Am i right to say that a thermochill 120.3 rad won't fit beneath there in the Lian Li V1200Plus?
I think you're right :D It's so strange, I have an akasa eclipse atm, but now I want a shiny white lili v1000 too man... Those cases are really beautiful.
I'll say, just mail the guy :) www.murderbox.com ;)
I'm planning to change my fluid soon with some medical grade sterilized distilled water. :D
That's an impressive first build! I like the way you installed your Swiftech reservoir. Did you purchase some Plexiglas and cut it to fit?
Ok, I was going to ask the above question until I noticed that you cut the Swiftech mount from 1/4" Plexiglas using a CO2 Laser. I'll have to analyze my options to see if I can come up with a solution.:rolleyes:
I thought it was bad to have the output of the pump sticking up.
someone has to be alert on these murderboxes ;)
THe Only pump that has a MFR warning against that orientation that I am aware of is Iwaki...but I mounted my RD30 in that postion and it was fine. I have mounted a number of D-5 that way without ill effect.
You are killing me man....
Now Your Talkin - That Looks Sweet - Tri Sli
Looks awesome :D
Pls hurry and post some pics of the whole system !!
what gfx card are those ???
Which gfx's are those? ultra's or gtx? OMG THAT LOOKS NICE
