Has this board setfsb support?
the stuck temp is not abit's fault...that lies strictly with Intel with poor quality DTS sensors....i had the exact same problem on my 1st QX9650...core one was stuck at either 51C or 54C...it would register above that when i prime 95 the cores with a high overclock...at stock speed, it didn't budge!
Hmm I'm going to have to try the 17 beta, the official 16 bios is decent but my uguru is broken still as it doesn't give me the proper vcore choices to set. Also my board and chip is great at 445ish, but getting to 450 has been tough and it's still not 100% stable. If its still raining tonight after work i'll definitely flash it, but if its not raining, I have to do yard work.
Well 17 probably won't fix that. But it should give you more FSB.
guys just a very quick ?
I am wanting to overclock my Q6600 and my IP35 Pro came with Bios 14 is 16 worth upgrading to for better overclocking ?? or should I just stick to 14
Use 14 for Q6600 overclocking :)
Nice overclock Cob. You recommend 14 for the q6700 as well? I just upgraded to the 16, but should I roll back?
Well in theory 14 should be just as good with a Q6700 as a Q6600. Certainly give it a go.
I found 16 b04 to be better than the final 16 too, tho still not as good as 14.
Also curious on what your WC loop is like. Im dumping my current rad for an MCR320 w/ Panaflows and hopefully getting a Dtek Fuzion V2 if they ever come back in stock. Im having a hard time booting in at 4ghz. When I get my tracers in ill try to hit a higher fsb with a 9x versus lower fsb with a 10x. I dont know, but I really need to hit 4ghz haha.
It's pretty basic tbh. A D-Tek Fuzion, Alphacool Nexxxos Extreme II and a little XSPC pump/res combo, all on 11/8mm Tygon. I'd like to get a PA120.2, but the roof of my case is cut for the Alphacool and I don't want to have to drill more holes in it.
But my temps have always been fine with that set-up anyway. It ran a B3 Q6600 at 3.55ghz for 9 months, the majority of which was Folding time.
Hi Cob, this image is from my Q9450...compared to your coretemp some of the fields are blank or completely incorrect....was this something you noticed when you were on BIOS 16?
Attachment 78160
Any ideas as to why this would be different? cheers.
I haven't really been using Core Temp with the Q9450, and I doubt I was using 16 for long enough to have a reason to open it.
In fact I don't think I was able to boot into Windows with 16 using the settings I wanted to use (475x8), so it was quickly reflashed.
Have you tried that last non-beta version of Core Temp?
I re-downloaded the latest non-beta coretemp and tested it and this time all but one of the fields was ok (?), so that resolves that, thanks.
I think I might try the lastest beta BIOS if it seems to support higher o/c FSB with this chip, I've not had much success around 450MHz.
Hows the SLI vs Xfire on this board? Because of the slower PCI X slot?
I'm not really sure what you mean by SLI vs Xfire since you can't run SLI on any intel chipsets right now. Personally I think P35 boards are single video card only, the 4x 2nd slot doesn't really allow full performance. You'd be much better off going with an x38/48 board if you want xfire. Or an nvidia board for SLI.
Anyone used the E7200 yet? I believe I'll be gettng this board, that CPU and 2gig of PC6400 Ballistix and just wandering if it'll be as good as I hope.
Ace, if you read this, would nylon screws and bolts work for the pipe mod? Thanks
I apologize if these questios have already been answered, have been working 12 hr days and can't keep up with this great thread.
