Hey I can link to 10 members with more sig space ( yes... I did have to look for em :sofa: )
I already removed a line because I was told it was getting to big, and the wfo quote I think will wear off in a few days seeing the graph :cord: ;)
I just wish the sig edit box was wider, I have so much coding for my sig it is so hard to figure out exactly where I am in that dinky little sig edit box :p:
pfft, who needs pictures. Text is where it's at.
Quick Question....What is an A2 core? Linux only?
Yes - Fahcore_a1 is Windows SMP and Fahcore_a2 is Linux SMP.
Thanks Russ, Thought so but just wanted to make sure I wasn't missing points somehow. :)
He forgot one though, macOS :P
I'm running a q6600 @ 3.6 with g-skills @ 1066 on x38 and XP sp3. My previous runs with SMP were with 5.91 on lesser equipment at lower speeds.
I am trialing 180.60 for the GPU's now and WinAFC too.
What I need is ppd figures for single and dual instances of SMP. BOTH Vista and XP either with or without GPU running too. Can anyone help?
*Q6600@3330mhz 1.35v | Abit IP35pro | 2x2GB Gskil pc8000@925mhz | Asus 9800GT 700/1783/900 | Corsair HX520 | CM690 | TRUE 120
Vista 64 w/ the old AC http://distributed.org.ua/forum/inde...showtopic=1149
SETUP A: Q6600@3.33ghz on a single smp client...
SETUP B: Q6600@3.33ghz on dual smp clients with affinity changer...Quote:
Project : 2665
Core : SMP Gromacs
Frames : 100
Credit : 1920
-- X4-smp1-Vista64-Q6600-3330mhz-6.23 --
Min. Time / Frame : 13mn 15s - 2086.64 ppd
Avg. Time / Frame : 13mn 20s - 2073.60 ppd
Cur. Time / Frame : 13mn 26s - 2058.16 ppd
R3F. Time / Frame : 13mn 22s - 2068.43 ppd
Project : 2665
Core : SMP Gromacs
Frames : 100
Credit : 1920
Min. Time / Frame : 16mn 15s - 1701.42 ppd
Avg. Time / Frame : 16mn 32s - 1672.26 ppd
Cur. Time / Frame : 16mn 37s - 1663.87 ppd
R3F. Time / Frame : 16mn 37s - 1663.87 ppd
-- X4-smp2-Vista64-Q6600-3330mhz-6.23 --
Min. Time / Frame : 16mn 14s - 1703.16 ppd
Avg. Time / Frame : 17mn 00s - 1626.35 ppd
Cur. Time / Frame : 16mn 29s - 1677.33 ppd
R3F. Time / Frame : 16mn 29s - 1677.33 ppd
Thanks Mike, For us XP types preliminary results look good....Very good in fact. Keep an eye on the WinAFC thread if you are interested.
Anyone got these figures beat?
I've got a question about memory on a fold only rig
Is it worth using 1066 or better ram? anyone got any info? ppd versus ramspeed?
from what I've heard ram makes almost no difference in ppd... in fact 2 of mine are using ddr2800, and with my cpu oc I have them at 740.... because the only dividers were below or above 800, and I didn't really care about ram oc's on dedicated folders..
would anyone have a problem with me trying to fold for this team ,if not how would i set it up,i dont want it to run in the Background i want it to run in my taskbar and i can view what going on i also will be running it on this PC the spec's are in my Sig
Please join us. You should install "Windows XP/2003/Vista
System tray client installer with viewer"
http://folding.stanford.edu/English/Download#ntoc1
ok ty im now folding ty
its showing team 32, why is that i changed it but it not taken
Right click the system tray and go to configuration. You can reenter the team number. It is 36362.
ok i changed it but on the site its still showing that other team, oncei finish one it should change to this team right?
you need to stop and restart the client after you change the team number. then the next wu turned in will start going to the new team #... whatever you turned in already under that other team # is not going to change, it's already turned in. whwerever you turned it in, it's there for good. all you can do is change how your client turns in.. you can't go back and change wu's that have already been uploaded and counted.
start and stop your client.. it needs to restart with the new team #, it will not change it on the fly. it needs a restart to reread the client.cfg file where that info is stored, and it only reads it on start.
ok done ty
well i dont know whats going on i had two going and they have been delete , i dont know if i did it or if there is a problem , is it what the log is saying
--- Opening Log file [December 12 19:20:25 UTC]
# Windows CPU Systray Edition #################################################
Folding@Home Client Version 6.23
Launch directory: C:\Documents and Settings\Roger\Application Data\Folding@home-x86
[19:21:31] - Ask before connecting: No
[19:21:31] - User name: XRogerX (Team 36362)
[19:21:31] - User ID not found locally
[19:21:31] + Requesting User ID from server
[19:21:31] - Machine ID: 1
[19:21:31]
[19:21:31] Work directory not found. Creating...
[19:21:31] Could not open work queue, generating new queue...
[19:21:32] Initialization complete
[19:21:32] - Preparing to get new work unit...
[19:21:32] + Attempting to get work packet
[19:21:32] - Connecting to assignment server
[19:21:32] - Successful: assigned to (171.64.122.136).
[19:21:32] + News From Folding@Home: Welcome to Folding@Home
[19:21:32] Loaded queue successfully.
[19:21:34] + Closed connections
[19:21:34]
[19:21:34] + Processing work unit
[19:21:34] Core required: FahCore_78.exe
[19:21:34] Core not found.
[19:21:34] - Core is not present or corrupted.
[19:21:34] - Attempting to download new core...
[19:21:34] + Downloading new core: FahCore_78.exe
[19:21:35] + 10240 bytes downloaded
[19:21:35] + 20480 bytes downloaded
[19:21:35] + 30720 bytes downloaded
[19:21:35] + 40960 bytes downloaded
[19:21:35] + 51200 bytes downloaded
[19:21:35] + 61440 bytes downloaded
[19:21:35] + 71680 bytes downloaded
[19:21:35] + 81920 bytes downloaded
[19:21:35] + 92160 bytes downloaded
[19:21:35] + 102400 bytes downloaded
[19:21:35] + 112640 bytes downloaded
[19:21:35] + 122880 bytes downloaded
[19:21:35] + 133120 bytes downloaded
[19:21:35] + 143360 bytes downloaded
[19:21:35] + 153600 bytes downloaded
[19:21:35] + 163840 bytes downloaded
[19:21:35] + 174080 bytes downloaded
[19:21:35] + 184320 bytes downloaded
[19:21:35] + 194560 bytes downloaded
[19:21:35] + 204800 bytes downloaded
[19:21:35] + 215040 bytes downloaded
[19:21:36] + 225280 bytes downloaded
[19:21:36] + 235520 bytes downloaded
[19:21:36] + 245760 bytes downloaded
[19:21:36] + 256000 bytes downloaded
[19:21:36] + 266240 bytes downloaded
[19:21:36] + 276480 bytes downloaded
[19:21:36] + 286720 bytes downloaded
[19:21:36] + 296960 bytes downloaded
[19:21:36] + 307200 bytes downloaded
[19:21:36] + 317440 bytes downloaded
[19:21:36] + 327680 bytes downloaded
[19:21:36] + 337920 bytes downloaded
[19:21:36] + 348160 bytes downloaded
[19:21:36] + 358400 bytes downloaded
[19:21:36] + 368640 bytes downloaded
[19:21:36] + 378880 bytes downloaded
[19:21:36] + 389120 bytes downloaded
[19:21:36] + 399360 bytes downloaded
[19:21:36] + 409600 bytes downloaded
[19:21:36] + 419840 bytes downloaded
[19:21:36] + 430080 bytes downloaded
[19:21:36] + 440320 bytes downloaded
[19:21:36] + 450560 bytes downloaded
[19:21:36] + 460800 bytes downloaded
[19:21:36] + 471040 bytes downloaded
[19:21:36] + 481280 bytes downloaded
[19:21:36] + 491520 bytes downloaded
[19:21:36] + 501760 bytes downloaded
[19:21:36] + 512000 bytes downloaded
[19:21:36] + 522240 bytes downloaded
[19:21:36] + 532480 bytes downloaded
[19:21:36] + 542720 bytes downloaded
[19:21:36] + 552960 bytes downloaded
[19:21:36] + 563200 bytes downloaded
[19:21:36] + 573440 bytes downloaded
[19:21:36] + 583680 bytes downloaded
[19:21:36] + 593920 bytes downloaded
[19:21:36] + 604160 bytes downloaded
[19:21:36] + 614400 bytes downloaded
[19:21:36] + 624640 bytes downloaded
[19:21:36] + 634880 bytes downloaded
[19:21:36] + 645120 bytes downloaded
[19:21:36] + 655360 bytes downloaded
[19:21:36] + 665600 bytes downloaded
[19:21:36] + 675840 bytes downloaded
[19:21:36] + 686080 bytes downloaded
[19:21:36] + 696320 bytes downloaded
[19:21:36] + 706560 bytes downloaded
[19:21:36] + 716800 bytes downloaded
[19:21:36] + 727040 bytes downloaded
[19:21:36] + 737280 bytes downloaded
[19:21:36] + 747520 bytes downloaded
[19:21:36] + 757760 bytes downloaded
[19:21:36] + 768000 bytes downloaded
[19:21:36] + 778240 bytes downloaded
[19:21:36] + 788480 bytes downloaded
[19:21:36] + 798720 bytes downloaded
[19:21:36] + 808960 bytes downloaded
[19:21:36] + 819200 bytes downloaded
[19:21:36] + 825633 bytes downloaded
[19:21:36] Verifying core Core_78.fah...
[19:21:36] Signature is VALID
[19:21:36]
[19:21:36] Trying to unzip core FahCore_78.exe
[19:21:36] Decompressed FahCore_78.exe (2338816 bytes) successfully
[19:21:41] + Core successfully engaged
[19:21:46]
[19:21:46] + Processing work unit
[19:21:46] Core required: FahCore_78.exe
[19:21:46] Core found.
[19:21:46] Working on queue slot 01 [December 12 19:21:46 UTC]
[19:21:46] + Working ...
[19:21:46]
[19:21:46] *------------------------------*
[19:21:46] Folding@Home Gromacs Core
[19:21:46] Version 1.90 (March 8, 2006)
[19:21:46]
[19:21:46] Preparing to commence simulation
[19:21:46] - Looking at optimizations...
[19:21:46] - Created dyn
[19:21:46] - Files status OK
[19:21:46] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[19:21:46] - Starting from initial work packet
[19:21:46]
[19:21:46] Project: 2527 (Run 88, Clone 84, Gen 6)
[19:21:46]
[19:21:47] Assembly optimizations on if available.
[19:21:47] Entering M.D.
[19:21:53] Protein: p2527_Am22-43
[19:21:53]
[19:21:53] Writing local files
[19:21:53] Extra SSE boost OK.
[19:21:53] Completed 0 out of 2000000 steps (0%)
[19:23:52] Opening http://fah-web.stanford.edu/cgi-bin/...&teamnum=36362...
[19:25:48] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[19:26:58] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[19:32:25] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[19:35:09] Writing local files
[19:35:09] Completed 20000 out of 2000000 steps (1%)
[19:35:45] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[19:48:24] Writing local files
[19:48:24] Completed 40000 out of 2000000 steps (2%)
[19:51:27] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[20:01:43] Writing local files
[20:01:43] Completed 60000 out of 2000000 steps (3%)
[20:15:01] Writing local files
[20:15:01] Completed 80000 out of 2000000 steps (4%)
[20:28:18] Writing local files
[20:28:18] Completed 100000 out of 2000000 steps (5%)
[20:41:36] Writing local files
[20:41:36] Completed 120000 out of 2000000 steps (6%)
[20:54:53] Writing local files
[20:54:53] Completed 140000 out of 2000000 steps (7%)
[21:08:10] Writing local files
[21:08:10] Completed 160000 out of 2000000 steps (8%)
[21:21:27] Writing local files
[21:21:27] Completed 180000 out of 2000000 steps (9%)
[21:34:45] Writing local files
[21:34:45] Completed 200000 out of 2000000 steps (10%)
[21:41:06] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[21:41:40] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[21:48:00] Writing local files
[21:48:00] Completed 220000 out of 2000000 steps (11%)
[21:52:46] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[21:54:40] + Paused
[22:06:26] + Working ...
[22:06:26] Suspending work thread...
[22:06:26] Resuming work thread...
[22:13:03] Writing local files
[22:13:03] Completed 240000 out of 2000000 steps (12%)
--- Opening Log file [December 12 22:21:07 UTC]
[22:21:07] - Ask before connecting: No
[22:21:07] - User name: XRogerX (Team 36362)
[22:21:07] - User ID: 51E19A292C3F3E86
[22:21:07] - Machine ID: 1
[22:21:07]
[22:21:07] Loaded queue successfully.
[22:21:07] Initialization complete
[22:21:07]
[22:21:07] + Processing work unit
[22:21:07] Core required: FahCore_78.exe
[22:21:07] Core found.
[22:21:07] Working on queue slot 01 [December 12 22:21:07 UTC]
[22:21:07] + Working ...
[22:21:07]
[22:21:07] *------------------------------*
[22:21:07] Folding@Home Gromacs Core
[22:21:07] Version 1.90 (March 8, 2006)
[22:21:07]
[22:21:07] Preparing to commence simulation
[22:21:07] - Ensuring status. Please wait.
[22:21:24] - Looking at optimizations...
[22:21:24] - Working with standard loops on this execution.
[22:21:24] - Previous termination of core was improper.
[22:21:24] - Files status OK
[22:21:25] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[22:21:25]
[22:21:25] Project: 2527 (Run 88, Clone 84, Gen 6)
[22:21:25]
[22:21:25] Entering M.D.
[22:21:45] (Starting from checkpoint)
[22:21:45] Protein: p2527_Am22-43
[22:21:45]
[22:21:45] Writing local files
[22:21:45] Completed 240000 out of 2000000 steps (12%)
Folding@Home Client Shutdown.
--- Opening Log file [December 13 01:02:19 UTC]
[01:02:19] - Ask before connecting: No
[01:02:19] - User name: XRogerX (Team 36362)
[01:02:19] - User ID: 51E19A292C3F3E86
[01:02:19] - Machine ID: 1
[01:02:19]
[01:02:19] Loaded queue successfully.
[01:02:19] Initialization complete
[01:02:19]
[01:02:19] + Processing work unit
[01:02:19] Core required: FahCore_78.exe
[01:02:19] Core found.
[01:02:19] Working on queue slot 01 [December 13 01:02:19 UTC]
[01:02:19] + Working ...
[01:02:19]
[01:02:19] *------------------------------*
[01:02:19] Folding@Home Gromacs Core
[01:02:19] Version 1.90 (March 8, 2006)
[01:02:19]
[01:02:19] Preparing to commence simulation
[01:02:19] - Looking at optimizations...
[01:02:19] - Files status OK
[01:02:20] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[01:02:20]
[01:02:20] Project: 2527 (Run 88, Clone 84, Gen 6)
[01:02:20]
[01:02:20] Assembly optimizations on if available.
[01:02:20] Entering M.D.
--- Opening Log file [December 13 01:10:46 UTC]
[01:10:46] - Ask before connecting: No
[01:10:46] - User name: XRogerX (Team 36362)
[01:10:46] - User ID: 51E19A292C3F3E86
[01:10:46] - Machine ID: 1
[01:10:46]
[01:10:47] Loaded queue successfully.
[01:10:47] Initialization complete
[01:10:47]
[01:10:47] + Processing work unit
[01:10:47] Core required: FahCore_78.exe
[01:10:47] Core found.
[01:10:47] Working on queue slot 01 [December 13 01:10:47 UTC]
[01:10:47] + Working ...
[01:10:47]
[01:10:47] *------------------------------*
[01:10:47] Folding@Home Gromacs Core
[01:10:47] Version 1.90 (March 8, 2006)
[01:10:47]
[01:10:47] Preparing to commence simulation
[01:10:47] - Looking at optimizations...
[01:10:47] - Files status OK
[01:10:47] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[01:10:47]
[01:10:47] Project: 2527 (Run 88, Clone 84, Gen 6)
[01:10:47]
[01:10:47] Assembly optimizations on if available.
[01:10:47] Entering M.D.
[01:11:07] (Starting from checkpoint)
[01:11:07] Protein: p2527_Am22-43
[01:11:07]
[01:11:07] Writing local files
[01:11:07] Completed 245845 out of 2000000 steps (12%)
[01:11:07] Extra SSE boost OK.
[01:11:13] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
--- Opening Log file [December 13 01:20:23 UTC]
[01:20:23] - Ask before connecting: No
[01:20:23] - User name: XRogerX (Team 36362)
[01:20:23] - User ID: 51E19A292C3F3E86
[01:20:23] - Machine ID: 1
[01:20:23]
[01:20:23] Loaded queue successfully.
[01:20:23] Initialization complete
[01:20:23]
[01:20:23] + Processing work unit
[01:20:23] Core required: FahCore_78.exe
[01:20:23] Core found.
[01:20:23] Working on queue slot 01 [December 13 01:20:23 UTC]
[01:20:23] + Working ...
[01:20:23]
[01:20:23] *------------------------------*
[01:20:23] Folding@Home Gromacs Core
[01:20:23] Version 1.90 (March 8, 2006)
[01:20:23]
[01:20:23] Preparing to commence simulation
[01:20:23] - Ensuring status. Please wait.
[01:20:40] - Looking at optimizations...
[01:20:40] - Working with standard loops on this execution.
[01:20:40] - Previous termination of core was improper.
[01:20:40] - Files status OK
[01:20:41] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[01:20:41]
[01:20:41] Project: 2527 (Run 88, Clone 84, Gen 6)
[01:20:41]
[01:20:41] Entering M.D.
[01:21:01] (Starting from checkpoint)
[01:21:01] Protein: p2527_Am22-43
[01:21:01]
[01:21:01] Writing local files
[01:21:01] Completed 245845 out of 2000000 steps (12%)
[01:41:42] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[01:56:59] Writing local files
[01:56:59] Completed 260000 out of 2000000 steps (13%)
[02:48:36] Writing local files
[02:48:36] Completed 280000 out of 2000000 steps (14%)
[03:40:02] Writing local files
[03:40:02] Completed 300000 out of 2000000 steps (15%)
[04:31:37] Writing local files
[04:31:37] Completed 320000 out of 2000000 steps (16%)
[05:07:07] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[05:14:33] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[05:15:59] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[05:22:46] Writing local files
[05:22:46] Completed 340000 out of 2000000 steps (17%)
[06:14:13] Writing local files
[06:14:13] Completed 360000 out of 2000000 steps (18%)
[07:04:55] Writing local files
[07:04:55] Completed 380000 out of 2000000 steps (19%)
[07:20:23] + Working...
[07:56:12] Writing local files
[07:56:12] Completed 400000 out of 2000000 steps (20%)
[08:46:59] Writing local files
[08:46:59] Completed 420000 out of 2000000 steps (21%)
[09:37:29] Writing local files
[09:37:29] Completed 440000 out of 2000000 steps (22%)
[10:27:57] Writing local files
[10:27:57] Completed 460000 out of 2000000 steps (23%)
[11:18:16] Writing local files
[11:18:17] Completed 480000 out of 2000000 steps (24%)
[12:07:34] Writing local files
[12:07:34] Completed 500000 out of 2000000 steps (25%)
[12:57:09] Writing local files
[12:57:09] Completed 520000 out of 2000000 steps (26%)
[13:20:23] + Working...
[13:22:08] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[13:27:21] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[13:47:10] Writing local files
[13:47:10] Completed 540000 out of 2000000 steps (27%)
[14:38:09] Writing local files
[14:38:09] Completed 560000 out of 2000000 steps (28%)
[15:29:05] Writing local files
[15:29:05] Completed 580000 out of 2000000 steps (29%)
[16:20:09] Writing local files
[16:20:09] Completed 600000 out of 2000000 steps (30%)
[17:11:26] Writing local files
[17:11:26] Completed 620000 out of 2000000 steps (31%)
[18:02:39] Writing local files
[18:02:39] Completed 640000 out of 2000000 steps (32%)
[18:53:53] Writing local files
[18:53:53] Completed 660000 out of 2000000 steps (33%)
[19:20:23] + Working...
[19:45:01] Writing local files
[19:45:01] Completed 680000 out of 2000000 steps (34%)
[20:36:08] Writing local files
[20:36:08] Completed 700000 out of 2000000 steps (35%)
[20:36:22] + Paused
--- Opening Log file [December 13 21:05:45 UTC]
[21:05:45] - Ask before connecting: No
[21:05:45] - User name: XRogerX (Team 36362)
[21:05:45] - User ID: 51E19A292C3F3E86
[21:05:45] - Machine ID: 1
[21:05:45]
[21:05:45] Loaded queue successfully.
[21:05:45] Initialization complete
[21:05:45]
[21:05:45] + Processing work unit
[21:05:45] Core required: FahCore_78.exe
[21:05:45] Core found.
[21:05:45] Working on queue slot 01 [December 13 21:05:45 UTC]
[21:05:45] + Working ...
[21:05:45]
[21:05:45] *------------------------------*
[21:05:45] Folding@Home Gromacs Core
[21:05:45] Version 1.90 (March 8, 2006)
[21:05:45]
[21:05:45] Preparing to commence simulation
[21:05:45] - Looking at optimizations...
[21:05:45] - Files status OK
[21:05:46] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[21:05:46]
[21:05:46] Project: 2527 (Run 88, Clone 84, Gen 6)
[21:05:46]
[21:05:46] Assembly optimizations on if available.
[21:05:46] Entering M.D.
[21:06:06] (Starting from checkpoint)
[21:06:06] Protein: p2527_Am22-43
[21:06:06]
[21:06:06] Writing local files
[21:06:06] Completed 700000 out of 2000000 steps (35%)
[21:06:06] Extra SSE boost OK.
[21:20:03] Writing local files
[21:20:03] Completed 720000 out of 2000000 steps (36%)
[21:33:58] Writing local files
[21:33:58] Completed 740000 out of 2000000 steps (37%)
[21:45:00] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[21:47:55] Writing local files
[21:47:55] Completed 760000 out of 2000000 steps (38%)
[22:01:51] Writing local files
[22:01:51] Completed 780000 out of 2000000 steps (39%)
[22:15:46] Writing local files
[22:15:46] Completed 800000 out of 2000000 steps (40%)
[22:29:40] Writing local files
[22:29:40] Completed 820000 out of 2000000 steps (41%)
[22:43:33] Writing local files
[22:43:33] Completed 840000 out of 2000000 steps (42%)
[22:57:18] Writing local files
[22:57:18] Completed 860000 out of 2000000 steps (43%)
[23:11:01] Writing local files
[23:11:01] Completed 880000 out of 2000000 steps (44%)
[23:24:41] Writing local files
[23:24:41] Completed 900000 out of 2000000 steps (45%)
--- Opening Log file [December 13 23:43:58 UTC]
[23:43:58] - Ask before connecting: No
[23:43:58] - User name: XRogerX (Team 36362)
[23:43:58] - User ID: 51E19A292C3F3E86
[23:43:58] - Machine ID: 1
[23:43:58]
[23:43:58] Loaded queue successfully.
[23:43:58] Initialization complete
[23:43:58]
[23:43:58] + Processing work unit
[23:43:58] Core required: FahCore_78.exe
[23:43:58] Core found.
[23:43:58] Working on queue slot 01 [December 13 23:43:58 UTC]
[23:43:58] + Working ...
[23:43:58]
[23:43:58] *------------------------------*
[23:43:58] Folding@Home Gromacs Core
[23:43:58] Version 1.90 (March 8, 2006)
[23:43:58]
[23:43:58] Preparing to commence simulation
[23:43:58] - Ensuring status. Please wait.
[23:44:15] - Looking at optimizations...
[23:44:15] - Working with standard loops on this execution.
[23:44:15] - Previous termination of core was improper.
[23:44:15] - Files status OK
[23:44:15] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[23:44:15]
[23:44:15] Project: 2527 (Run 88, Clone 84, Gen 6)
[23:44:15]
[23:44:15] Entering M.D.
[23:44:35] (Starting from checkpoint)
[23:44:35] Protein: p2527_Am22-43
[23:44:35]
[23:44:35] Writing local files
[23:44:35] Completed 900000 out of 2000000 steps (45%)
[00:23:37] Writing local files
[00:23:37] Completed 920000 out of 2000000 steps (46%)
[01:02:41] Writing local files
[01:02:41] Completed 940000 out of 2000000 steps (47%)
--- Opening Log file [December 14 02:15:54 UTC]
[02:15:54] - Ask before connecting: No
[02:15:54] - User name: XRogerX (Team 36362)
[02:15:54] - User ID: 51E19A292C3F3E86
[02:15:54] - Machine ID: 1
[02:15:54]
[02:15:54] Loaded queue successfully.
[02:15:54] Initialization complete
[02:15:54]
[02:15:54] + Processing work unit
[02:15:54] Core required: FahCore_78.exe
[02:15:54] Core found.
[02:15:54] Working on queue slot 01 [December 14 02:15:54 UTC]
[02:15:54] + Working ...
[02:15:55]
[02:15:55] *------------------------------*
[02:15:55] Folding@Home Gromacs Core
[02:15:55] Version 1.90 (March 8, 2006)
[02:15:55]
[02:15:55] Preparing to commence simulation
[02:15:55] - Looking at optimizations...
[02:15:55] - Files status OK
[02:15:55] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[02:15:55]
[02:15:55] Project: 2527 (Run 88, Clone 84, Gen 6)
[02:15:55]
[02:15:55] Assembly optimizations on if available.
[02:15:55] Entering M.D.
[02:16:15] (Starting from checkpoint)
[02:16:15] Protein: p2527_Am22-43
[02:16:15]
[02:16:15] Writing local files
[02:16:15] Completed 946414 out of 2000000 steps (47%)
[02:16:15] Extra SSE boost OK.
[02:25:20] Writing local files
[02:25:20] Completed 960000 out of 2000000 steps (48%)
[02:38:42] Writing local files
[02:38:42] Completed 980000 out of 2000000 steps (49%)
[02:52:04] Writing local files
[02:52:04] Completed 1000000 out of 2000000 steps (50%)
[03:05:30] Writing local files
[03:05:30] Completed 1020000 out of 2000000 steps (51%)
[03:18:54] Writing local files
[03:18:54] Completed 1040000 out of 2000000 steps (52%)
[03:32:14] Writing local files
[03:32:14] Completed 1060000 out of 2000000 steps (53%)
[03:45:42] Writing local files
[03:45:42] Completed 1080000 out of 2000000 steps (54%)
[03:59:13] Writing local files
[03:59:13] Completed 1100000 out of 2000000 steps (55%)
[04:12:39] Writing local files
[04:12:39] Completed 1120000 out of 2000000 steps (56%)
[04:26:01] Writing local files
[04:26:01] Completed 1140000 out of 2000000 steps (57%)
[04:39:26] Writing local files
[04:39:26] Completed 1160000 out of 2000000 steps (58%)
[04:52:49] Writing local files
[04:52:49] Completed 1180000 out of 2000000 steps (59%)
[05:06:14] Writing local files
[05:06:14] Completed 1200000 out of 2000000 steps (60%)
[05:06:31] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[05:06:58] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[05:19:42] Writing local files
[05:19:42] Completed 1220000 out of 2000000 steps (61%)
[05:33:37] Writing local files
[05:33:37] Completed 1240000 out of 2000000 steps (62%)
[05:47:36] Writing local files
[05:47:36] Completed 1260000 out of 2000000 steps (63%)
[06:01:39] Writing local files
[06:01:39] Completed 1280000 out of 2000000 steps (64%)
[06:15:42] Writing local files
[06:15:42] Completed 1300000 out of 2000000 steps (65%)
[06:29:44] Writing local files
[06:29:44] Completed 1320000 out of 2000000 steps (66%)
[06:43:50] Writing local files
[06:43:50] Completed 1340000 out of 2000000 steps (67%)
[06:57:52] Writing local files
[06:57:52] Completed 1360000 out of 2000000 steps (68%)
[07:11:53] Writing local files
[07:11:53] Completed 1380000 out of 2000000 steps (69%)
[07:25:53] Writing local files
[07:25:53] Completed 1400000 out of 2000000 steps (70%)
[07:39:56] Writing local files
[07:39:56] Completed 1420000 out of 2000000 steps (71%)
[07:53:58] Writing local files
[07:53:58] Completed 1440000 out of 2000000 steps (72%)
[08:08:00] Writing local files
[08:08:00] Completed 1460000 out of 2000000 steps (73%)
--- Opening Log file [December 14 08:22:02 UTC]
[08:22:02] - Ask before connecting: No
[08:22:02] - User name: XRogerX (Team 36362)
[08:22:02] - User ID: 51E19A292C3F3E86
[08:22:02] - Machine ID: 1
[08:22:02]
[08:22:02] Loaded queue successfully.
[08:22:02] Initialization complete
[08:22:02]
[08:22:02] + Processing work unit
[08:22:02] Core required: FahCore_78.exe
[08:22:02] Core found.
[08:22:02] Working on queue slot 01 [December 14 08:22:02 UTC]
[08:22:02] + Working ...
[08:22:02]
[08:22:02] *------------------------------*
[08:22:02] Folding@Home Gromacs Core
[08:22:02] Version 1.90 (March 8, 2006)
[08:22:02]
[08:22:02] Preparing to commence simulation
[08:22:02] - Looking at optimizations...
[08:22:02] - Files status OK
[08:22:02] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[08:22:03]
[08:22:03] Project: 2527 (Run 88, Clone 84, Gen 6)
[08:22:03]
[08:22:03] Assembly optimizations on if available.
[08:22:03] Entering M.D.
[08:22:23] (Starting from checkpoint)
[08:22:23] Protein: p2527_Am22-43
[08:22:23]
[08:22:23] Writing local files
[08:22:23] Completed 1460000 out of 2000000 steps (73%)
[08:22:23] Extra SSE boost OK.
[08:35:48] Writing local files
[08:35:48] Completed 1480000 out of 2000000 steps (74%)
[08:49:28] Writing local files
[08:49:28] Completed 1500000 out of 2000000 steps (75%)
[09:03:08] Writing local files
[09:03:08] Completed 1520000 out of 2000000 steps (76%)
[09:16:47] Writing local files
[09:16:47] Completed 1540000 out of 2000000 steps (77%)
[09:30:34] Writing local files
[09:30:34] Completed 1560000 out of 2000000 steps (78%)
[09:40:54] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[09:41:23] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[09:42:14] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[09:44:16] Writing local files
[09:44:16] Completed 1580000 out of 2000000 steps (79%)
[09:57:59] Writing local files
[09:57:59] Completed 1600000 out of 2000000 steps (80%)
[10:11:35] Writing local files
[10:11:35] Completed 1620000 out of 2000000 steps (81%)
[10:25:12] Writing local files
[10:25:12] Completed 1640000 out of 2000000 steps (82%)
[10:38:44] Writing local files
[10:38:44] Completed 1660000 out of 2000000 steps (83%)
[10:52:12] Writing local files
[10:52:12] Completed 1680000 out of 2000000 steps (84%)
[10:54:34] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[10:54:50] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[11:05:48] Writing local files
[11:05:48] Completed 1700000 out of 2000000 steps (85%)
--- Opening Log file [December 14 11:12:25 UTC]
[11:12:25] - Ask before connecting: No
[11:12:25] - User name: XRogerX (Team 36362)
[11:12:25] - User ID: 51E19A292C3F3E86
[11:12:25] - Machine ID: 1
[11:12:25]
[11:12:25] Loaded queue successfully.
[11:12:26] Initialization complete
[11:12:26]
[11:12:26] + Processing work unit
[11:12:26] Core required: FahCore_78.exe
[11:12:26] Core found.
[11:12:26] Working on queue slot 01 [December 14 11:12:26 UTC]
[11:12:26] + Working ...
[11:12:26]
[11:12:26] *------------------------------*
[11:12:26] Folding@Home Gromacs Core
[11:12:26] Version 1.90 (March 8, 2006)
[11:12:26]
[11:12:26] Preparing to commence simulation
[11:12:26] - Ensuring status. Please wait.
[11:12:43] - Looking at optimizations...
[11:12:43] - Working with standard loops on this execution.
[11:12:43] - Previous termination of core was improper.
[11:12:43] - Going to use standard loops.
[11:12:43] - Files status OK
[11:12:43] - Expanded 238665 -> 1191289 (decompressed 499.1 percent)
[11:12:43]
[11:12:43] Project: 2527 (Run 88, Clone 84, Gen 6)
[11:12:43]
[11:12:43] Entering M.D.
[11:13:03] (Starting from checkpoint)
[11:13:03] Protein: p2527_Am22-43
[11:13:03]
[11:13:03] Writing local files
[11:13:03] Completed 1700000 out of 2000000 steps (85%)
[11:52:54] Writing local files
[11:52:54] Completed 1720000 out of 2000000 steps (86%)
[12:32:48] Writing local files
[12:32:48] Completed 1740000 out of 2000000 steps (87%)
[13:12:49] Writing local files
[13:12:49] Completed 1760000 out of 2000000 steps (88%)
[13:52:17] Writing local files
[13:52:17] Completed 1780000 out of 2000000 steps (89%)
[14:31:37] Writing local files
[14:31:37] Completed 1800000 out of 2000000 steps (90%)
[15:11:01] Writing local files
[15:11:01] Completed 1820000 out of 2000000 steps (91%)
[15:50:27] Writing local files
[15:50:27] Completed 1840000 out of 2000000 steps (92%)
[16:29:45] Writing local files
[16:29:45] Completed 1860000 out of 2000000 steps (93%)
[16:46:51] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[17:09:00] Writing local files
[17:09:00] Completed 1880000 out of 2000000 steps (94%)
[17:12:26] + Working...
[17:48:12] Writing local files
[17:48:12] Completed 1900000 out of 2000000 steps (95%)
[17:48:12] - Checksums don't match (work/wudata_01.xtc)
[17:48:13] Premature end of file when checksumming (54308 bytes left)
[17:48:13] - Could not calculate checksum (work/wudata_01.xtc)
[17:48:14] Checksum not what expected.
[17:48:14]
[17:48:14] Folding@home Core Shutdown: FILE_IO_ERROR
[17:48:18] CoreStatus = 75 (117)
[17:48:18] Error opening or reading from a file.
[17:48:18] Deleting current work unit & continuing...
[17:48:22] - Preparing to get new work unit...
[17:48:22] + Attempting to get work packet
[17:48:22] - Connecting to assignment server
[17:48:25] - Successful: assigned to (171.64.65.111).
[17:48:25] + News From Folding@Home: Welcome to Folding@Home
[17:48:25] Loaded queue successfully.
[17:48:25] - Couldn't send HTTP request to server
[17:48:25] (Got status 503)
[17:48:25] + Could not connect to Work Server
[17:48:25] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[17:48:43] + Attempting to get work packet
[17:48:43] - Connecting to assignment server
[17:48:46] - Successful: assigned to (171.64.65.111).
[17:48:46] + News From Folding@Home: Welcome to Folding@Home
[17:48:46] Loaded queue successfully.
[17:48:50] + Closed connections
[17:48:55]
[17:48:55] + Processing work unit
[17:48:55] Core required: FahCore_81.exe
[17:48:55] Core not found.
[17:48:55] - Core is not present or corrupted.
[17:48:55] - Attempting to download new core...
[17:48:55] + Downloading new core: FahCore_81.exe
[17:48:57] + 10240 bytes downloaded
[17:48:57] + 20480 bytes downloaded
[17:48:57] + 30720 bytes downloaded
[17:48:57] + 40960 bytes downloaded
[17:48:58] + 51200 bytes downloaded
[17:48:58] + 61440 bytes downloaded
[17:48:58] + 71680 bytes downloaded
[17:48:58] + 81920 bytes downloaded
[17:48:58] + 92160 bytes downloaded
[17:48:59] + 102400 bytes downloaded
[17:48:59] + 112640 bytes downloaded
[17:48:59] + 122880 bytes downloaded
[17:48:59] + 133120 bytes downloaded
[17:48:59] + 143360 bytes downloaded
[17:48:59] + 153600 bytes downloaded
[17:48:59] + 163840 bytes downloaded
[17:48:59] + 174080 bytes downloaded
[17:48:59] + 184320 bytes downloaded
[17:48:59] + 194560 bytes downloaded
[17:49:00] + 204800 bytes downloaded
[17:49:00] + 215040 bytes downloaded
[17:49:00] + 225280 bytes downloaded
[17:49:00] + 235520 bytes downloaded
[17:49:00] + 245760 bytes downloaded
[17:49:00] + 256000 bytes downloaded
[17:49:00] + 266240 bytes downloaded
[17:49:00] + 276480 bytes downloaded
[17:49:00] + 286720 bytes downloaded
[17:49:00] + 296960 bytes downloaded
[17:49:00] + 307200 bytes downloaded
[17:49:00] + 317440 bytes downloaded
[17:49:00] + 327680 bytes downloaded
[17:49:00] + 337920 bytes downloaded
[17:49:00] + 348160 bytes downloaded
[17:49:01] + 358400 bytes downloaded
[17:49:01] + 368640 bytes downloaded
[17:49:01] + 378880 bytes downloaded
[17:49:01] + 389120 bytes downloaded
[17:49:01] + 399360 bytes downloaded
[17:49:01] + 409600 bytes downloaded
[17:49:01] + 419840 bytes downloaded
[17:49:01] + 430080 bytes downloaded
[17:49:01] + 440320 bytes downloaded
[17:49:01] + 450560 bytes downloaded
[17:49:01] + 460800 bytes downloaded
[17:49:01] + 471040 bytes downloaded
[17:49:01] + 481280 bytes downloaded
[17:49:01] + 491520 bytes downloaded
[17:49:01] + 501760 bytes downloaded
[17:49:01] + 512000 bytes downloaded
[17:49:01] + 522240 bytes downloaded
[17:49:01] + 532480 bytes downloaded
[17:49:01] + 542720 bytes downloaded
[17:49:01] + 552960 bytes downloaded
[17:49:01] + 563200 bytes downloaded
[17:49:01] + 573440 bytes downloaded
[17:49:01] + 583680 bytes downloaded
[17:49:01] + 593920 bytes downloaded
[17:49:02] + 604160 bytes downloaded
[17:49:02] + 614400 bytes downloaded
[17:49:02] + 624640 bytes downloaded
[17:49:02] + 634880 bytes downloaded
[17:49:02] + 645120 bytes downloaded
[17:49:02] + 655360 bytes downloaded
[17:49:02] + 665600 bytes downloaded
[17:49:02] + 675840 bytes downloaded
[17:49:02] + 686080 bytes downloaded
[17:49:02] + 696320 bytes downloaded
[17:49:02] + 706560 bytes downloaded
[17:49:02] + 716800 bytes downloaded
[17:49:02] + 727040 bytes downloaded
[17:49:02] + 737280 bytes downloaded
[17:49:02] + 747520 bytes downloaded
[17:49:02] + 757760 bytes downloaded
[17:49:02] + 768000 bytes downloaded
[17:49:02] + 778240 bytes downloaded
[17:49:02] + 788480 bytes downloaded
[17:49:02] + 798720 bytes downloaded
[17:49:02] + 808960 bytes downloaded
[17:49:02] + 819200 bytes downloaded
[17:49:02] + 825684 bytes downloaded
[17:49:02] Verifying core Core_81.fah...
[17:49:02] Signature is VALID
[17:49:02]
[17:49:02] Trying to unzip core FahCore_81.exe
[17:49:02] Decompressed FahCore_81.exe (2396160 bytes) successfully
[17:49:07] + Core successfully engaged
[17:49:12]
[17:49:12] + Processing work unit
[17:49:12] Core required: FahCore_81.exe
[17:49:12] Core found.
[17:49:12] Working on queue slot 02 [December 14 17:49:12 UTC]
[17:49:12] + Working ...
[17:49:12]
[17:49:12] *------------------------------*
[17:49:12] Folding@Home Gromacs Simulated Tempering Core
[17:49:12] Version 1.10 (Oct 4, 2007)
[17:49:12]
[17:49:12] Preparing to commence simulation
[17:49:12] - Looking at optimizations...
[17:49:12] - Previous termination of core was improper.
[17:49:12] - Files status OK
[17:49:13] - Expanded 468011 -> 2292782 (decompressed 489.8 percent)
[17:49:13] - Starting from initial work packet
[17:49:13]
[17:49:13] Project: 4105 (Run 36, Clone 2, Gen 24)
[17:49:13]
[17:49:13] Entering M.D.
[17:49:19] Protein: p4105_villinwt_unf_Amber03_Extended
[17:49:19]
[17:49:19] Writing local files
[17:49:19] Completed 0 out of 1500000 steps (0%)
[17:58:05] Writing local files
[18:02:06] Completed 15000 out of 250000 steps (6%)
[18:13:15] Writing checkpoint files
[18:20:23] Writing local files
[18:20:23] Completed 17500 out of 250000 steps (7%)
[18:28:24] Writing checkpoint files
[18:38:38] Writing local files
[18:38:38] Completed 20000 out of 250000 steps (8%)
[18:43:34] Writing checkpoint files
[18:52:43] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[18:52:56] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[18:56:18] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[18:56:53] Writing local files
[18:56:53] Completed 22500 out of 250000 steps (9%)
[18:58:45] Writing checkpoint files
[19:02:01] Opening http://fah-web.stanford.edu/cgi-bin/...&teamnum=36362...
[19:13:53] Writing checkpoint files
[19:15:10] Writing local files
[19:15:10] Completed 25000 out of 250000 steps (10%)
[19:26:13] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[19:29:20] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[20:06:36] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[20:22:37] Opening http://fah-web.stanford.edu/cgi-bin/...&teamnum=36362...
[20:22:48] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[21:05:37] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[21:05:46] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[21:49:23] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[23:12:26] + Working...
--- Opening Log file [December 15 07:50:38 UTC]
[07:50:38] - Ask before connecting: No
[07:50:38] - User name: XRogerX (Team 36362)
[07:50:38] - User ID: 51E19A292C3F3E86
[07:50:38] - Machine ID: 1
[07:50:38]
[07:50:38] Loaded queue successfully.
[07:50:38] Initialization complete
[07:50:38]
[07:50:38] + Processing work unit
[07:50:38] Core required: FahCore_82.exe
[07:50:38] Core not found.
[07:50:38] - Core is not present or corrupted.
[07:50:38] - Attempting to download new core...
[07:50:38] + Downloading new core: FahCore_82.exe
[07:50:40] + 10240 bytes downloaded
[07:50:40] + 20480 bytes downloaded
[07:50:40] + 30720 bytes downloaded
[07:50:40] + 40960 bytes downloaded
[07:50:40] + 51200 bytes downloaded
[07:50:40] + 61440 bytes downloaded
[07:50:40] + 71680 bytes downloaded
[07:50:40] + 81920 bytes downloaded
[07:50:40] + 92160 bytes downloaded
[07:50:40] + 102400 bytes downloaded
[07:50:40] + 112640 bytes downloaded
[07:50:40] + 122880 bytes downloaded
[07:50:40] + 133120 bytes downloaded
[07:50:41] + 143360 bytes downloaded
[07:50:41] + 153600 bytes downloaded
[07:50:41] + 163840 bytes downloaded
[07:50:41] + 174080 bytes downloaded
[07:50:41] + 184320 bytes downloaded
[07:50:41] + 194560 bytes downloaded
[07:50:41] + 204800 bytes downloaded
[07:50:41] + 215040 bytes downloaded
[07:50:41] + 225280 bytes downloaded
[07:50:41] + 235520 bytes downloaded
[07:50:41] + 245760 bytes downloaded
[07:50:41] + 256000 bytes downloaded
[07:50:41] + 266240 bytes downloaded
[07:50:41] + 276480 bytes downloaded
[07:50:41] + 286720 bytes downloaded
[07:50:41] + 296960 bytes downloaded
[07:50:41] + 307200 bytes downloaded
[07:50:41] + 317440 bytes downloaded
[07:50:41] + 327680 bytes downloaded
[07:50:41] + 337920 bytes downloaded
[07:50:41] + 348160 bytes downloaded
[07:50:41] + 358400 bytes downloaded
[07:50:41] + 368640 bytes downloaded
[07:50:41] + 378880 bytes downloaded
[07:50:41] + 389120 bytes downloaded
[07:50:41] + 399360 bytes downloaded
[07:50:41] + 409600 bytes downloaded
[07:50:41] + 419840 bytes downloaded
[07:50:41] + 430080 bytes downloaded
[07:50:41] + 440320 bytes downloaded
[07:50:41] + 450560 bytes downloaded
[07:50:41] + 460800 bytes downloaded
[07:50:41] + 471040 bytes downloaded
[07:50:41] + 481280 bytes downloaded
[07:50:41] + 491520 bytes downloaded
[07:50:41] + 501760 bytes downloaded
[07:50:41] + 512000 bytes downloaded
[07:50:41] + 522240 bytes downloaded
[07:50:41] + 532480 bytes downloaded
[07:50:41] + 542720 bytes downloaded
[07:50:41] + 552960 bytes downloaded
[07:50:41] + 563200 bytes downloaded
[07:50:41] + 573440 bytes downloaded
[07:50:41] + 583680 bytes downloaded
[07:50:41] + 593920 bytes downloaded
[07:50:41] + 604160 bytes downloaded
[07:50:41] + 614400 bytes downloaded
[07:50:41] + 624640 bytes downloaded
[07:50:41] + 634880 bytes downloaded
[07:50:41] + 645120 bytes downloaded
[07:50:41] + 655360 bytes downloaded
[07:50:41] + 665600 bytes downloaded
[07:50:41] + 675840 bytes downloaded
[07:50:41] + 686080 bytes downloaded
[07:50:41] + 696320 bytes downloaded
[07:50:41] + 706560 bytes downloaded
[07:50:41] + 716479 bytes downloaded
[07:50:41] Verifying core Core_82.fah...
[07:50:41] Signature is VALID
[07:50:41]
[07:50:41] Trying to unzip core FahCore_82.exe
[07:50:41] Decompressed FahCore_82.exe (1683456 bytes) successfully
[07:50:46] + Core successfully engaged
[07:50:52]
[07:50:52] + Processing work unit
[07:50:52] Core required: FahCore_82.exe
[07:50:52] Core found.
[07:50:52] Working on queue slot 03 [December 15 07:50:52 UTC]
[07:50:52] + Working ...
[07:50:52]
[07:50:52] *------------------------------*
[07:50:52] Folding@Home PMD Core
[07:50:52] Version 1.03 (September 7, 2005)
[07:50:52]
[07:50:52] Preparing to commence simulation
[07:50:52] - Looking at optimizations...
[07:50:52] - Files status OK
[07:50:52] - Expanded 600981 -> 4231059 (decompressed 704.0 percent)
[07:50:52]
[07:50:52] Project: 897 (Run 2, Clone 347, Gen 6)
[07:50:52]
[07:50:52] Assembly optimizations on if available.
[07:50:52] Entering M.D.
[07:50:59] Protein: p897_NIFKcomplex_p897
[07:50:59]
[07:50:59] Completed 0 out of 250000 steps (0%)
[08:05:54] Writing checkpoint files
[08:11:56] Writing local files
[08:11:56] Completed 2500 out of 250000 steps (1%)
[08:21:00] Writing checkpoint files
[08:32:55] Writing local files
[08:32:55] Completed 5000 out of 250000 steps (2%)
[08:36:04] Writing checkpoint files
[08:51:09] Writing checkpoint files
[08:53:53] Writing local files
[08:53:53] Completed 7500 out of 250000 steps (3%)
[09:06:17] Writing checkpoint files
[09:14:54] Writing local files
[09:14:54] Completed 10000 out of 250000 steps (4%)
[09:21:30] Writing checkpoint files
[09:36:08] Writing local files
[09:36:08] Completed 12500 out of 250000 steps (5%)
[09:36:33] Writing checkpoint files
[09:45:29] Opening C:\Documents and Settings\Roger\Application Data\Folding@home-x86\MyFolding.html...
[09:51:39] Writing checkpoint files
[09:57:18] Writing local files
[09:57:18] Completed 15000 out of 250000 steps (6%)
[10:06:40] Writing checkpoint files
[10:18:39] Writing local files
[10:18:39] Completed 17500 out of 250000 steps (7%)
[10:21:51] Writing checkpoint files
[10:36:52] Writing checkpoint files
[10:40:05] Writing local files
[10:40:05] Completed 20000 out of 250000 steps (8%)
--- Opening Log file [December 15 14:44:27 UTC]
[14:44:27] - Ask before connecting: No
[14:44:27] - User name: XRogerX (Team 36362)
[14:44:27] - User ID: 51E19A292C3F3E86
[14:44:27] - Machine ID: 1
[14:44:27]
[14:44:27] Loaded queue successfully.
[14:44:27] Initialization complete
[14:44:27]
[14:44:27] + Processing work unit
[14:44:27] Core required: FahCore_82.exe
[14:44:27] Core found.
[14:44:27] Working on queue slot 03 [December 15 14:44:27 UTC]
[14:44:27] + Working ...
[14:44:28]
[14:44:28] *------------------------------*
[14:44:28] Folding@Home PMD Core
[14:44:28] Version 1.03 (September 7, 2005)
[14:44:28]
[14:44:28] Preparing to commence simulation
[14:44:28] - Ensuring status. Please wait.
[14:44:45] - Looking at optimizations...
[14:44:45] - Working with standard loops on this execution.
[14:44:45] - Previous termination of core was improper.
[14:44:45] - Files status OK
[14:44:45] - Expanded 600981 -> 4231059 (decompressed 704.0 percent)
[14:44:45]
[14:44:45] Project: 897 (Run 2, Clone 347, Gen 6)
[14:44:45]
[14:44:45] Entering M.D.
[14:44:52] Protein: p897_NIFKcomplex_p897
[14:44:52]
[14:44:52] Completed 19625 out of 250000 steps (7%)
[14:47:35] Writing local files
[14:47:35] Completed 20000 out of 250000 steps (8%)
[14:59:46] Writing checkpoint files
[15:04:16] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[15:05:47] Writing local files
[15:05:47] Completed 22500 out of 250000 steps (9%)
[15:14:53] Writing checkpoint files
[15:24:01] Writing local files
[15:24:01] Completed 25000 out of 250000 steps (10%)
[15:30:02] Writing checkpoint files
[15:42:16] Writing local files
[15:42:16] Completed 27500 out of 250000 steps (11%)
[15:45:11] Writing checkpoint files
[16:00:17] Writing checkpoint files
[16:00:28] Writing local files
[16:00:28] Completed 30000 out of 250000 steps (12%)
--- Opening Log file [December 15 17:44:50 UTC]
[17:44:50] - Ask before connecting: No
[17:44:50] - User name: XRogerX (Team 36362)
[17:44:50] - User ID: 51E19A292C3F3E86
[17:44:50] - Machine ID: 1
[17:44:50]
[17:44:50] Loaded queue successfully.
[17:44:50] Initialization complete
[17:44:50]
[17:44:50] + Processing work unit
[17:44:50] Core required: FahCore_82.exe
[17:44:50] Core found.
[17:44:50] Working on queue slot 03 [December 15 17:44:50 UTC]
[17:44:50] + Working ...
[17:44:50]
[17:44:50] *------------------------------*
[17:44:50] Folding@Home PMD Core
[17:44:50] Version 1.03 (September 7, 2005)
[17:44:50]
[17:44:50] Preparing to commence simulation
[17:44:50] - Ensuring status. Please wait.
[17:45:07] - Looking at optimizations...
[17:45:07] - Working with standard loops on this execution.
[17:45:07] - Previous termination of core was improper.
[17:45:07] - Going to use standard loops.
[17:45:07] - Files status OK
[17:45:07] - Expanded 600981 -> 4231059 (decompressed 704.0 percent)
[17:45:07]
[17:45:07] Project: 897 (Run 2, Clone 347, Gen 6)
[17:45:07]
[17:45:07] Entering M.D.
[17:45:14] Protein: p897_NIFKcomplex_p897
[17:45:14]
[17:45:14] Completed 29975 out of 250000 steps (11%)
[17:45:25] Opening http://fah-web.stanford.edu/cgi-bin/...ername=XRogerX...
[17:45:27] Writing local files
[17:45:27] Completed 30000 out of 250000 steps (12%)
New to folding, got the GPU running but have not joined a team.
How can i join the XS team?
My OS is Vista 64bit, what SMP client can be used?
Also can the GPU and SMP run at the same time?
Thanks,
