is vtt the same as PLL
vtt is know on some mobos as FSB Termination Voltage. PLL is completely different from vtt. On 45nm, vtt shouldn't exceed 1.4 as it will cause electromigration (cause the chip to slowly die).
L812B258, Pack Date 05/15/08 should be avoided, has a VID=1.25
hello which is better for the q9450
Gigabyte X48-DQ6 or abit ip35-pro?
This is my new toy:
http://forum.nexthardware.com/galler..._1_h_prime.jpg
Vid, according to coretemp, 1,25.
Vnb 1,29 volt, vtt 1,2 volt, fsb 1,6 volt.
It's an L815 boxed.
I've tested two of them and they clock exactly the same. :)
http://img66.imageshack.us/img66/958...enchwo4.th.jpg
http://img529.imageshack.us/img529/3379/3800qq1.th.jpg
http://img529.imageshack.us/img529/5...3800ly6.th.jpg
All test with Thermaltake Max Orb, AC5, is not the best cooler but for my quad is enough.
Temps in full load 63-64-55-65 at 3,8ghz
Later i will test more than 3,8ghz if i can do it.
Asus Rampage Formula x48
4x2GB G.Skill PC2 8000 (DDR2 1000)
Edit: I over-volted cpu vcore because I was experimenting with LLC for stability as there have been reports about instability on the RF.
oh yeaah i see too much v core in your quad, , re u using watercooling right??, but i see x48 is much better, if i put 3,91ghz like u my score in cinebench will be lower for sure, pretty nice chiset Zucker2k.
Iv been tested at 3,9ghz and i boot fine but my temps re a little hi, , almost 57 in cpu adn cores right 58 avg, but if y bench, ohh my god there s a barbaque here, all invited jajajajaaj
Looks like I just need to buy a real Rampage, and get a new Q9450...
Good results Zucker.
tnxs Zucker!, buy x48 is really superior, look at cinebench to much diference thats te good of your mobo, , exceleent performance.!
Plz can u post at 3,8ghz to compare in evereest test ans super pi. I can see the difference between x48 and p35 chipsets, obviously if u want!
Tnxs again men!!
Your welcome.... here is cinebench at 3.8Ghz... I posted this result here http://www.xtremesystems.org/forums/...=156129&page=3 last week. I'll run a 32m pi now and post results asap.
Thought I'd have a last play with this chip in the IP35 Pro before I start playing with the P5Q Deluxe -
http://img261.imageshack.us/img261/8931/superpiyl6.jpg
Not bad considering the VTT only goes upto 1.42v in this board.
Anyone running this chip in the P5Q Deluxe motherboard? I've got the following recommended BIOS settings for that board. I'd like to hit as close to 500FSB as my 'on air' setup can possibly take.
JumperFree Configuration Settings
AI Overclock tuner: MANUAL
CPU Ratio Setting: 8
FSB Strap to North Bridge: AUTO
FSB Frequency: 400 - 425
PCI-E Frequency: 101
DRAM Frequency: 1003 - 850
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: MANUAL
1st Information
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 18
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: DISABLED
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
Common Performance Level: AUTO
Pull-In of CHA PH1:
Pull-In of CHA PH2:
Pull-In of CHA PH3:
Pull-In of CHA PH4:
Pull-In of CHB PH1:
Pull-In of CHB PH2:
Pull-In of CHB PH3:
Pull-In of CHB PH4:
CPU Voltage: 1.35 - 1.4
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.5
FSB Termination Voltage: 1.2
DRAM Voltage: 1.96
NB Voltage: 1.2 - 1.3
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: DISABLED
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
CPU Clock Skew :
NB Clock Skew :
Advance CPU Settings:
CPU Ratio Setting:
CPU VID:
C1E Suppport:
Max CPUID Value Limit:
Intel® Virtualization Tech:
Vanderpool Technology:
CPU TM Function:
Execute Disable Bit:
Hi, I'm new to overclocking, and I just got a Q9450. I got it to 3.2Ghz by only changing the vcore to 1.26 and everything else on auto, but after 2 hours of prime95, Realtemp reads that the max temps were 65, 53, 56, 60c. According to my thermometer, it's about 88 degrees in my room. I have a TRUE 120 and an EVGA 780i mobo. Are these temps too high? Do I need to remount the HS? or just try lowering the vcore? What's a good amount of time to run prime95 for ? Sorry for all these questions. I searched around and I'm still a little uncertain.
Those temps arent bad for air coooling in a 88F room. 65C is the max I would go so you are fine.
Welcome BTW!
Wow thanks! What a quick reply!
Uh oh, I just found out that I read the thermometer wrong. It's actually 78*F. Are my temps still ok?
