Manufacturer part
Manf Part # OSA165DAA6CD
Same on ALL 165s
Manufacturer part
Same on ALL 165s
But there is a big chance those are 0608mpmw's, as i got one.Quote:
EDIT: I looked into the mail, it is infact the same seller and same item as i got my ccb1e 0608mpmw from. Perhaps you could mail "betha1377" and ask him about the stepping.
Seller: betha1377 (baymails@bellsouth.net)
Got my CCBBE 0610DPMW 165 up and running. Currently 312*9(2807). Still going up. Runs nice and cold for air. Idle at 28c load around 35c. ;)
i would definatly send the seller a message asking what stepping it is. if no reply, i wouldn't bid on it. i believe last time i asked that guy what stepping he was selling it was a CCBWE 0607
Originally Posted by itznfb
Ive won that, I just know it will be the worst 0608 made tho lol.
nice :) TT.BT 1424v@3000mhz 29c idle.. :stick: room temp? :rolleyes:Quote:
Originally Posted by HousERaT
itznfb, I didn't find the utility on the CD, so I downloaded it form nVidia (great stock btw). It gave me a message that the monitoring isn't supported by the bios (or something to that effect). I'm guessing that's why it's not on the CD. ;)Quote:
@crashtack did you install the chipset drivers? http://dlsvr01.asus.com/pub/ASUS/mis...a/MakeDisk.zip
it shouldn't matter what motherboard you have.
Additional Comment:
i believe this software allows you to alter the frequencies and voltages from within windows, which i highly recommend NOT doing. \
My best one so far : CCBBE 0610DPMW
http://img414.imageshack.us/my.php?i...000147v7fm.jpg
http://img414.imageshack.us/img414/3...147v7fm.th.jpg
I got my 0610 from Monarch last week.Quote:
Originally Posted by Mastactor
Which cooling solution are you using?Quote:
Originally Posted by famich
Btw.: Is 48° at full load (both cores) at 2900 mhz (1.4v) normal with tuniq tower 120 - for ccb1e 0608mpmw ?
Watercooling - :) see my sigQuote:
Originally Posted by Malkec
those getting from monarch this and last week,
when did you order?
and what did you order? the oem, or retail box with fan?
This is round 2 of installing XP for this system. So, maybe i didn't intstall the drivers this time around. Must have installed some of them though. The nVidia net port is working as well as the nVidia Raid monitoring utility.Quote:
:woot: monarch shipped my new 165, ordered yesterday. It will be here on friday, just in time for a rainy weekend :D
Here are my intial results.
Opteron 170 CCB1E 0609 FPAWon water
http://img68.imageshack.us/img68/133...42vcore7io.jpg
OPTERON 165 CCB1E 0608 MPMWzalman 9500
http://img77.imageshack.us/img77/204...hrs142v5qu.jpg
Its pretty warm in Texas already & was over 80 degrees in my pc room.
i ordered the oem last wednesday morning. they shipped it out friday.
running dual prime stable and 3d stable(everything stable so far) @2961mhz 1.4v
ram with 166 divider running at 269 3-3-3-8. i havent had any time to tweak my ram nemore.
55c, thats a tad high for water...
wonder if I have too much AS5 on there cuz I was thinking the same thing. My surf temps aren't much better than the Zalman was.Quote:
Originally Posted by creidiki
Update: Opteron 165 CCBBE 0610DPMW (Used to be Repoman's) WaterCooled with IHS On:
http://img.photobucket.com/albums/v6...2906SP2004.jpg
CompGeek, If you could please update my entry..
CCBBE 0610DPMW
2952Mhz 328x9
1.5v Bios 1.472 Windows
TTBT
Prime Stable:Yes
Load Temps 48c
http://www.swva.net/jehamilt/2952.jpg
Temp offset is set at +10 so I belive the temps are fairly accurate on the Expert.
Ambient is 73.9F/23.3C
I think before I was having some problems with my Ambient temps. My computer room is normally hot 80F+ I was having a :banana::banana::banana::banana::banana: of a time getting 2950 Stable.
Ive now bumped it to 2988 @ 1.5 and its priming away so far.
the screen shot i have is not recent, was when i first got this thing working and didn't realize i didn't need all that vcore to run 300x9 on this nice Opty 165 which i walked into Monarch and hand picked
also the EVGA NF41 mobo i was running along with TCCD OCZ Plat Rev2 memory was really gumming up the works
now with the DFI mobo and Crucial Ballistix i am rockin' 300x9 at stock vcore, 1.42v, idle's 30*c, loads 50*c dual prime small FFT's on air!
**edit, stock vcore runs fine but not prime stable, takes a bit more to keep it prime stable
not too shabby i dont think considering all i have is a Zalman 7000CU-B
http://xs67.xs.to/pics/06061/primestable6hrs.jpg.xs.jpg
Can you guys list cooling? This is perhaps the most important element of OCing.Quote:
Originally Posted by Spazilton
Its right under Vcore.
TTBT..
That's exactly where I am (2952 with 1.5v on BIOS) but still not stable. What did you do to get it stable? I'm with TTBT too, but load temps get to 52c and that's the problem IMO. Do you think removing the IHS will help? Core 0 is the wearker, core1 can bench at 340x9. With my last 165 temps dropped 5-6c, exactly what I need :DQuote:
I've been a bit lazy lately (very little spare time) so I'm running the chip 334x9 with 1.525v. I can bench, surf, do anything but prime. I think with normal use the chip doesn't get so hot so I get no errors. So sign me as another member of the no-prime club :D If I think how many hours I've lost getting something prime-stable... I don't bother anymore. Prime Small FFTs for 30 minutes, and if it works, I lower HTT 2-3 mhz and that's my 24/7 :slap:
