What are the differences between these UD3P and UD3Rs and say a DQ6 version P45 motherboard? Just curious if the DQ6 is any better or the r or the p?
Well sorry, I meant the other one that just has a different letter that is a little cheaper that has ddr2, I would have to look but its ok. The main thing I was wanting to know was what you just said. I was getting the impression that this was the case with the DQ6 from reading around as well. I might grab one of these, my motherboard is crippling my CPU right now and it kills me a little inside more and more every day. :p:
New PiFast Test With Higher Ram Frquenc
And Once Again Break My Record :D
http://shahrsakhtafzar.com/img/out.php/i18385_1.JPG
well done Vivid ... u certainly know how to overclock a quad! :clap:
Well thank god I ordered the P version LMAO. I would have been salty. I think I would have noticed it though before buying it though, probably. I can't wait to get it, I am so geeked.
How high is your VTT? I can reach 3.825G at 1.35V core and 1.40V VTT.
Tanx M8
Just HardWork :cool:
I'm Use Water Chiller But I Don't Think It's Necessary:D Air Can Be Enough To 1.5 Vcore:up:
VTT: 1.6 For High Test And 1.4~1.45 For 4530Mhz FSB 533Mhz :yepp:
Hi everyone, this is my first post and i apologize for my english but i'm italian :) not my fault anyway lol
I have a question to the "Batch Experts". I just ordered a Q9550 SLB8W with this batch "L847C200"
Could someone tell me what can i expect in oc with this batch? is it a good or bad one? i'm still a bit confused about this batch story...
thx all
PS: congrats to Vivid for his amazing results
I'm not a "Batch expert" lol :D, but you can check your VID using CoreTemp:
-If your VID is lower than 1.2000v (lowest in this thread is 1.1375) then you're having a golden batch CPU :D :yepp:.
-If your VID is around 1.2500v, you're having a :banana: CPU.
Keep in mind that a high VID CPU doesn't always OC badly, some with high VID can OC very well (my old E6600 with 1.325 VID can make 3.6Ghz with stockfan), but this case is rare :p:.
/My Q9550 L848C310 1.2125VID is now running at 450*8.5=3825Mhz 24/7 completely stable with 1.2250v in BIOS (1.2000v in CPU-Z).
I know how to check the VID with CoreTemp but i ain't got the cpu with me yet :D that's the reason why i asked.. im thrilling to know if my batch is a good or bad one :hehe:
I already have a Q9650 L845B562 that make 4ghz with 1,3v but im not so satisfied about it so i'm looking for luck with this new Q9550 L847C200 and in case the "baby" will do it better i think im gonna sell my Q9650 ;)
Your cpu rocks for me :up: i guess u can reach 4ghz staying under 1,3v (thats my aim)
now I have a new baby! :) my 9550 E0 FPO L922B951 VID 1.1125V:clap:
today finishing testing and results is :
http://pic.ipicture.ru/uploads/090908/mzq73diz81.png
I belive,4Ghz too izzi for this chip, but my mobo is not good for quad 45nm.
465 FSB is good result, and it not a limit,but I dont want raising too much volt fot NB.
BTW, what temp is critical for NB? now I have 64'C at peak load, is this good or not?
Temps for chip is not more,than 79'C at LinX,Prime95 at 65-67
and my rig is:
Intel Core 2 Quad Q9550 E0@ 3952 at 1.264V real
Thermalright IFX-14 +NOCTUA NF-P12-1300@
Asus Maximus Formula @ Rampage Formula x38
DDR2 2x2Gb G.Skill F2-8800CL5D-1100@1117
2xClub3D ATI RADEON HD4870 512MB OC Edition 800/950 CROSSFIRE
Raid0 2x320Gb Seagate SATA2 16Mb
DVDRW Samsung 182M LightScribe
PSU 780W Tagan Superrock
Full Tower Thermaltake Xaser VI + 4x120 vent. + Scythe Kama Meter
Windows7 x64 RTM
Have a new board to play with, trying the EP45 DQ6. Ran some blend on 2 cpu's. Was able to get stable on the same vcore load with both cpu's on this board as on my UD3P. Only thing i dont like is this board does not have LLC so need higher idle voltage because of vdroop. My main goal was to try for higher max oc but in w7 64bit it is a real pain above 543fsb.
http://img83.imageshack.us/img83/368...q95501312v.png
4350mhz prime blending on the dq6 board. Sorry for the tiny ss but I am on xp and have no snipping tool. 4350mhz 1.360vcore pl8 turbo 5:6 divider. I hate xp but want to use it to try for higher max validation.
http://img190.imageshack.us/img190/4...50dq6board.png
It isn't junk, the thing I dont like is it has no LLC so you will need more vcore set in bios to allow for vdroop/vdrop. I have been able to reach the same stable oc's with this q9550 and my q9650 with the same load vcore and other voltages on this DQ6 as on my UD3P. It is actually a higher end board but I think the UD3P/R are a better value. My main reason for getting this board was to shoot for higher max oc, I believe this is a better benching board but for 24/7 use I would probably go with the UD3P/R. I am back in Windows 7-64 running blend at the same settings with a more clear ss. Will let this run for a few more hours to be sure it is stable.
http://img197.imageshack.us/img197/8...50dq6q9550.png
