Thx :D
Ram disks are only good for correctness testing.Quote:
btw, why not just use tmpfs (it's almost like RAMdisk), put there 50gig file and test your RAW I/O from there?
I think there is no need to run the computational part and create same 50gig PI file over and over again...
tmpfs hint:
add one line to your /etc/fstab
something like:
tmpfs /testdir tmpfs size=50G,mode=0775,uid=YOURUSERNAME,gid=YOURGROUP 0 0
edit yourusername and yourgroup to match your's
(or just set mode to 0777 and make that directory writeable for everyone)
be sure not to delete the other lines in fstab :D
and then run "mount -a"
It doesn't help much when I'm actually trying to measure the performance of something on actual hard drives.
Also, I do in fact test the I/O parts by themselves to narrow down the possibilities.
But there are some parts that involve doing I/O in parallel with computation - for those I need to see how the computation threads will interfere with the I/O threads.
In Windows, I have to set the I/O threads to a higher priority than the computation threads to keep the I/O threads from being starved by the computation threads.
In Linux, I'm still trying to figure out what's going on... though I won't be able to do much anyway since OpenMP lacks priority control.
Nah... It seemed easy enough when I found that you can do it by printing "\033[01;31m".Quote:
btw, do you use ncurses for colored output?
So all I needed was to add a linux version to each of my color changing functions and all was good. Too easy...
I tested ext4 today. (Formatted all 8 drives to ext4 for this.)Quote:
with ntfs I recomend ntfs-3g, it's userspace implementation, and works very well, (last time I used it was about a year ago and it was flawless)
in Ubuntu search with aptitude for ntfs3g or ntfs-3g (not sure how it's called there...)
Yes, Linux does not like NTFS at all. 30 - 60% faster I/O speeds on ext4 than NTFS. But for some reason it still doesn't like the raw I/Os - which, in contrast, worked really well on Windows...
Hey!!! I guarantee you that 95% of OCers who are called "Xtreme" do not have 18.5 TB of disk and 64 GB of ram in one machine... :rofl::rofl::rofl: And still be able to close the case... :yepp:Quote:
PS:
You are not OCing, your are not Xtreme :ROTF:
EDIT: ok, just noticed :D you are OCing your i7, good boy :ROTF:
Not just that... this baby has had that 64 GB of ram since January 2009. ;):p:
Also, this board won't OC... I tried SetFSB... doesn't seem to work at all on this board. :(
