Yep, I can do, but testing atm. will try in a few hours when I'm back for lunch, and assuming prime has failed, otherwise i'll do it tonight :)
I can confirm that 105MHz PCI-E results in no POST whereas 104 works fine. Tried 110 too but no joy.
am just wondering if 101 will brimg stability on the board like you said on high fsbs am a bit scared though last time i try 110 on the pci-e fried the board and took out the card with it :mad: my 8600 gts lol but ill try 101 see any differences on the results am backing up my data which ill be a couple of day cos am raiding 0 on 2 Tb and one of them is failing and making everything dead slow so before ill lose it all am trasnfering it and am gonna use the normal HD use i dont particular think that intel raid is any good to be honest :shakes: anyway it says its gonna take 2 days to move it all :ROTF: so hopefully it doesnt crash on the way :D
I'm not certain it will. I think most people do it because it gives them a teensy bit more GFX speed (correct me if I'm wrong).
Fair enough, I stand corrected :)
Got 462x8 stable with memory at 1155:
http://i194.photobucket.com/albums/z...tableP5Q-D.jpg
Finally beat my P5B-D overclock by 6MHz! Might try to see what I can get with 1.5v as temps are still about 5°C under threshold, and it's getting cooler outside by the day.
Nice!
What are your voltages/settings?
I've gotten ~ 465 stable in the past, but with higher FSB/NB voltages than i'd like.
I'm presently getting stuck @ 456-458.
Seems increasing the vFSB or vNB by a small amount isn't working for me to get higher. :(
Gonna likely have to mess with skews & much higher vFSB/vNB.
CPU Voltage: 1.25625
CPU GTL Voltage Reference (0/2): 0.645
CPU GTL Voltage Reference (1/3): 0.645
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.26
DRAM Voltage: 1.8
NB Voltage: 1.26
NB GTL Reference: 0.64
PCIE Voltage: 1.5
SATA Voltage: 1.1
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
http://ense7en.com/pics/q9650/Q9650%...0%20passes.jpg
I'll post my settings here once I've finished another test. One thing that was key for me was the clock skews which I have at normal/300, but I suggest you use trial and error to find your best ones. On both boards I found that delaying the NB more gave me better stability at higher fsb.
On what test does it fail? Large FFTs? If so, I would recommend higher NB volts as it's a bit low imo. Mine is at 1.4 with GTL at 0.62
So yeah...gotta love how it's 8 GB LinX "stable", but it locked up P95 Large two lines in.
Yes, Large FFTs are giving me teh lockups.
It's NB-related, no doubt, though i will also have to drop down from 4:5 to 5:6 to go much higher.
Back when i had my Q9550 & initially got my Q9650, i had 465 stable, but was using 1.36 vNB/1.34 vFSB or higher, & i was hoping to keep those lower this time around.
I also was using -100 CPU skew & -200 NB skew.
It seems i'm going to have to bust out using my old higher voltage settings, & see if they work.
Upping to 1.28 vNB caused the lockup to be delayed till about 8 lines in.
I
Try Large FFT settings in custom with run ffts in place unchecked and all of your available ram enabled, now thats rough. Actually made me either BSOD or just lock up fast while I was HCI Memtest, IBT, blend, and small fft stable. Long runs, too.
Just ordered a P5Q Premium from Newegg. Been itching for a new board for over a year. I plan to use it on a watercooled E8500 and EVGA8800GT and GSkill Trident 2x2Gb DDR2 1200. My original plan was to use this board as a server because it had so many SATA and USB ports with my Q6600 and Corsair Dominator 4x1Gb 1066. But I think it's going to replace my Maximus Formula, I mean Rampage Formula ;), for my main/gaming machine. Just posting because I was wondering if anyone with a similar setup could tell me some speeds to expect.
ok guys this post is not related but just wondering if you know the problem every time i try to unrar a archive that like more than 20 gb my ram will go crazy and run out dry and when i stop it it will stay used but if i cancel it it will go back done as normal..?? am using vista 64 bit and it just randomly started happening do you guys know whats causes it? it must be something i enabled by accident right?? LOL
Never mind guys i installed Services Pack 2 for vista and it seem to fix the problem am also try to get my windows media player 11 to run on 64bits like its suppose to but it wont ? LOL.... welcome to the wonders of microsoft
Anyone help me, why i don't get over 4.6ghz my e8600 with P5Q-e? I test about this settings, but orthos stopped in 10-20seconds. 4.4ghz orthos running over 8hours perfectly (vcore. 1.39v) Little bit bigger vcore is not problem because prosessor cooled with water.
CPU setting
CPU ratio: 10
C1E support: disabled
Max cpuid value limit: disabled
Intel virtualization tech: disabled
CPU tm function: disabled
execute disable bit: disabled
(if something missing all settings are disabled in cpu settings page in bios
FSB: 460
DDR: 920
memory manual
5
5
5
15
CPU voltage 1.4-1.58v
CPU PLL: 1.5-1.6
FSB termination: 1.18-1.22
DRAM: 2.1v (default voltages g.skill 1066 5-5-5-15 kit)
nb voltage: 1.2-1.34
sbridge: 1.1-1.2v
pcie voltage: 1.5v
load line calibration: disabled
CPU spread spectrum disabled
PCIe spread spectrum disabled
I am very thankfull if somebody can help me with this problem. Prosessor batch is unknown, because prosessor is sanded on copper, revision are E0 if cpu-z talks right :)
even on water you can't make it, I have hardly seen a watercooled CPU do 4.6Ghz Prime or Orthos... you need better cooling for that ! Water ain't gonna cut it...
@LassiVV
I assume you've tried enabling load line calibration to see if that makes a difference? What are your temps like? 4.4GHz isnt bad at all, but you'll be lucky to push a lot further. Only other things I can think of are CPU/NB Skews which had quite an effect on my o/c at ~460fsb. Try delaying the NB 100-300ps, test each one and see if that helps.
For the record I'm now testing at 462x8, but with the 400MHz divider, giving me ~1230 mem speed (with PL8). Memtest stable overnight, and 5 hours into blending - looking good! :D
I only got about 100MB/s bandwidth gain over the 266 divider (or 333, can't remember) and mem at 1158. Will try for strong/stronger too, but I feel the limit is nigh :)
OMG Guys it still going on when ever i extract a Rar file bigger than 4 gig it will eat all my bloody memory i dont know why is happening and is really annoying cos it runs out of RAM and the system becames realllylylylyyy slow!!
Sounds like a software problem to me, try google or other archive software - 7-zip is good.
Also check your filesystem isn't set to FAT32.
All my HDD are NTFS lol and i also use 7 zip but it doesnt unrar files that arenot .7zip very well.... it weird cos i try loads of different edition on winrar and it only does that when i use vista 64b ??
He'd better get 4.5 stable with 500 FSB then trying to do 10 x 460FSB with far lesser bandwith... Prolly more FSB term volts are required, 1.22 for 4.6 ain't gonna cut it... but like l I said, I have rarely seen prime shots of an E8600 at +4.5Ghz under air or water...
Davidkozat try another OS mate and see what happens...
Almighty Leeghoofd i really not happy changing my OS as i like vista 64 a lot and am just wondering if there were something i could dude to fix this problem thats all....
Most of us think it's software related... hence why it would be good if you could try another copy... how much free space do you have on the C drive ? Or on the partition where you are unrarring ?
And check your virtual memory settings. Perhaps add a paging file of unlimitied size to another drive?
Strangeness.
I moved recently, & as room temps at this basement are significantly cooler than my previous place, i've been working on the OC again.
More 8 GB action @ as low as i can keep the mobo voltages:
CPU Voltage: 1.26875
DRAM Voltage: 1.8
NB Voltage: 1.28
PCIE Voltage: 1.5
SATA Voltage: 1.1
CPU Clock Skew : -100
NB Clock Skew : -200
Small FFTs
http://ense7en.com/pics/q9650/Q9650%...%203%20hrs.jpg
HCI (was running P95 at the same time but it basically didn't go anywhere)...
http://ense7en.com/pics/q9650/Q9650%...0%20350%25.jpg
Presently working on Large/blend.
LinX is an evil mother w/ 8 GB.
Temps are ridiculous compared to P95, & i need to use two full vcore notches higher just to get things almost stable.
It did 12 passes before deciding to lock up system (likely needs more vNB), & honestly considering how insane the stressing it does is compared to real world, i don't think i care...
