@donmarkoni
yes, but I have 3T in the bios.
it seems that cpuz displays incorrectly.
@donmarkoni
I'm confused... You have a 6 core at 5.84GHz, I have a 4 core at 4.02GHz and I get more CPU points than you...
http://img42.imageshack.us/img42/171...arkvantage.png
EDIT: You kick my CPU's arse on CPU test 1, but one CPU test 2 you are worse than me for some reason?
Excellent board. Best of the best :up:
I thought it may be PhysX but being that it is a "CPU" test I would have thought it was for the "CPU", bit of a gimmik really :down:.
Thanks for the heads up anyway, makes sense now.
EDIT: 25K :rofl: How shameful! That totally shows how bias Futuremark is towards Nvidia :rolleyes:.
It's because the PhysX on the GPU is much better than a CPU at calculating physics. But yeah, gimmick :)
So I flashed from 0402 to 0602. My northbridge temps have dropped about 6-7 degrees celsius... or Asus mangled the software reading to make me feel better.
Also fixed the bug with TurboV displaying the wrong PLL voltage.
Where can one download 702 from? I dont see it on FTP site...
EDIT: Even with 0602 my IOH and ICH temps are rediculous and I never checked the temps with 0402 so I have no reference to check to see if my temps went down or not. This board is most definitely going to get a full cover block that is for sure.
http://img18.imageshack.us/img18/8597/vanup.png
I like RIIIE :D
Got a little problem, when system is cool & you start up for the first time the memory only shows 4gig of the 6gig.
If you enter bios shows 4gig & then turn off computer & re-enter bios it shows 6gig, noproblem after that.
Tested different memory slots ect & shows 0 errors on memory test.
Any one have an idea whats going on?
A lot of people are having problems with ram showing 2 gigs or more missing.. i would try and reset the ram with stock timings and if that doesnt work bump qpi up a notch or two. Also it can be the Heatsink is tightened down to tight. Eva2000 posted a thread on this on http://i4memory.com/f54/asus-x58-6-1...stalled-19200/ Hope this helps. :up:
I also noticed that my memory which is set at stock of 1600 shows as 1066 when cold booting, but if I re-boot it immediately it then shows the proper 1600 during post. Seems this board has problems with memory, so hopefully it is just bugs that need to be worked out of the bios....
i had serious problems i'm sure others are having
i couldnt overclock as soon as it booted in memtest or windows pc would
reboot even at a low overclock
i thought my memory was failing then another set then another set i went nuts
then i set memory @ 1333mhz and overclocked the cpu cause memory was stable @ stock n boom error
if you cant overclock the board reflash bios
i recreated problem 3 times:eek:
every time was solved by reflashin bios
bios is gettin corrupt
i think its either the board or some bad bios chips
i will contact asus to send me some new bios chips
I had 2 gigs missing for a while, and reseating my VenX about 3 times loosening up each time I got it back.
While I am not at Cas 7.. I am really happy with this combo.. RIIIE , Patriot 2kLL, & W3570
This looks promising for a 24/7 set up..
I could not get the Ram to goto 2k without raising the QPI/VTT to 1.58/1.6 with both my 930 & 920..
I finally have some good luck.. only need 1.41 VTT with this set up. and lower dimm v:):)
