Originally Posted by
riiaku
I'm still using 1503, its been running smooth for a long time but i have some sound problems in vista with games, i read in other forums that updating my bios would do the trick.
My question is what is the most stable bios out of all of these that would maintain my 3.2 gigahertz overclock of my core 2 duo 6400 and also be stable with no bugs? Or hopefully allow me to push to a higher overclock if possible. I'm using OCZ Platinum Revision 2 2GB DDR800 PC6400 ram. It wont boot even if i go one megahertz past 400, so yeah. Can anyone please lend a helping hand?
EDIT: just tried the 2004 mod bios, booted up ran load setup defaults, did not clear cmos though, but still runs great. I went into bios set up my overclock options and it runs awesome, all i gotta do now is run it with games and see if it solved the problem, vista needs a lot of work.
What is memory remap feature and what is better for OCing disabled or enabled. what is dram throttling too? do i need it? and what about the CPU thermal control what would that do if i disabled it. sorry for all the questions guys its just i always wondered if i really needed these options or not and what they did.
