The software that comes with it looks pretty sweet, not sure about performance though theres a post about it somewhere.
Bugger!! didnt even know that the Block has to be a certain way :eek:. Will Change that tom.
The temps are not too bad (i think), 38c idle and 52c load. My E6600 is overclocked to 3.6ghz needing 1.5125v and havent oced 8800gtx yet.
Cant get it to be stable with orthos yet, but will play crysis with no probs, albeit stuttery at times.
By the way, silly qu ahoy- do i need to turn cpu block upside down or do i need to switch tubes round?
Sorry if im not making much sense, very new to all this.
cheers for pointing that guys:up:
by the way, what are the implications of having the tubes the wrong way round? just curious
Nice rigs guys.
will keep you guys updated on if there is any differences in temps after I switch the tubes round.
have to stop typing now coz wife is trying to sleep and apparently I tap keys very loudly! speak to u guys tom!
http://www.sharkacomputers.com/aqcoaqmoeh10.html
Never mind, google is my friend
Edit: 7ft max head? Am I figuring this right?
No problem. :D here are some more pics. :D
http://i54.photobucket.com/albums/g1...ledresized.jpg
http://i54.photobucket.com/albums/g1...r/outside2.jpg
http://i54.photobucket.com/albums/g1...de3resized.jpg
http://i54.photobucket.com/albums/g1...er/Closeup.jpg
http://i54.photobucket.com/albums/g1...r/inaction.jpg
looks sik!!!! is that just distilled water no coolant??
Looks nice like that i think i may just use distilled water aswell and let the uv neon's light it up :)
when you upgrade our gfx card take out the fan side bracket thing and wc the gfx card aswell
There are also clear coolants available. Here in germany one of the best, without making the tube looking cloudy. It is called Innovatek Protect.
Available as a concentrate to mix with distilled water, or also ready mixed.
I hope to have my 343b ready soon. :( I need more space for my 2 loops. They won´t fit in my old built :(
http://www.lifepatcher.com/pc/test/sys/testsys1.jpg
Yup! Pure distilled H20. :D As for the Gfx card, I'm fine cooling it with air. for easy maintenance. hehehe
But i think I'll keep the bottom 2 fans on the side panel to keep cool components .
Hi Stormshadow, just finished retubing the cpu block and looks like this now
Decided to turn cpu block upside down to keep the tubing running in the same pattern.
Temps have not changed at all, still 38c idle and 52c load but have not let as5 run in yet, so temp might change still.
By the way, i think i was looking at some of your previous rigs for inspiration towards this, had one pic saved on my last HD. Thanx for that :up:
@fireice2: why not use the coolant?
peebee looking good man!! could u post your worklog here @ xs aswell please
@emoners
I was thinking of adding a Fesser UV Black Dye. :D
But that would be for the next lanparty. hehehe We have monthly lanparties in my place so having a fancy coolant would be nice.
But for daily usage, I still prefer pure H20. :D
@cyber & sparky
Thanks guys! :D
Really have to thank the water-cooling veterans for keeping me away from pre-built kits and also for the ideas on how to setup my loop. :D
I also realized that my two favorite colors are really blue and purple. mwehehehe
