Dark Energy, read this and see if it helps any http://www.overclock.net/intel-mothe...-ep45-ud3.html
Here is a pic of my rig now, before all my WC parts come it.
Well I looked and they didn't have any DRR2-1200 ram so I just went with the 1066 but I could even push to 540 FSB if I wanted to quickly bench because I found the ram is stable at 1080. But I doubt anything above 520 FSB will ever be completely stable for the CPU unless I get lucky and spend days of tweaking
Sup guys for those on the EP45T USB3P i updated to F2D bios, no issues at all
got a nice run at 24C last nite on low vcore
http://img171.imageshack.us/img171/5...end88passe.jpg
will go up till 4608 lets see how it goes :up:
Cheers :up:
Sergio
been testing a while this mobo and i love it :up:, its like a remake of the good UD3P rev 1.0
been testing all that i did on the UD3P rev 1.0 and no problems at all, i remember testing the limits on in and goot some bad reboot loops, this doesn't have that problems, sometimes when pushed hard yes you just power off and back, but had to do that only 2 times in 2 weeks of testing rest it autorecovers pretty fast...
here's what i am testing now, mem is not tweaked just using auto and turbo
http://img230.imageshack.us/img230/7...pi32mturbo.jpg
some bandwith
http://img156.imageshack.us/img156/3...mturboever.jpg
Cheers :up:
Sergio
Nice job Sergio.:up: Look like a fun board to play with.
Hey Sergio do you have any pics of your system? I just brought a USB3P and would like to watercool but dont know how it will look.
Shure mate :up:
http://www.xtremesystems.org/forums/...=249147&page=3
That's my build :up:
Have you tried running a Linpack tester at those speeds and voltages? What were the temps? Talking about actual core temperatures like in Realtemp.
I normally dont use Linx or IBT just test with prime but i did it for 4500 you can see it on the 4500 Linx Thread at 24C ambient wich is high
Just to quote this i could never did on my ex water cooler as it took max temp at 1 sec linx, this system dropped Linx one 10C or more
I did a run for you, sorry max mem i can use is that im not using page file, passed at low vcore :)
http://img704.imageshack.us/img704/3...9turb0linx.jpg
http://img23.imageshack.us/img23/3095/p1040541hd.jpg
Cheers
Sergio
Not bad for temps. My cores do the same thing. Core 3 and 4 are 5C higher than core 1 and 2.
Parts are coming in, few more days........oh the waiting.
Very nice LinX run Sergio!
Thank you my friend i could do a 20 run but will not, dont wanna bust my X3380 if i do it maybe opening the door and let ambient go to 18C that will be nice ;)
polish ? lmao
be sure not to overtight barbs specially on the res
Cheers
Sergio
NoGuru it looks like your going to have a great time once your loop gets setup.
I just hooked up my first loop, MCP655 pump, MCR 320 rad w/ 6 YL fans, bitspower 7/16" compression fittings, Apogee XT, Swiftech Micro res w/ silver coil + distilled water, and I believe Primochill 7/16" tubing.
Everything went together very smoothly, and I wish I could say my X3380 went under water, but I nabbed a really sick chip for a great price. . .
http://i42.tinypic.com/b9c9pz.png
whats even sicker is that I got the whole loop for $250 shipped from a member on ocn, its definitely inspired me to put all my rigs under water now.
trying to take it easy since it is an ES and a B0 revision.
honestly that took insane VTT voltage because of the stuck uncore multiplier. Once I get a bios to fix that this chip is going to be great.
I submitted some scores for the X5660, and then realized that ES's aren't allowed, or thats what I assume after reading the rules page in depth. So are ES chips allowed for hardware points on HWbot?
Well trying to up my Gskills ECO 2x2 1600 CL7
i almost got it lol this ain't fair :rofl::ROTF:
http://img687.imageshack.us/img687/6...cr1pl8spi3.jpg
http://img266.imageshack.us/img266/9...cr1pl8ever.jpg
Cheers :up:
Sergio
Dam 8 more iterations and you would be all set.
