For those who have had an X38 formula and damaged it removing the heatsinks read on there might be something a bit special on the horizon ;)
http://www.anandtech.com/mb/showdoc.aspx?i=3208&p=1
I fell another mega thread starting already. Dang ASUS!!!LOL!!!
What sucks on these board is that Asus uses a thickass thermal conducting tape, and paste under both NB and SB Fusion block and cooler, to top it off the SB cooling is linked from under the NB fusion block, so the NB gets a lot of thermal cooling resistance. I took my imitation copper of and used Koolance blocks with a microthin layer of themal paste, just enough to fill in any micro inperfectiond, and I got down to 26°c. Check my pic.
Thx for the input guys! So far I guess the recomendations are G-Skill and Ballistix!
Ballistix 8500 would be me choice, cheap and good ram.
can anyone get this 4:5 divider working I wanna go 400FSB with 1000mhz on the ram, doesn't post, do I really need to relax transaction booster and co to get it booting ?
475FSB~570 DRAM = 5:6 Divider or 333 FSB Strap
475FSB~633 DRAM = 3:4 Divider or 400 FSB Strap
333Straps 1:1, 5:6 and 5:8
400Straps 1:1 and 3:4
DETDRAM to include:
-Vdimm defaults to 1.9v - Too Low for highend RAM
-Try DRAM Static Control: Disabled
-Try Always set to 2T
-Try Manually set CPU Ratio in Advanced CPU where CPU related functions like Excecute Disable Bit are located.
-Try NB and VDIMM slight increase, 1066 is still taxing the NB.
Hello guys , my system were running stock fine , then I did some overclocking , it does not boot up , I hit the clear cmos button on back several time and still don't boot ,
LCD poster stuck at DET DRAM , someone help please ??
@icecpu,
Power dowm by turning off your poewr supply, unplug it for a few seconds, hit your Clear Cmos botton then plug your power back and power up your system.
When your in your bios all your settings should be default again.
9/10 times it's transaction booster
400 strap set to enabled relax level 0
333 strap set to disable relax level 0
You may need to set Dram Static to Auto
If you get the DET RAM hang its usally just a matter of finding the right Trans Booster setting
No need to clear cmos and certainly no need to power down and wait the bios is just fussy kinda like a woman :rofl:
I just put in different ram and it boot up and now testing 4Ghz (450X9) Prime stable for 1 HR so far , by the way Vcore for E8400 is set 1.39 in bios
True I second that :up:
Wrong thread, but I've added it to the start of mine.
Yea ofc your thread I ment ;)
Found my E8400 24/7 settings
http://i237.photobucket.com/albums/f...er/4300MHz.jpg
http://i237.photobucket.com/albums/f...147ram4300.png
http://i237.photobucket.com/albums/f...15h59-CPU1.png
just short of 3 hours now for Prime95 blend test and still running :up:
Let's see some benches :)
Max fsb for now.
Not stable.
Still testing and waiting for a god damn bios.
http://www.imageshack.gr/files/ebz1zx82emj3flmkpfu5.jpg
