ASUS posted "new" bios 1102 on their web site and it seems that this is not a beta bios.
Only description is :Maximus Formula 1102 Bios Fixed it can not enter the setup of some PCI-Express SATAII RAID Card.
Just popped into Windows to run 3DMark and get some info.
CPU-Z Stuff:
http://www.darkfibrecommunications.com/photos/cpuz.jpg
http://www.darkfibrecommunications.com/photos/cpuz2.jpg
Everest:
http://www.darkfibrecommunications.c...os/Everest.jpg
And she did 14,117 3Dmarks on 3DMark 06.
I know it's a MILD overclock, I'll be getting faster RAM at some point, and more of it.
hi i changed my e8500 cpu gtl reference to 0.67x, and now it boots only max 320 fsb before this i have 9.5 x 450 @4.3 vcore 1.32 with no problems. I have tryed 3 motherboards: Maximus formula, Maximus rampage and p5w dh deluxe, same problem with each one. LCD poster says det ram, I have tryed with 3 different sets of memory. i cant understand :\
the det ram issue has to do with PL settings once you find the right setting the issue is gone.
Set dram static read control to auto
and set trans booster to auto, I bet it boots...
There is a chart to calculate the proper settings, dont have it handy atm for I'm installing a fresh OS but I'm sure someone can post it or a link to it
If you set your ram timing to 4-4-4-12 what is your bandwidth then? or can it run at 4-4-4-12?
I may try it later today RF 403!What about max PLL on these 45nm quads? Is 1.632v too high
I think I may want a new 65nm Quad though. So what is the current best batch or rev to have? Are the current stock at local stores any good compard to our old GO early rev? I can keep 'em cool, but can they take the clock mHz?
BETA hacks? Are these BIOS rewritten spacifically for the mobos we used here, or can the actual RF download be used? If so then can we use the BETA v402 of the P5E3 Premium? Will it gain access to the multi CPU GTL control? If not, is somebody working on this for our mobos?
I think PLL is 1.65-1.70 max but I could be wrong you may want to google that. I had the Intel paper but I just formatted and dont have everything handy atm, my NAS is still disconnected.
I just grabbed a quad batch# L737B021 with a VID of 1.22 and I'm very pleased it will hit 4.0 with little effort altho I run it at 3.825 for 24/7
I bought it from Zen and he bought it from ebay ( correct me if I'm wrong Zen ) Ebay would probably give you a better choice of Q6600's.
Then you might get 1200mhz...
I would have thought that 2v on the memory would be hard on it, no?
Pretty safe so far, tested for over 3 yrs regular used PC's. Even some of the cheaper of budget can do 2.0v 24/7 on air. Better DDR2 can do 2.4v comfortably 24/7 w/ GOOD air and fan if you got it. Relaxing that trfc seamed to allow mine to use less at higher MHz. I can do 1164 at trfc50 2 2.24v.
Well, have it running at 1066Mhz now, the next one up was a bizarre 1112Mhz, then 2xFSB after that which is 1333, and I doubt the RAM can do that.
No errors in Memtest, and my 3DMark score went from 14,117 to 14,260 with no other changes.
Everest:
Before:
After:
http://www.darkfibrecommunications.c...s/everest2.jpg
hey guys I'm having trouble running 450 FSB on my maximus formula, I've tried every voltage option available :(
that is with using a 6.5 multi and running the ram at 900MHz
I've tried using the Rampage 0308 BIOS and the Maximus 1201 BIOS
I'm running a Xeon X3360 (Q9550)
the system posts but I either freeze during the windows (xp) load screen or get a blue screen during it
any ideas?
Finally 10 hrs. Prime small FFT's stable @ 3.6GHz on air!!! Temps never went over 62c on cores, or 41c on N/B. Heres my settings, thanks for all the info I got from Xtremeforums and the people who helped with answers to my questions.
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting :9
FSB Frequency :400
FSB Strap to North Bridge :400 MHz
PCI-E Frequency:100
DRAM Frequency: DDR2-1066 MHz
DRAM Command Rate :2T
DRAM Timing Control: Manual
CAS# Latency :5
RAS# to CAS# Delay :5
RAS# Precharge :5
RAS# ActivateTime :12
RAS# to RAS# Delay :4
Row Refresh Cycle Time :55
Write Recovery Time :5
Read to Precharge Time :Auto
Read to Write Delay (S/D) :9
Write to Read Delay (S) :5
Write to Read Delay (D) :5
Read to Read Delay (S) :4
Read to Read Delay (D) :6
Write to Write Delay (S) :4
Write to Write Delay (D) :6
Dram Static Read Control:Disabled
Ai Clock Twister :Auto
Transaction Booster :Disabled
Relax Level:1
CPU Voltage :1.36875
CPU PLL Voltage :1.52
North Bridge Voltage :1.39
DRAM Voltage :1.90
FSB Termination Voltage :1.34
South Bridge Voltage :1.05
Loadline Calibration :Auto
CPU GTL Reference :.063x
North Bridge GTL Reference :.067x
DDR2 Channel A REF Voltage :DDR2-Ref
DDR2 Channel B REF Voltage :DDR2-Ref
DDR2 Controller REF Voltage :Auto
SB 1.5V Voltage : Auto
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :Enabled
CPU Spread Spectrum : Auto
PCIE Spread Spectrum : Auto
Advanced CPU Configuration
- Ratio CMOS Setting :9.0
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Enabled
Execute Disable Bit : Enabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
http://img254.imageshack.us/img254/4...ablejk6.th.jpg
Priming the Q9450? If prime or the PC just freezes, no shut down crash but locks up where I have to or get to reset, what is that usually the 1st signs of? I usually used to just get crach/restart or no crash or 1 or more cores error out but 1 or 2 keep going. Bumping the FSBT up a hair kept all cores good but PC fose after 10 minutes. Prime 95 v25.5 blend mores, full CPU stress is OK.
Testing 433x8 in 5:6 aI light, boost off=0 (reported PL8), vvore: 1.32v (again, not sure idf it's too high but temps are good), FSBT: 1.456v, PLL: 1.632v, CPU GTL Ref: Auto for now cause I havent found the butter zone yet.
@Ric2L
What is the CPU PPL voltage set to [as it's on auto according to your explanation]
Also - you've got a very good CPU then - mine needs around 1.47v for 3.6ghz
Hey scottath , my q6600 can prime at 3600 with 1.3925 in bios / 1.37 actual , but its still not a 4.1+ cpu .
:shrug:
Isn't your a crap clocker? - you seem to say that everywhere on OCAU, can you post all of your settings? [or pm me on OCAU]
I managed a boot at 4.1ghz, but highest i've been able to run 3dmark was at 3.96 - got good video card scores, but horrid [considering clocks] for the CPU
Will do , and no this is another cpu , this one is only moderately crap ...
:up:
