P5WDH; Rev 1.02g; 66M0AG; (July 2006); Q6700 G0 @ 3.0G; BIOS:
2302
- switched from QX6700 B3 to Q6700 G0, Aug 23, 2007
- stable @ 300FSB with either QX6700 B3 or Q6700 G0
- never a problem with memory @ 1000, 3:5, 5,5,5,15
- EZFlash USB flashdrive method
- use Speedstep, Vcore settings not tested
- no problems with "onboard audio" staying disabled (X-FI F1 installed)
- or any other BIOS settings
- all QFan PWM settings disabled
- no radical performance change
- temps all nominal (Q6700 G0)
- AMB: 71f/21.6c; case closed
- approx 35watt less AC power, same machine clock/specs/parts, than QX6700 B3 (measured with WattsUpPro)
- specs/details in sig below
OCCT TEST @ 24min with CPUZ, Coretemp, MB Monitor:
http://www.esnips.com/doc/6474e6d5-b...2-OCCT-1-24min
OCCT TEST 1sec before end (shows idle temps/SpeedStep Vcore):
http://www.esnips.com/doc/565d658f-a...CT-2-00min-end
