pleeease? :worship:
pleeease? :worship:
Try enabling Load line calibration.
21x200BCLK shouldn't be hard at all with a 3845B D0 chip. Try setting QPI/DRAM voltage (which is better known as VTT, I don't know why Asus uses that stupid term for it) to 1.30~1.35v.
I have core voltage at 1.320 and qpi/dram at 1.35. prime 95 still crashes instantly.
Try this...
Also, make sure your memory timings are being set right in the bios. Not just the 9-9-9-24 whatever ones, but all the rest of bank 1.Quote:
CPU Ratio: 21
Speedstep: disabled
BCLK: 201
PCIE frequency: 100
DRAM frequency: DDR3-1603MHz
UCLK frequency: lowest setting
QPI link data rate: lowest setting
CPU voltage: 1.35
CPU PLL voltage: 1.82
QPI/DRAM core voltage: 1.2
IOH voltage: 1.25
IOH PCIE voltage: lowest setting
ICH voltage: lowest setting
ICH PCIE voltage: lowest setting
DRAM bus voltage: 1.65 or whatever your memory is rated at
DRAM data REF voltage on CHa: auto
DRAM CTRL REFvoltage on CHA: auto
DRAM DATA REF voltage on CHB: auto
DRAM CRTL REF voltage on CHB: auto
DRAM DATA REF voltage on CHC: auto
LOAD line calibration: enabled
CPU differential amplitude: auto
CPU clock skew: auto
CPU spread spectrum: auto
IOH clock skew: auto
PCIE spread spectrum: auto
I copied everything you said to my bios, but one thing is not possible.The DRAM bus voltage cant go at 1.65 (which is the rating of my RAM kit) only 1.64 or 1.66 and with 1.66 I get a warning that I might damage my CPU. Which of the rating shall I choose?
And about the memory timing, I have no clue about what I should do :cow:
Edit: the voltages did the trick though, now running smooth on 4,217Mhz :D
Thanks a million for the help Roadhog and Shiranui Gen-An :bows:
1.64 and 1.66 doesn't matter. Whatever one you want.
thats just a myth lol
intels way of scarin us
i really doubt if intel even knows
bump your IOH PCIE to 1.55-1.6
you might wanna bump the qpi pll to 1.3-1.36 for higher ram clocks
pcie frequency 102
set cpu to 1.4 and blk to 210 for 4.4ghz dont be afraid as long as temps dont get too high
if you on air you can turn ht off for lower temps
testing at 4,4 now, multi goes back to 20 when temps reach 70 though.
