Nautilus 500 is a fine WC setup
Originally Posted by
gwolfman
I'm running the Corsair Nautilus 500, which I understand it to not being a very good water cooler, only decent, but pretty good compared to air coolers. I'll try checking my temps again with the programs I see you running in the screenshot. :)
That statement is just not true. I have a Q6600 OC'd to 3 GHz
My temps were 54-55 on load Prime 95.
I modded the radiator and put in a Danger Den Black Ice Pro and it dropped load temps t0 44-48.
The Nautilus has some benefits:
1) no mess
2) reliable
3) decent WC (not extreme) but for $150 bucks its not bad.
Plus its moddable.
:up:
p5wdh deluxe and q6600 go stepping
here is the details of the overclock shown if i use 400fsb it reboots when its about to load the applications in windows i tried upping vcore but it dont help any ideas.
http://img.photobucket.com/albums/v2...untitled-1.jpg
settings used in bios
390x9
DDr2 at 780mhz memory is dominator 800mhz micron chips at 4-4-4-12
memory voltage 2.10v
cpu voltage 1.4750v
fsb 1.50v
mch 1.65v
ich 1.20v
hope this helps others reach a decent overclock on q6600
