What do the Phase adjustments do in the BIOS?
They can actlike like partial steps to lowering trd (performace level), if all are set to '1' whils the board is running trd of 9, then it will be just like running 8 ;). It can help fine tuine memory performance & squeeze the last out of the NB.
Hey guys, got a question :
What's the best bios rev. for the UD3P and UD3R?
I'm still running F4 on the UD3P, managed to find a UD3R rev. 1.0 after a long and hard search. (haven't installed it yet, still sitting it it's box so can't say which bios is on it).
Thx,
should i upgrade my BIOS on my GA-EP45-UD3R to F12e from F8. right now i do have my E8500 OCed to 4GHZ with 9.5x and 422 FSB 100% stable
is UD3P Rev 1.0 still very good compared to Rev 1.6? also does the NB get hot like in RE that you need to cool with a water block? i'm thinking of getting rev1.0 but can't decide if i should look for rev 1.6. is buying a used rev1.0 for 75 shipped good idea or should i be getting a new rev1.6 from egg at $110 AMIR. i already plan on going water with my cpu. so i''d figure if the NB gets hot, i can just throw on a MCW30 on it.
I get you. I just didn't want anyone putting down my beloved 1.6! :D
I've been having a few stabs at getting 4.5 linx stable, but I'm suffering as a result of what I believe to be a bit of an iffy temp sensor and another weird issue I hope some of you might be able to help with..
I managed up to 8 passes before the PC instantly shut off which indicated to me that a temperature reached it's threshold somewhere. After opening ET6 and looking at the CPU temp sensor on there, I noticed it was jumping around a lot by up to 15°C above the internal sensors. Below is a pic of me testing at 4.4, just to record the kind of spikes the sensor reaches (I guess speedfan would have been better):
http://i194.photobucket.com/albums/z...useofcrash.jpg
Although I understand that the sensor is quite a way off the actual core temps in most people's cases, this one jumped between 75-93°C whilst under load, even though the actual core temperatures are what I think is ok for a linx run at these volts (i could have gone lower on the vcore, but this was just to help illustrate my point without crashing).
The furthest I've got is 8 passes at 4.5, and as you can see below, the temp is actually lower at higher volts:
http://i194.photobucket.com/albums/z...x/45-8pass.png
Shortly after this, ET6 spiked to 96°C and after that, it instantly shut down. (I assume it must have hit 100°C)
Below is another shot just before the previous one showing voltgaes:
http://i194.photobucket.com/albums/z...x/45-7pass.png
My other issue is sometimes when I run linx, temps run lots lower, and cpu runs slower and sometimes loses more than half the performance (i.e ~30 gflops rather than ~60), although nothing different shows in CPU-Z speeds or any other unusual events - could some process be interfereing with it even though everything else shows 0% usage? This is pretty much a fresh install of W7 64bit.
Any hints from the experinced pros are welcome! Do any of the bios offer lower CPU temp readings?
Hi guys , just got UD3P few days ago as my galaxy 650i ultra got busted due to 2 yrs of overclocking my q6600.. on that mobo it was doing 3.3ghz 24x7.
Now I wanna hit somewhere around 3.6ghz with this mobo.Went through few pages of this very very long thread.Looks like everyone is using 8xxx or 9xxx with this mobo. Is there anyone using q6600 with it. PLs post ur oc settings for it then :) so that I can start on a solid ground.. I have cooler master Extreme power 600 w psu and true 120. Since the heatsink on northbridge is sufficient hence I avoided swapping it with hr-05 sli. Now will it help if I replace the stock southbridge heatsink with Hr-05 sli or its not needed? .. Pls help guys .. On bios ver f8
You'll probably find the settings for the Q9xxx range will get you most of the way. You'll need more vcore to get lower clocks though and you won't be able to clock as high. I would suggest you start with all voltages/settings at default (not auto), set your multiplier to 6x and increase FSB from there whilst keeping a low multi (something like 400 will be worth starting from imo). It will also be worth checking if you can get 500fsb stable, just to find your CPU's limit and get a feel for what voltages you'll need. For everything other than CPU. There are no 'right' settings, it all depends on your CPU. Note that skews and CPU/MCH ref voltages are very helpful in getting stable, particularly at high fsb, although I don't know about this board and 45nm quads, If I kept my Q6600, I would probably have some settings for you.
See how far you can get, and post back with your settings and we could go from there. Remember to keep an eye on your temps though - those quads get proper toasty!
Look for posts made by user name "Fatguy1992" on this thread, I'm pretty sure he pushed his Q6600 over 4300Mhaz daily:
- http://www.xtremesystems.org/forums/...rchid=19269694
Fatguy's Q6600 4050Mhz stable template:
http://www.xtremesystems.org/forums/...postcount=3227
man, all rev's seem good. you guys are getting insane fsb's that P5Q can't seem to hit. what kind of memory are you guys using? would this G.SKILL 4GB (2 x 2GB) DDR2 1066 (PC2 8500) Model F2-8500CL5D-4GBPK - Link be good enough? or do i have to get something that is even higher than this? and the Voltage 2.0V - 2.1V that the ram is rated at, is that fine to run in the board as well?
can someone post/link me to OC settings for this board. i have a q9550 e0 and coming from an asus p5e mobo, not sure what max volts are for this mobo/chipset. thanks in advance.
start reading at page 125 of this thread, that is where all this quads start to show up :D http://www.xtremesystems.org/forums/...05132&page=125
Had 4.0 GHZ easy the other day, and then lost it... i couldn't get it back no matter what i tried in the bios on the UD3L rev1 f4 bios... it seemed like it was resetting the memory speed on me...
so here's what happened: i updated the bios to f7 and it booted right away,,,,
just in case any of you folks have the ep45 ud3l and run into this:clap::clap::clap:
My god these Gigabyte boards are finicky.... :shakes::shakes: - but they run good....
http://i432.photobucket.com/albums/q...k666/TYYTY.jpg
that's all
enjoy....
Thanks guys for all ur replies..:up: I will start with settings posted by fatguy1992 .. got a pretty decent knowledge abt overclocking but zero knowledge about p45 chipset.As I was using nvidia 650i ultra for last two yrs and it was a decent board for its price. Will try different things and post how far I can go 24x7 :)
Ok. Been able to clock q6600@3.6 ghz with ram@800 mhz -9x400 fsb 1:1 .My ram is pretty ordinary one- transcend 800mhz cl5.. I think max this ram can do is 900-950 mhz with loose timings.
