i have F12 on my GA-EP45-UD3R with my E8500 OC'ed to 4GHZ with 9.5x422 and 1.3000 Vcore
I wonder if the EP45T-UD3P is ever going to get a BIOS update :/
what's the difference between rev.1.0 and rev 1.1 for EP45T-UD3P?
Thanks vailr and dustin! F12 I go!
can i get f10j bios from someone? I cant seem to find it anywhere
F10j, which mobo?
Thanks Stasio i have the CD that came with the giga but happened the same when i first installed worked fine then after some days i got an error and closes...i re installed and same .... also hoss31 sent me that same version but as i told you its not working i installed that one you have
Cheers and thanks :up:
Thanks Hoss for sending :up:
OK,bro.
Btw,BIOS F10j I found on JZelectronic (01.Dec 09).
thank you guys
I wonder if the EP45-UD3P (1.0, 1.1) BIOS will ever come out of f10.f beta and finally become a full release.
Just bought a Q9450 this afternoon for $150, and sold my Q6600 for $120 this evening. It's a modest, but nonetheless noticeable boost, and I'm happy to be using less power. :)
So they are actually continuing work on F10, then? Good to know, since 10f is the most recent on the US site, and that's dated August of `09. :(
Latest for UD3P is BIOS F10k. :yepp:
-new feature "Quick Boot"
-released on 13.Jan 2010
GA-EP45-UD3P rev 1.0/1.1
F10k:
http://www.station-drivers.com/page/...-ep45-ud3p.htm
wasnt F10K kinda buggy reported ???
GIGABYTE
EasyTune 6
utilitaire
B10.0130.1
http://www.gigabyte.com.tw/Support/M...lity&FileID=86
you know what, i was so busy using 475fsb 24/7 i never attempted to go higher.
480x7 = 1024k orthos passed
485x7 = 1024k orthos passed
490x7 = locked up 1 minute 55 seconds into orthos blend
still 1.3 vtt 1.24 mch 2.2 vdimm
it was an unusually cold day so my 24/7 setting remains 475x7
Could anyone offer some advice on o/cing an E5200 on a UD3L? I used to have this thing @ 3.33GHz on stock cooling with a slight Vcore bump on an EP35-DS3L, but that board had a failed BIOS flash and I replaced it with this board. I've tried the stock multi and 9.5x.
Edit: spoke too soon. 12.5x272 (3.4GHz) @ 1.275V works, no other voltages adjusted.
this is my new 24/7 setting, passed 1 and a half hours orthos before i got impatient and stopped it.
http://b.imagehost.org/0662/24_7_setting.jpg
485 fsb also passes 1024k orthos but im sticking to 480 fsb for guaranteed stability in games. besides cant complain about 10k write and copy :D
490 fsb locks up after a couple minutes orthos blend but thats to be expected
GA-EP45-UD3P rev 1.0/1.1 - Bios F10 (Final)
finally F10 final version, will update in a few :D
heh guys whats the current best DDR2 kits you can buy for overclocking. I was just checking out Newegg and there seems to be alot of new kits I have never seen before, and some of the other ones I thought were real good are no longer there.
My OCZ Plat LV RAM needed to be RMAd and now they are sending me regular Platinum :(
