hi gurus,
ive been running this oc for a year now and it bsod only once:
ASUS P5Q DLX Template :
JumperFree Configuration Settings
AI Overclock tuner: manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: AUTO
FSB Frequency: 425
PCI-E Frequency: 100
DRAM Frequency: ddr2-1066
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
Common Performance Level [5]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.20625
CPU GTL Voltage Reference (0/2): 0.670
CPU GTL Voltage Reference (1/3): 0.670
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.24
DRAM Voltage: 2.02
NB Voltage: 1.26
NB GTL Reference: AUTO
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Normal
NB Clock Skew : Normal
Advance CPU Settings
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: enabled
today ive decided to give it a bit more juice and see how it performs at 3.8 so i got it stable with fsb 444, ram 1067 and vcore 1.23125, max temps reported by real temp r 66,63,59,59
everest is also showing those same temps but its also showing cpu temp next to those core temps and its a lot lower, like 52 under load, so my question is: how dangerous r these core temps im having and what can i do to lower them, cooler is ocz vendetta 2, ram corsair dominator 8 gb, q9550 @ p5q deluxe
