500 watts is plenty as long as the PSU is solidly built.
new bios is around the corner but don't hold your breath about setting vcore in the bios or uguru and then getting the same vcore in windows at idle...ain't going to happen...you need to just move on and enjoy the board, which is a SOLID board!
im using beta 16.b10 bios and my vdrop is not bad at all no more :) 1.45v in bios idles 1.45 and load is 1.4v :)
still need to take off the heatpipes and repaste them and maybe do the mod for them to get tighten down better not sure yet :P
http://img156.imageshack.us/img156/3796/26839342sj7.jpg
Geatings all...after 192 pages, I'm now thoroughly confused. But I'm excited to ask stupid questions and dazzle you all with my ignorance.
Chuckster, your system seems to be closest to mine.
My Ballistix are the new 2x2Gb double sided (8 modules a side) without clips and yellow (not the new red ones).
My system was just put together and I haven't had the time (or knowledge) to OC yet.:p:
A Work In Progress
Abit IP-35 PRO
E8400 (just built)
Zalmann 9500
(2x2GB) Crucial Ballistix 6400 CL4
XFX 8600 GT@ 680 Mhz
Corsair VX550 80Plus
WD 500GB SATA3
Antec 900 w/
(4)12cm (1)20cm
I am still a noob at oc'ing and this is my first real try. Just do lots of reading and go in baby steps. I first oc'ed this system to 400x9 at 1.25 volts v core and a small increase on the mch. 3600 seems pretty easy for most cores to reach so read up and ask all the questions you want!
Does anyone know if the ip35 pro has a TPM chip on it? Been thinking about playing around with bitlocker. I haven't been able to find a solid answer anywhere. Do enthusiast mobos for desktop PCs typically have TPM chips, or are they reserved for more of the enterprise/business class?
Abit still has not fixed the following bios error (running v. 16 b10):
When attempting to boot from a SATA DVD-RW drive connected to either Intel or JMicron SATA port, bootable optical discs cannot boot when the Intel Raid/IDE/AHCI bios selector is set in Raid mode. Switch back to IDE mode, and the optical disc becomes bootable again.
Anyone else encountered this? I ran into this, when the board was newly released about 9 months ago. A workaround solution is: use the set of (6) WinXP SP2 bootable floppies, in order to install onto a Raid 0 pair of hard drives. My old Gigabyte 865-DS3 board didn't have this "boot from SATA DVD-RW drive while bios is set to Raid" problem.
Anyone managed to snag a Q9450 or 9550 and dropped it into an IP35 pro yet?
Unless I am mistaken, SATA ports 5&6 are under control of the JMicron controller chip (which I do not use and normally have disabled). I've already tried enabling the JMicron controller (in IDE mode) and seeing whether the SATA DVD-RW would boot from port 5, which didn't work either.
Ok, you're correct. The JMicron is used for the 40-pin IDE connector and for eSATA. However, the SATA DVD-RW still won't boot from any of the 6 Intel (internal) SATA ports, when the bios is set to Raid mode. I'd like confirmation that anyone else is running into the same problem. Or if using an older IDE DVD-RW on the IDE port would allow booting from an optical disc, while the bios is set to Raid mode?
i would not have told you to use sata ports 5 & 6 if i were not using them myself...have you made sure that you have selected the dvd drive "BY NAME" in the bios when Raid is set for the intel chipset...when you change from IDE to Raid, the sata dvd drive then shows up by name further down on the list...go into your bios to check.
The relevant bios (version 16.b10) settings are:
under "Standard CMOS Features":
SATA Channel 1.............None
SATA Channel 3.............None
SATA Channel 2.............None
SATA Channel 4.............None
???(no indication for SATA 5 & 6)
Note: the cursor jumps directly from "Time" to "Drive A", skipping over all of the SATA Channels.
Isn't the cursor supposed to stop on each of the SATA Channels also?
under "Advanced Bios Features":
First Boot Device.........Floppy
Second Boot Device.....SATA CDROM
Third Boot Device........Hard Disk
Boot Other Device.......Enabled
Quick Power On Self Test....Enabled
under "Integrated Peripherals":
OnChip SATA Device:
Bus Master.....Enabled
OnChip SATA Controller....Enabled
SATA Mode.....Raid
Onboard PCI Device:
(All disabled)
SATA ports (connected & working) are:
(bootable) Single HD on port 2
(bootable) Raid 0 pair on ports 3 & 4
SATA DVD-RW on port 5
Did I overlook something, in order for SATA Channels 5 & 6 to appear (under "Standard CMOS Features")?
I have my E6400 400x8 1:1 rock solid, but when i put 1:1.25 to run the ram 1000 5-5-5-15, ugly bsod :slapass: my system. Are there any known issue with this multiplier?
probably if you back the FSB down and then set the 4:5 memory strap, it will work.
I will try with 1:1.2, but if i cant run this thing at 400fsb with ram over 800, i prefer 400x8 1:1 than other configuration with less fsb.
Thanks Ace.
No, I didn't think that information had any bearing on solving my question.
Hard Disk Boot Priority:
1.SCSI-1: Intel Volume0 [Raid 0 pair]
2.SCSI-0: ST3160827AS [Single Seagate HD]
3.Bootable Add-in Card
So: can anyone comment on my question concerning what is showing in their bios setup screen under "Standard CMOS Features"?
Do you see 4 or 6 "SATA Channels"?
The Abit IP35-Pro Owner's Manual clearly shows 6 SATA Channels, where my bios setup screen only shows 4 SATA Channels.
Does the screen cursor allow positioning on each separate SATA Channel?
I'm beginning to think my IP35-Pro board may need to be RMA'd back to Abit.
