Originally Posted by
kazgirl
I think that the M3A79-T doesn't include the little clip on fan in the box.
These little fans have been included with the M2N32-SLI, and the M3A32-MVP mobo's both of which I have..... and they are mainly meant to be used when using watercooling, to supplement airflow that is normally provided by the CPU fan.
I'm not sure why they decided not to provide them with the M3A79-T though... but I have kept the ones I had with the M2N32-SLI, including a DOA M2N32-SLI I bought, and so had some spare...
So I just used the one from my M3A32-MVP mobo on the M3A79-T, and then used the spare one from the DOA M2N32-SLI, for the M3A32-MVP.
Though I did notice that it was a really tight fit to get the M2N32-SLI fan onto the HSF for the M3A32-MVP, and it actually bent a couple of the copper fins.. but nothing major...!!!!
