Ok, I've tried everything to get the 1333 strap to work, but every attempt results in a no POST situation.
shift jumper, load BIOS defaults, the only thing I changed was vcore to 1.5 to make sure CPU is stable at 333fsb, vMCH to 1.65, and default fsb to 1333.
no POST.
tried lowering memory, maxing vMCH etc with no change in results.
I've run 370fsb at 1066 strap, memory has done 450mhz cas 4....wth is going on here!?!?!?
Help appreciated...
