Ok, donmarkoni, I tried the template you suggested and it did not post, never even came back on. So I tried the below template from page 3 and it also did not post, did not even power back on. So, I downloaded bios 1401 (was on 1208) flashed it and retried, and the same thing. So, I looked around and realized that I had set my multi to 20 and left BCLK at 200. Set multi to 21 and still didnt post, so then I realized QPI Loadline Calibration was still disabled via the jumper, so I decided I did not have any interest needing to use a jumper, so I looked at a few guides on i7-920 overclocking and decided to use the CPU Level up feature just to get me some ideas on reference voltages/settings etc. After setting voltages manually (and anything else in your template), it then booted just fine and I have ran Prime95 for an hour before the CPU warning went off. I stopped prime just because the warning from PC Probe kept going off. I installed probe before running any overclocks, and it was complaining of all kinds of things, mostly voltages. It would say that cpu voltage has droped to 0.00 or that cpu pll has droped to 0.02 or that dram bus voltage has droped to 0.23 (also claims IOH pcie volts has dropped to 0.23v, lol, seems fishy to me) or that dpi volts has dropped to 0.03 and many more similar warnings but the system kept running just fine. Constantly going off for about 5 seconds and then returning to normal and repeating itself a few minutes later or so. This happens with or without overclocking, on both bios 1208 and 1401, so I can only assume PC Probe is crap (or my windows install is borked) and I need to uninstall it, lol... CPU Temp hit 70c so I halted Prime95 and it then recovered to 44c... and yes I know 70c is still safe but I need this cpu to last a very long time. (by the way, I am preparing to replace my cpu hold down as one of the 4 swiftech screws is stripped, so it may not be getting full pressure from the block)
I'm am perfectly Ok with a mediocre overclock of 3.5ghz but not Ok with all the warnings. Do you see anything in my template below that I need to change asap? Everything in bolded parenthesis below is my actual current setting and the only thing that differs from your template on page 3. Thank you for any guidance you may be willing to share with this OC noob. lol
Also, for reference my memory is the cheap Dominator TR3X6G1600C8D 6gb kit. Oh and one last thing, if anything in my current settings scream out how noob I really am at this please forgive me, I already know this as a overclocker friend of mine rubs it in all the time, lol...
Code:(CPU Level UP to i7-965 for reference settings)
Target CPU Frequency 4000MHz (3570)
Target DRAM Frequency 1603MHz (1704)
LN2 Mode: [Disabled]
QPI Loadline Calibration: [Disabled]
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto] (i7-965)
2D Performance Booster [Disabled]
CPU Ratio Setting [21.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Enabled]
Hardware Prefetcher [Enabled]
AdjacentCacheLinePrefetcher [Enabled]
MPS and ACPI MADT ordering [Modern]
Intel(R) Virtualization Tech [Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Performance/Watt select [Power]
Intel(R) C-STATE Tech [Enabled]
C State package limit setting [Auto]
C1 Auto Demotion [Enabled]
C3 Auto Demotion [Enabled]
BCLK Frequency [200] (170)
PCIE Frequency [105]
DRAM Frequency [1603] (1704)
UCLK Frequency [4009] (3408)
QPI Link Data Rate [7218] (6135)
Memory Recheck [Disabled]
MemoryConfigurationProtect [Disabled]
>DRAM Timing Control----EVERYTHING BELOW ON AUTO
CAS# Latency 6 [6] (AUTO)
RAS# to CAS# Delay 7 [7] (AUTO)
RAS# PRE Time 6 [6] (AUTO)
RAS# ACT Time 18 [18] (AUTO)
RAS# to RAS# Delay 4 [4] (AUTO)
REF Cycle Time 72 [72] (AUTO)
WRITE Recovery Time 10 [10] (AUTO)
READ to PRE Time 6 [6] (AUTO)
FOUR ACT WIN Time 24 [Auto] (AUTO)
Back-To-BackCAS# Delay 0 [Auto] (AUTO)
Timing Mode 1N [1N] (AUTO)
Round Trip LatencyonCHA 59 [59] (AUTO)
Round Trip LatencyonCHB 61 [60] (AUTO)
Round Trip LatencyonCHC 62 [61] (AUTO)
WRITEToREAD Delay(DD) 8 [Auto]
WRITEToREAD Delay(DR) 8 [Auto]
WRITEToREAD Delay(SR) 18 [Auto]
READToWRITE Delay(DD) 7 [Auto]
READ To WRITE Delay(DR) 7 [Auto]
READ To WRITE Delay(SR) 7 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITEToWRITE Delay(DD) 7 [Auto]
WRITEToWRITE Delay(DR) 7 [Auto]
WRITEToWRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Enabled]
Extreme OC [Auto]
CPU Voltage 1.343 [1.33750] (1.25)
CPU PLL Voltage 1.349 [1.35150] (1.81)
QPI/DRAM Core V 1.429 [1.43750] (1.35)
DRAM Bus Voltage 1.654 [Auto] (1.51)
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage 1.111 [Auto] (1.11)
IOH PCIE Voltage 1.508 [Auto] (1.51)
ICH Voltage 1.111 [Auto] (1.11)
ICH PCIE Voltage [Auto] (1.51)
*QPI Voltage OCP [Enabled]
*IOH Voltage OCP [Enabled]
*DRAM Voltage OCP [Enabled]
*QPI PWM Frequency [Auto]
*IOH PWM Frequency [Auto]
*DRAM PWM Frequency [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
