It is an E0. Now, I am running BIOS 1702 but instead of the stock Asus BIOSes I'm using a modded BIOS from Ket, got them from here.
http://www.xtremesystems.org/forums/...ght=modded+p5q
My GTLrefs are set to .63 and .67, NB GTL at 6.3, VTT at 1.26v and vNB at 1.30v. PLL is at 1.5v.
RAM settings are going to vary as I'm running 4GB of Mushkin, but I have Static Read Control disabled, DRAM Read Training and OC Charger are set to Auto.
Common Performance Level is set to 10, doesn't want to POST with it lower than that above 500FSB.
All Pull-ins disabled, all clock skews set to Auto.
Keep in mind that I'm on water so my vCore requirement is already a little lower. Wolfdales don't seem to respond to GTL tweaking until much higher speeds so you can pretty much leave them alone.
My advice is to find a CPU speed you want, then try to match the RAM to it. I have Mushkin Ascent 1066 RAM but I run them at 1000 for the time being because 4.25GHz is a happy CPU speed at the moment. Running lower speeds can often help you run tighter timings, which can also help with speed. I'm not familiar with Dominators, so I can't really help you there.
Good luck!
