If you want to run high FSB speeds make sre you get good rams, eg 500FSB with my quad was hard to get stable with the rams at 1000mhz, with rams at 1200mhz it was far easier. P45 and 1:1 divider is harder to get stable.
These should do the job, yes?
http://www.newegg.com/Product/Produc...82E16820227406
i dont know WTF is going on with this computer. i was at stable settings for 10+ hours on prime blend. no crashes or anything. then i changed it to try to get more out of it but it was a no go. so i went back to my stable settings and for the love of me it cant even pass 1 hour of prime blend
Is there a software that will help me monitor NB and SB temps? I suspect I have a problem there, and that one of them is overheating. I can't get 4Gig stable no matter the volts I put through CPU
1.26-1.28 for NB and 1.1-1.2 for SB
I can't get past ~3950 no matter the Multi. FSB is ok up to 520 (tested with 6 multi). I've been feeding CPU up to 1.4 volts in BIOS. I have Schyte and 120mm fan cooling it. Also have about 6-7 fans on my case (Antec 1200), so temps shouldn't be an issue but I wanted to check them either way :(
what cpu is it? and im using 1.28 nb and 1.2 sb borderlining hot and warm when i thouch their heatsinks, but im stable at 525 x 8. try running small fft's for 2 hours to see if its the voltages of the cpu. if it isnt the cpu, i can almost guarantee you its the nb gtl. it takes ALOT of tweaking. my board surprised me. instead of .630 and higher its always been under that :shrug:
It is 8400 E0
Hmmm never even touched nb gtl. Any reference from where I should start?
first lower ur vcore for the e8400 e0. im at 1.325 4.2 ghz stable. so try somehting lower then run prime 95 small ffts for two hours and then let us know where you stand. after that, we'll tweak your fsb
Tried 1.38 in BIOS but I either BSOD on boot or if I get into Windows I can't run prime for more than 2 seconds. So it is CPU than?
I got the exact same issue i need 1.38v in bios to be stable at 4Ghz..
If i decrease the vcore one notch i get bsod or errors after a few minutes in windows! My E0 is just really bad. Tried to get it too 4.2 Ghz just to see if it even could and it could do it.. Just needed 1.42v to be able to boot and run SuperPI :down:
I tried tons of other bios settings etc but the ONLY way to actualy get this chip stable at 4Ghz+ is pouring voltage on it :P
Look like I have even worse CPU than you :) I can't get 4 GHz even with 1.42
Sell them CPU's lads and get a new one... I hope you guys are testing prime small FFT and not blend.. first stabilise the cpu , then go with the mix
i wouldnt say that the cpu is bad right away. i bsod on higher voltages. WEIRD board. but im completely stable at 1.325. try 1.33125 and see if that lets you guys load. its should ok. its an E0 and shouldnt need much.
Sadly rig won't even post at 1.325+ all the way to 1.38.
Wish I could sell of this chip but I don't know anyone that would buy it :/ My biggest problem with hardware as I never sell, I just give it away to family
It's not like i hate my E8400 or anything :) I still think it got alot of performance for such a cheap CPU, and im happy with a 4Ghz 24/7 clock. It's just that i want to be able to push it a little further on a decent voltage :)
I will try to sell the CPU and buy a new one as Leeghoofd said, hopefully I'll get one that can do 4Ghz around stock volt :up:
I easily get to 3.4GHz on my Q9400. I am am having trouble at 3.6GHz. I can boot into Windows, but I fail the IntelBurn test on the first pass. I upped the Vcore to 1.33 and still failed. I am not familiar with Vtt, PLL, and GTL voltages. Any ideas to start with?
425 x 8 = 3.4GHz
Vcore: 1.31
vDimm: 2.00
vNB: 1.34
LLC: Disabled
CIE: Disabled
CPU Margin: Optimized
All other voltages on auto.
Well to start out with if your board is like mine vdroop is HUGE on this board with a quad. You may want to try out loadline. I generaly keep my vtt close to my vcore at load, a little higher with LLC disabled and a littler lower with it enabled. You shouldn't heed that much voltage on your northbridge either. Just set your PLL to 1.56 since it dosen't need to be higher and at auto, 1.52, and 1.54 it overvolts from what I hear. I havent tested that out with a DMM myself.
Your GTLs are based off of your vtt. For example your vtt is set to 1.32 and your cpu GTL is set to 0.650. So, 1.32x0.65= 0.858. That is your actual GTL. You want to keep that between 0.8v and 1.0v. It's all trial and error really and a 0.05 difference in your GTLref can make the difference in stability. You should really read this thread. There is alot of really good info in there.
Good luck.
What driver do you guys use for onboard audio on this board?
Thanks for reminding me about my Vdimm and vNB voltages. I needed these to
run my memory at PL=7 for 3.0GHz. At 3.4GHz I am running PL=10 and I do not know if it is posibble to improve that with normal voltages. I am testing:
vDimm: 1.96v
vNB: 1.24v
A nice improvement. Up to now it seems the memory has been the main problem when I try to increase FSB.
I use an old SB Audigy sound card, I have never used onboard audio.
OK, Im still struggling to get 4.5GHz even bootable on this dx and 9650. I have tried just about all voltages. Any suggestions aside from ud3p?
Im on the 333 strap with ram running at 1200Mhz so 5:6 (memory was fine there with much lower multi). Even tried higher voltage (and less) with 8x multi, still cant get it to boot into windows.
Oddly enough, I got her to boot and a Spi run (10.3xx) at 4.5Ghz 500Mhz...Took a lot of FSBt (1.56) to do it though...
