Asus Striker II Extreme 790i overclocking info
One more thing, on ram timings make sure P1 and P2 are on auto, visit corsair's forum for your ram and see what is the default bank (tRC) and tRFC. For instance, (mine) OCZ recommends for maximum capability to set tRC to 50 and tRFC to 110. If you can't find any info on these advanced timings, what you can do is run everything at stock, preferably on auto except vdimm (at 1.9v) and timings (excluding advanced) and NB at (1.44v) and see what the MB set for your ram, then whatever is on auto set it yourself. I think you might get stable timings like that, though on mine it tightens them just a bit.
All the suggestions I mentioned make huge performance gains and huge instabilities. All of them require more voltage on ram but P1 and P2 requires more vNB. I wouldn't worry about them now though, you can play with them later as long as you make sure you have the most stable settings.
People, having Loadline Calibration Enabled (or any other vdroop reducer or eliminator) reduces CPU life, CPU needs more voltage and strains system, in my case causes instability in overclocking. Though I had to enable it because I was going over 1.5v.
Full report here http://www.anandtech.com/cpuchipsets...spx?i=3184&p=6
Originally Posted by
Bobly
You also mention disabling loadline calibration, would that not also mean having to raise CPU Voltages? Because it's already set to 1.4V in BIOS (1.36V in CPU-Z) and I can't really afford to raise it any higher for 24/7 use :/ (Water cooled but can reach mid 60s under load).
Having a higher voltage on non cpu use will not raise your temperatures, on load though lets say 1.42 LLC Disabled does less heat from 1.42 LLC Enabled.
Bobly
Yes but isn't the idea that because of vdroop, with LCC Enabled you can have it set lower than with it disabled?
Enabled: CPU Volts set to 1.4V in Bios, 1.36V in CPU-Z
Disabled: CPU Volts set to 1.4V in Bios, could dip beneath 1.36V under load and therefore unstable?
That was my understanding of it.Cibic thanks for the awesome reply, hopefully tomorrow evening I'll get some spare time, read over it properly, take some notes and start some intensive testing ^^
Asus Striker II Extreme with LLC Disabled has a vdroop of 0.05v so if you want your cpu at 1.36 on full load you really want it at 1.41.
By the way, ram at high speeds are most likely to perform at design specs with dual cores. On quad cores you should relax timings and increase voltage to sustain operation, or relax timings just a bit, increase voltage a notch or two and downclock it. Either way, it should be about the same performance. Nvidia chipsets get the most performance with 1:2(or 1:1 with ddr2) ratio, 1900FSB linked and synced with my ram, so I can't decrease ram frequency.
Wish I had someone to help me when I got this MB, lets hope I save you some frustration.
NB and CPU skews on 45 nm quadcores
Hello,
after having wondered about if I can manage to run my Q9550 E0 and the P45 NB at the stock GTL values after all after such a long time (Bought my CPU in October), I tried out what powellandy did, also after having read something along the lines from mikeyakame.
And, I was successful. I just felt that a narrow range of 0.66-0.69x for stability on all GTLs was not looking like the system felt overly well. Here are my results, old first:
Mainboard: ASUS P5Q3 Deluxe Wifi@n
FSB Clock: 450 MHz (x8.5=3825)
CPU VCore: 1.275V
DDR3 RAM Clock: 1350MHz (4x1 GB Corsair 1600 modules)
NB Volt: 1.4V-1.44V
FSB Term Volt: 1.36V
CPU GTL Ref (0/2): 0.66x-0.69x, using 0.68x
CPU GTL Ref (1/3): 0.66x-0.69x, using 0.68x
NB GTL Ref.: 0.66x-0.69x, using 0.68x
LLC: Enabled
CPU Clock Skew: AUTO
NB clock Sew: AUTO
New:
CPU VCore: 1.275V
NB Volt: 1.4V-1.44V
CPU GTL Ref (0/2): 0.63x-0.70x, using 0.63x or 0.65x
CPU GTL Ref (1/3): 0.63x-0.70x, using 0.67x or 0.68x
NB GTL Ref.: 0.63x-0.70x, using 0.63x or 0.65x
LLC: Enabled
CPU Clock Skew: 500 ps delay
NB clock Sew: 400 ps delay
400/300 works, too, less than that tends to instability. Once again it shows that automatic settings aren't really good...
I am currently using 0.65/0.68 to not be on the razor's edge. These settings also take into account that ASUS is trying to keep the GTL references 0/2 and 1/3 apart...on top of this, the stable way higher GTL reference range indicates that this is a lot more of a stable setting than previously. However the previous settings without skews were tested 11 hours prime stable, too.
The best way of stabilizing a 45 nm quadcore above FSB430 appears to be to try and compensate with the clock skews first and leave GTL Ref. lines at defaults (not AUTO!), and then test the upper and lower limit of stable GTL settings. Then use a value that's in the middle, to be as far away from the limits as possible.
Translated into more analogue terms, this means the smaller the stable range of GTL references is, the closer the signal overshoot and undershoot are getting to the reference line. With it, the probability of one of them crossing the reference line increases drastically,and with it certainly the chance of having data corruption on the processor bus.
If you've got any questions or need my full Ai Tweaker settings, let me know.
:rolleyes:
This thread is a joke, I can overclock more with all gtl refs left on auto :P
