:D The easy way to downgrade BIOS on ME:
If You are i.e. on 1001, flash 1001 again (will work!) and shut off Your system during flash. This board has a crash-free BIOS and will automatically tell You to insert the board's DVD after reboot. Then it will flash the BIOS from the DVD. Now You are on a very old version so there will be no problem to flash a later one.
:up:
