mmm yeah maybe i could crunch some numbers tomorrow
:up: Thx
Nice score :D
X3350 is +/- like a Q9450:
http://images4.hiboox.com/vignettes/...fc0a5a9496.jpg
:p:
Yes!!! Thx
I just would like to know how efficient is a C2D 45nm with higher than 4.5Ghz.
Here is a personal test:
http://images1.hiboox.com/vignettes/...98a4b9f6ce.jpg
wanna watercool the NB but dont wanna rip off that sexy heatpipe contraption that this asus board has ?? well you could do this !!:D
i installed my swiftect NB block straight to the heatpipes like so.. you need to swich the mounting finns on the block the otherway arround !!! if you dont do it the block wont alling with the holes on the heatpipe cooler ;)
http://i163.photobucket.com/albums/t...s/DSCN1275.jpg
i used the block screws that come with it the other way arround like you can see from the pic.. then just tightened until the springs went no further.
http://i163.photobucket.com/albums/t...s/DSCN1276.jpg
READY TO ROCK :yepp:
http://i163.photobucket.com/albums/t...s/DSCN1278.jpg
->Solarfall: I needed to cut a little the WB because contact between WB/NB is not enought ;) That's allow me to "screw it well"(sorry, don't really know how to tell this).
BTW, it seems that Swiftech is about to produce a sexy MF2 WB for NB:
http://img355.imageshack.us/img355/1...m2fx450qf7.gif
Your CPU isn't WCed???
mr-rob you dont have to cut anything if your using the same block as i am.. you will just have to swich the metal mounting finns (the shiny ones) other way arround.. the swiftech mwc-30 will fit then !! you'll just have to swich the mounting finns easy as that :up:
nope i usually dont watercool my cpu.. cos i basically use this board just to do benching :D
I use the same as yours: Swiftech MCW-30, isn't it?
I don't really understand what you meant by "switch the mounting...".
Not a big deal :p:
:clap: I do the same!!! This board is for benching!!! :up:
Here is my bench'rig:
http://images4.hiboox.com/vignettes/...959ce6f7cf.jpg
:D:D:D
before you think that big OC is stable, run IntelBurnTest on Max memory usage.
it might scare the :banana::banana::banana::banana: outta ya.
So i'm leaning towards the Asus P5Q Deluxe because of the cooling for the Mosfets/NB/SB.
How's the motherboard chipset cooling for the Maximus? And is there really any big difference between the Deluxe and Max other than sound card?
My board just arrived
Are the chipset drivers on the CD upto date?
Damn, the 0901 Bios is giving me lots of problems. Crash codes in OCCT and Errors in Orthos. Im going to try the 0802 Bios....
It seems to come out in about 3 weeks.
:D Yeah, it's really sexy :p:.
I'll see if I'll change my MCW-30 by this one later :cool:
I don't know for the drivers. I used to DL directly from ASUS & BTW I never used CDs provided with the boards.
For now, my favourite bios is still the 604.
Thanks guys for the info.
I'll try 604 first and move up from there.
Someone has the measures, of bridge NB???To do a domestic block, for my.
Regards
I have noticed that the 0901 bios has been removed and replaced several times on the Asus website. as of now it is posted - anyone know what is up with that?
Guys, please help me! I`ve bought M2F today. Before that i had MF.
My rig is in signature.
I reached very good result with MF. But i can`t reach the same with M2F (maybe coz of different bios which i need to learn?)
Can someone write bios config,please?
hey everyone i just got the maximus 2 formula and love it. im having one problem though. im trying to install a 64 bit os and it doesnt work. all my 32 bit os's work. is there something i have to change in the bios? thanks
It doesn't work is really vague. What problems are you encountering?
lol sorry. well i make it boot from the cd drive and whenever i put in a 64 bit os it says "reboot and select boot device or put in boot media and press a key"
