Why? :confused:
It appear in 925X mainboard but not in 965. :shrug:
On 3.3 beta is present in my Gigabyte P35-DQ6 an annoying change of displayed memory MHz in the "System" rectangle.
It changes randomly between 3 values: one is correct, others are wrong.
Bye,
Thank you FELIX, works good :)
Here is beta2 version with Performance Level (by The Stilt): MemSet33beta2
We added Command Rate too, but it's only a Read only timings.
Also, improve reading memory frequency. :)
Warning: I don't try the Performance Level with P965, and I don't know the result.
I'm going to try this on p965 right now :)
But so far, I've noticed trtp is reading wrong. I have dfi p965, and set trtp to 4 in bios. memset32 shows 4, but 33b2 shows 2 only.
performance level seems to have no effect. not sure if it's because it's read only or what. but it showed 12 initially. I was able to drop it all the way to 1, and mbench showed no differences whatsoever.
range from 1-12
edit: also it looks like trtp is off by 2. When I set it from 2 to 4 in 33b2, it goes from 4 to 6 in 32.
thanks for the new version.
but it donīt read the memory frequency:
http://pics.mwirths.de/pics/memset.jpg
Asus P5K Deluxe
FSB 500
MEM 600
Doesn't work on p965 ... Tried with commando . I can select from 1 to 12 without lock ups , but the performance doesn't change .
On GA-P35-DQ6 performance level works perfectly.
From level 7 (my first stable setting at 390 MHz FSB) to level 12 there is more than 20% difference in everest memory and cache benchmark.
The strange thing is that at first launch of memset it displayes 11 as performance level even if the real performance level is 8 (checked with everest benchmark)
Is it possible to save a memory configuration and load as soon as memset starts?
Or do it by a command level start?
Works fine, great option and thanks a lot :up:
Lowest i can get is 5 (+0.3 vMch). P35C bios F3b. Settings from bios:
Default = 8
http://img.photobucket.com/albums/v6...c/default8.jpg
Performance = 6
http://img.photobucket.com/albums/v636/loc_oc/perf6.jpg
Performance = 5
http://img.photobucket.com/albums/v636/loc_oc/perf5.jpg
Felix I can't get the performance level to even read a # on my P965-DS3 board. When I open memset it has no value for the performance level and if I try to change it the apply button is grayed out.
Felix the latest Beta ( v3,3 Beta 2 ) isn't working with Asus P5K3 Deluxe at all ( it's a DDR3 P35 board ).
Here's a pic
http://i8.tinypic.com/521wgpk.jpg
Let me know if I can help you with something :)
dunno if it has been posted or not..but this program works on my 680i mobo.
Beta 2 works on Asus P5K Deluxe, Performance Level is also working.
Thanks to both you and the Stilt :)
Will soon be writen Vista 64bit version?
dlin that tool..
I confirm that it don't runs with DDR3
Gigabyte P35T-DQ6
I didn't check if the timings are being set actually, but after a fresh OS install, the apply button is now enabled @ P5K3 Deluxe.
Will test it in a matter of hours and report back Felix ;)
Found out that if you boot with "DDR2-like" like timings on the P5K3 Deluxe ( probably applies to other DDR3 mobos as well ) ( timings like 7-6-6-15 ) [ tCL, tRCD, tRP, tRAS ] lets you use memtest ( performance level changing works perfectly ) [ haven't tested the timings thoroughly yet )
Hello m8,excellent tool.Probably in the next beta the SAVE option will be available,so that it could be applied at system start-up.My mainboard is a p35-dq6.Thanks.
