I've got a similar setup as you - C1 Q9550 @ 3.91GHz/1.3075 vCore. With the TRUE 120 and a single fan, I run idle at 34ish per core and at full load after 3 hours of Small FFTs, I don't go over 65.
anyone using 16GB of RAM on this board?
what kit?
Check to make sure the Zalman is sealed well too - I tinkered with the TRUE a few times before realizing the washer mod was required. I've also lapped the TRUE (but not the processor) and that helped flatten things out and help make it more secure, although I can't say it did too much for temps that I was able to notice.
Hello All,
First of all let me say hi to everyone, I'm new to this forum.
Secondly, just so you know, I have read 99% of the 200+ pages of this thread. But still having issues.
My problem is I can get past 422 x 9.5 on this P5Q Deluxe rig I just built on the weekend.
Ok a little background: I have another rig with a P5Q Deluxe and the same E8500 E0 CPU. That rig will run 442 x 9.5 with 1.4 volts on CPU and most all other settings on auto except for the usual stuff that you normally would disable like Speedstep, Spread Spectrum, etc. That rig is totally stable. I even copied from this stable rig my exact bios settings and plugged them into this second rig, still no go.
But this other rig won't go past 422 x 9.5 no matter what I do. Below are the settings I'm using But I can't remember exactly the OC Twister settings and DRAM Read Training (I think is dsabled), so I left those settings out. I will update my post with those settings tonight when I get home. But I can run at 422 x 9.5 on this rig with everything on Auto except cpu volts which I raise to 1.4 and it is stable.
Also the CPU that is in this problem rig was just in an SLI 680i board and it was running 442 day and night totally stable, so I know it's capable of these speeds. I just changed out the board because I wanted to run a 4870 X2.
Here is a side note: I can get to 442 with this troubled rig by setting the DRAM Frequency to 1066, but it's not stable.
By the way, the settings below will not boot to Windows.
Hardware in both rigs:
C2D E8500 E0
Zalman 9500
P5Q Deluxe 1406 Bios
2 x 1GB Corsair Dominator 8500
PC Power and Cooling 750/Thermaltake 750
HD 4870 X2/GTX 280
So as you see both rigs are identical except PSU and Video cards.
Bios settings :
AI Overclock tuner: MANUAL
CPU Ratio Setting: 9.5
FSB Frequency: 442
PCI-E Frequency: 100
FSB Strap to North Bridge: AUTO (have tried 400 and 333)
DRAM Frequency: 885
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: AUTO
1st Information: 5-5-5-18-3-52-6-3
2nd Information: 8-3-5-4-6-4-6
3rd Information: 14-5-1-6-6
CPU Voltage: 1.41 (I have tried all the way up from 1.27)
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: AUTO
FSB Termination Voltage: AUTO
DRAM Voltage: 2.1 (but have tried all the way up from 1.8 in .2 increments)
NB Voltage: AUTO
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Disabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: AUTO
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
CPU Margin Enhancement: OPTIMIZED
Please can anyone give me a template of settings to try or any advice to get this rig to 442 x 9.5? I am pulling my hair out guys because I should totally be able to do this. Like I said my other rig runs this speed and is totally stable (hours of Prime95, Orthos, games, etc), but I just cant get this CPU/Board past 422 x 9.5. So if anyone can PLEASE, please give me some help/advice I would be forever greatful. :confused:
Thanks guys,
Marc
This is hindering ya OC mate,
CPU PLL Voltage: AUTO --> set 1.56
FSB Termination Voltage: --> set 1.26
NB Voltage: AUTO --> set 1.26
Too much voltage isn't always better... and AUTO overvolts BIG TIME !!
And why don't you run 445 with 1066Mhz on the ram (more bandwith , lower PL etc...)
Thanks so much, I will try those settings tonight.
As far as 445 with 1066, I might try that but I thought it was always best to run at 1:1? But actually as I said in my original post, 442 with 1066 would boot into XP but was totally unstable. So maybe you've got something there that I should try.
Oh I forgot to mention from my original post: I have listed in my bios settings the DRAM voltage as 2.1. But, in the other stable rig it's on AUTO if you can beleive that, but it's true. I set 2.1 as the last thing I tried when experimenting on the weekend. But actually when I tried to run at 442 with 1066, I started increasing DRAM voltage and the more voltage I gave it, the faster it failed Prime95, until finally at 2.1 it wouldn't boot.
Thanks for the voltage values you listed, but do you have a suggestion for the DRAM given what I just said above?
Thanks for your help,
Marc
Has nobody else got any feedback on this problem? Its the most bizzare issue I have ever come across and I am really struggling to think why it could be doing this. I am booting from a 320GB F1. With the Maxtor plugged in my PC boots every time even though its booting from the F1. I fail to see why having the Maxtor plugs in resolves my boot issue. It is so weird!!!
Thanks. I have SMART checked and error checked all my F1 drives and they are all fine. My two 1TB drive do have different firmware on them though. It is really strange. I am thinking that perhaps the maxtor that I have plugged in externally is creating some king of earth to my PC. Only way to test this though really is to rebuild my system!
There is nothing on the e-sata except for a few DVD images. I only realised that having this plugged in resolves my boot problems the other day when I had it plugged in for the first ever time!
The PC doesnt have boot problems when it is not overclocked (or even with a moderate overclock)even without the e-sata plugged in.
Like I say, it is the craziest issue ever! I think it is either an earthing problem or a disk controller issue but I really dont know.
im now at 515 x 8 with 1.28 vcore in cpu-z. i was stable for 4 hours before i had to leave so its lookin real good
i changed my gtls to .630 and the nb gtl to .650
would stabilize at 3.8ghz, any tips?
http://img3.imageshack.us/img3/8803/...avelar0.th.jpg
I want moar, getting 3.7Ghz out of my E6750 with 1.448v@ stress :s, to much on vcore imho, on my previous board (Gigabyte EX38-DS5), I did 3.64Ghz with 1.44v and 3.7ghz @1.456v @full stress, so this is like to much for just those 60mhz more ...
Although I'm running a strange kinde of memory combination, 6gb in dualchannel, does anybody know how far the corsair pc6400 sticks go?
I really want to get a very good clock on my cpu for 24/7 use, since it came out of a L722 batch, and from research I learned this is a good batch for E6750's
Atm I think cpu pll and fsb termination voltage is treating me ... thursday/friday I'll try more.
but does anybody know good settings on al those xtra ram overclock options ... ?
Thank's in advance ;)
Nice that you did find a good combo...
Just try 425FSB and up Vcore and PLL voltage to 1.56 or even 1.6... hope it will work
I don't get it, you get the same clocks (3.7Ghz) with less voltage on the P5Q Dlx then the GB and you complain ? or did I misread ya sentence there (leestekens tegoei zetten vent :p )
For the rams it would be nice to see how the rig is setup now by completing the template plz :
P5QDlx Template
I meant diffirent, on the GB lower voltage than the P5Q Deluxe :s, wich is strange, I had the same on the P5K Deluxe ..., will try tonight, now I have to study
thank's anyway for the ram information ;) :)
Hello
I just installed another P5Q Deluxe,this time with a E8500 CPU Q822A671 VID:1.10V
Without screwing around too much with Voltages i was wondering about the result.
I Made also Test 30Loop IBT and 8 Hours Orthos.
If you watch the Voltages settings, my opinion is that they are very good for this clock.
Mainboard P5Q Deluxe Bios1702,Ram Crucial Ballistix Red,Air Cooling ZEN Nanoxia Edition.
Work In Progress !
Rock Solid for DU :eek:
1.24V @4300Mhz Bus 453Mhz Ram @543Mhz
http://img518.imageshack.us/img518/5325/4300vo3.th.jpg
AI Overclock tuner: Manual
FSB Frequency: 453
DRAM Frequency: 543
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: Manual
Common Performance Level [8]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.24V
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.20
DRAM Voltage: 2.10
NB Voltage: 1.22
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: Enabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
CPU Margin Enhancement: Performance Level
I'm ready to go stresstest 3720Mhz on my E6750@1.46v idle and 1.47v stressed, it looks like I setted the GTL references wrong, setted them to auto and huppa, it's going like hell, got to finetune that later ... :p:
edit: I'll keep it@3704Mhz, fast enough, 1.46 is enough to keep it running, altough I still have to do a long stresstest, prolly for tomorrow ...
and you want to stabilize xxGhz ?
Ok its been awhile since i was last posted but i dont care about cooling issues, i just want to reach 5 Ghz, my comp. should have no problem running at it i just cant find any stable settings for it to run on.
I have intel core 2 duo stock 3.33Ghz its OC to 4.4 Ghz.
ram is DDR3 1600, and my mobo is asus P5Q3 deluxe and it should be able to get higher. So please tell me wat i need to do to get it to 5Ghz.
Not all E8600's do 5Ghz Will on air or water... maybe for short benches but you really will need chilled water or phase to stabilise things for 24/7 use...
Can't you get 500FSB and 1600mhz ram speed stable ?
What would be a good target NB GTL REF Voltage, not the divider but the actual voltage for 4 2gb sticks and lets say a 475fsb. I should be getting my chip soon and was just planning things out. Thanks
well its stable at 4.4Ghz on a full load, and i no how to overclock to an extent, but there r so many more settings that r there and i pretty sure my mobo and my cpu could get to 5Ghz. My fsb is set to 440, cpu ratio is at 10x, and my cpu voltage is at 1.462v, and anything above that fsb is unstable so i was wondering wat do i need to change the other settings too.
