It's a Amacrox Calmer 560
Hey Andrea, thats an awesome setup. Am planning to get the same case from lancool. How good are the fans?? And how good is the case to use. Do u think I need to budget a little extra to get better fans??
fan in the box are:
3* 14cm 1000rpm
1* 12cm 1500rpm
dual ball bearing!
i have replaced the 1500rpm fan with a 1000rpm led fan from lian li.
for the cpu i have used the same fan in push pull....
but in not the best..... maybe in future i replace the 1000rpm 12cm fan with a 1500rpm...... or all the set of another brand...
but now my pc is REAL silent!
it's a V2000B by Lian Li. There is also the Tagan Black Pearl which is about the same with a few minor differences in appearance.
I got it used actually. I couldn't find one anywhere, but I saw one for sale at the guru3d fs thread.
Yeah actually. The front was originally solid with plastic bay covers. The case had absolutely no front airflow, so I stuck a 120mm fan in and picked up some perf sheet metal at Home Depot and cut it out to fit the hole.
Printed and cut out a GoW logo, masked the front and sprayed it. Turns out pretty nice with the lights! :D
Here you have:
http://i31.tinypic.com/1e4dxc.jpg
http://i31.tinypic.com/24v600p.jpg
Sorry for my late :)
Obrigado Marco , really appreciate this :)
Prolimatech Mega Shadow Deluxe Edition...
http://i878.photobucket.com/albums/a...roliMS-1-1.jpg
http://i878.photobucket.com/albums/a...ut/ProliMS.jpg
http://i878.photobucket.com/albums/a...roliMS-2-1.jpg
Is this TX-3 the same as MX-3?
shawnlut how much?
Hey everyone. This will be my first post and I thought I might as well do it here.:cool: Here is a pic of my rig.http://i431.photobucket.com/albums/q...is/updated.jpg
Its nothing extreme but it gets the job done ;)
shawnlut
how much it was and where did you bought it?
dont use abload.de, cant see images :shrug:
