire Rapids, Emerald Rapids, Granite Rapids, Lunar Lake M, and preliminary Panther Lake
- New: Dark Mode (requires Windows 10 or newer OS)
- New: Effective core frequency readings + system tray icon
- New: Core select menu for frequency (right click the frequency fields)
- New: P-Core/E-Core tooltip indicators
- New: Folder selection for log file path
- New: Windows Event Log reporting for Overheat Protection events
- New: System Information dialog upgraded
- New: Average measurement field for temperatures
- Fix: BSOD on some newer AMD machines
- Fix: Vulnerabilities in driver and better restrict driver access
- Fix: Improve frequency detection accuracy on AMD processors by using a new algorithm
- Fix: Frequency detection on newer Intel processors
- Fix: Many other fixes for older AMD and Intel processors
- Fix: Window size on DPI, resolution and display changes
- Fix: Button sizes in the settings dialog in some languages
- Fix: UI glitches on older OSes
- Change: Make the look and feel of the UI on AMD processors to be the same as Intel
- Change: Both Tdie and Tctl readings are displayed on Zen 1 processors when applicable
- Change: Mini-Mode and TjMax adjust options removed
- Change: Modulation field replaced with Effective frequency
