Alternate Belgium has it in stock and they sent not only to Belgium ;)
Creditcard will also accepted.
Why i didnt have the TDP TDC option? :confused:
[QUOTE=r1ch;3660478]dave i'd suggest G19
http://www.benchzone.com/Downloads/B...onn/BloodRage/
I have been using it for a week or so but was told not to post it, Bill has obviously been given the ok :)
I flashed the ( G19 bios) but wen i look in to the bios @ mainbord information it says G18 bios ???:confused:
Well, ive got myself a 3837B 920 OEM, which should arrive on Friday... can't wait to put this board through its paces now :D!
The questioned option:
http://img61.imageshack.us/img61/9449/fx58b04dt1.jpg
BIOS G15, so says windwithme here (<- there clicky) for instance.
Ok thnx
No need to worry about that option as AFAIK it is disabled by defaults ;)
How to enable it?
Thats what i have done with GB Extreme.
I could never do this with the Bloodrage because the Multi drops down to 20,thats why i ask.
http://www.abload.de/img/i74368ghz-4desktopauflz6f2.jpg
Are you applying the same voltage approximately ?
Does any of your CPU cores temp get past 84C ?
I didnt have the CPU right now,but i ask for coming CPUs.It suckz that the Multi drops down from 21 to 20 when you set a VCore over 1,45?
Hello Guys,
i`v just resive mine some hour ago from Alternate.be, ordered / paid at 02.12.
So it wanna say hello to it`s brothers, together with Watercool HeatKiller 3.0 witch i let black nickel.
:wave::wave:
Just awesome :up:
@ Sch0ck.....Dood, glad to see you got your board and that block looks sIcK!!!! Looking forward to your results!!:up:
Yeah jooney is wright , if my multiplayer should stay @ x21 i should hit the 4.5GHz and get me a fine 3D06 score :confused:
the problem is that i have to use 1.55V to get is bench stable , no worry on the themps doh , i use extreme watercooling + airco :up:
see my screenschot plzz
I thought it was an OC Board for all i7,not only for 965XE :(
I´ve sold my Rampage II Extreme, because I thought that the Bloodrage doesn´t have this bug. I hope the bug will be fixed with one of the next BIOS.:slapass:
Foxconn should "sponsor" you guys an XE... ;) j/k
