Originally Posted by
Bartflaster
I think that looks stunning :D
So much so, I wanted to go with 10/8 and compression fittings (I assume thats what was used ?) for my build, but I have a problem.
I ordered some compression fittings, but the store that sold them only had one sort of black 10/8 in stock (alphacool) so I got that ... I am dissapointed in it will only go to around 120mm bend ... much more and it kinks.
The Tygon Mflox used goes much tighter, looking at the CPU to Northbridge in that pic, but I can only find one supplier in the UK ... and that is 11/8, is that what you used ?
Did you have a problem getting the compression ring over it as the tubes OD is 1mm to large ?
Secondly, anyone know of any other UK suppliers for this tube ?
(I don't want to pay nearly a fiver postage on £6 worth of tube which is the case on the supplier I found :rolleyes: ).
