amazing work sergio!
looks like the mod worked quiet well :yepp:
cheers!
cheers!
i guess the smily didnt do it :) lol i was j/k :toast:
look everyone does it however/whichever sees fit.. im not forcing you guys to do it my way/only way.. i dont take it personal.. this is how i take it sergio:
modded evga ftw 285 @ 810/1836/2970 arctic accelero air cooled :D
http://i33.tinypic.com/1h59hl.jpg
10mhz core/72mhz shader better than ssc
under 40C after bench completes according to precision
ill recap C561-4 and see if it sustains 828core or 1872shader on air
sorry napalm i didn't got the joke lol, very nice score mate W7x86 keeps scoring a bit better than W7x64
yes i do the same except that i can go a bit more on mem, what vgpu are you using for that bench, will be good to know...
if i go to 821 core OCP cracks even with 10ohms as you suggested...only gain is that now shaders go high but artifacts, i tried till 1,4 yesterday and didnt see much gains...
so far i can sustain 810/1800/3024 to play crysis at 1920x1080 on the settings i showed before wich is an improvement at 1,35vgpu
Cheers mate :up:
Sergio
1.38vgpu.. keep tweaking/modding eventually youll get it to sustain higher clocks
- 1.39vgpu/2.2vmem
- 2.5v 1500uf tantalum @ C561-4
- 828/1836 sustained on air cooling (arctic accelero)
http://i35.tinypic.com/59twye.jpg
http://i33.tinypic.com/mht7pf.jpg
Napalm today i talked with a mate that's an electronic Eng. he told me to take ground not from the molex but for the proper circuit where the vr's are grounded wich is indeed the voltaje divisor, so if you measure vgu on molex you will get more volts than measuring on the vr's circuit ground. Can you confirm that ?
I got this testing 3DM06
Q9650@ 4608
GTX285@ 810/1836/3024
vgpu LOAD 1,36 / IDLE 1,16 (measured on the circuit)
W7x64
http://img22.imageshack.us/img22/338...0183615123.jpg
http://img689.imageshack.us/img689/4...8361512vgp.jpg
Cheers mate :up:
Sergio
Well, of course you should measure from common circuit ground as close to the measure point as possible, however it gives little difference in reality, and you really just want to know the
relative voltage increase from the mod, knowing the exact vGPU is of little importance. For this reason I simply use the molex as ground, and probe the measure point on the card.
Testing the card at my stable clocks for Crysis with Q9650@ 4707mhz on XP32
http://img259.imageshack.us/img259/3...0183615123.png
Cheers :up:
Sergio
just as on the ssc i have no success @ high load on the ftw @ crotale vgpu (xtreme cooling required)
light load can be fun though
http://i35.tinypic.com/oaww9y.png
air cooled at that :)
yeh 190 > 191 > 195 the diff between all 3 is 0.1 fps @ heaven bench.. havent tested anything else
alright.. i got 1.41vgpu now thru several vmods.. ill test @ 190
well sergio only way to get higher performance per clock and higher clocks is to perform diff vgpu mod/s
could you ask your mate electronic eng.. show him the isl6327 pdf.. show him the front of the card: D14-D21 (diodes) youll see why i tell you to bridge 1/2/3/4/11/12 ;)
diff diode configurations yield diff voltages.. would ask him what config does higher voltage.. or if he has/comes up with a better idea
thanks :toast:
he wont be able to answer that napalm unless i give him the circuit to study, his is not on the OC he just told me that about his toughs of grounding but soon as i get him i will
he works as an inventor he designs robots and hidraulic machines for factories in a minor scale for our country, i mean the machines that packs prodcuts etc...
i removed 12 bridge as it was no gain on voltaje before i did this mod, do you think that its also important to live that bridged ?
Cheers mate :up:
Sergio
i added a female connector and a cable with a male and a molex on the end so i can measure volts comfortable, still waiting the tantalums to try
http://img509.imageshack.us/img509/8373/p1030085.jpg
well sergio.. i used a diode from another 285 @ D18.. now i got 1/2/3/4/9/10/11/12 bridged.. + other mods i reached ~1.45 @ load and can push even higher.. same air/arctic accelero cooling and at this voltage the rest of the pwm is holding back further clocks.. the gpu itself runs cool.. ~40 C @ load.. id have to mod the whole freakin pwm.. or use better cooling
http://i45.tinypic.com/2rqmw4l.jpg
http://i45.tinypic.com/aw9q3k.png
no need to do vmem mod unless you want to hit 3300+ :D lol
the vgpu mods alone increase vmem to 2.2 from 2.1
here you go.. 10k ohm = ~2.3v
http://i50.tinypic.com/x4ir8n.jpg
yes to ground
Neighborhood do you think of a Akasa Freedom Force in a GTX 285?
Hi, could someone explain to me which of these mods on the first page would work with an asus GTX 275 non volterra chip VRM card (it has an uP6206 VRM)?
thanks
As always, measure mod point to ground, multiply by 20 and use a VR of that value. Should cause minimal change when set to max resistance and soldered in place.
