Originally Posted by
J0kke
I think this is my last post to this thread. I'm losing my nerves and thinking to throw entire rig out of the window. Did a fresh install on 64bit Vista Ultimate and still I am unstable with 1:1 divider. With 2:3 divider my memory can run memtest as long as I can wait. With 500fsb and 1:1 divider only couple % and I see errors. Here is my bios template. I'd be forever thankful if someone could find a solution for my problem.
Genie BIOS Setting:
Exit Setup shutdown....................... - Mode 2
CLOCK VCO divider......................... - Auto
CPU Clock Ratio........................... - 8 X
CPU-N2 Ratio.............................. - Disabled
- Target CPU Clock........................ - 4000 MHz
CPU Clock................................. - 500 MHz
Boot Up Clock............................. - Auto
DRAM Speed................................ - 333/667
- Target DRAM Speed....................... - DDR2 1001
PCIE Clock................................ - 100 MHz
PCIE Slot Config.......................... - 1X 1X
CPU Spread Spectrum....................... - Disabled
PCIE Spread Spectrum...................... - Disabled
SATA Spread Spectrum...................... - Disabled
CPU Feature:
Thermal Management Control................ - Enabled
PPM(EIST) Mode............................ - Enabled
Limit CPUID MaxVal........................ - Disabled
C1E Function.............................. - Auto
Execute Disable Bit....................... - Enabled
Virtualization Technology................. - Enabled
Core Multi-Processing..................... - Enabled
Voltage Setting:
CPU VID Control........................... - Auto
CPU VID Special Add....................... - 112.51%
DRAM Voltage Control...................... - 2.1V
SB 1.05V Voltage.......................... - 1.15V
SB Core/CPU PLL Voltage................... - 1.55V
NB Core Voltage........................... - 1.53V
CPU VTT Voltage........................... - 1.150V
Vcore Droop Control....................... - Enabled
Clockgen Voltage Control.................. - 3.60V
GTL+ Buffers Strenght..................... - Strong
Host Slew Rate............................ - Weak
GTL REF Voltage Control................... - Enabled
CPU GTL 1/3 REF Volt..................... - 68
CPU GTL 0/2 REF Volt..................... - 67
North Bridge GTL REF Volt................. - 67
DRAM Timing:
Enhance Data transmitting................. - Auto
Enhance Addressing........................ - Auto
T2 Dispatch............................... - Auto
CAS Latency Time (tCL).................... - Auto
RAS# to CAS# Delay (tRCD)................. - Auto
RAS# Precharge (tRP)...................... - Auto
Precharge delay (tRAS).................... - Auto
All Precharge to ACT...................... - Auto
REF to ACT Delay (tRFC)................... - Auto
Preformance LVL (Read delay).............. - 10
MCH ODT Latencey.......................... - Auto
Write to PRE Delay (tWR).................. - Auto
Rank Write to Read (tWTR)................. - Auto
ACT to ACT Delay (tRRD)................... - Auto
Read to Write Delay (tRDWR)............... - Auto
Ranks Write to Write (tWRWR).............. - AUTO
Ranks Read to Read (tRDRD)................ - AUTO
Ranks Write to Read (tWRRD)............... - AUTO
Read CAS# Precharge (tRTP)................ - Auto
All PRE to Refresh........................ - Auto
Clock Setting Fine Delay:
Ch1 Clock Crossing Setting................ - Auto
DIMM 1 Clock fine delay................... - Current[89]
DIMM 2 Clock fine delay................... - Current[489]
Ch1 Command fine delay.................... - Current[801]
Ch1 Control fine delay.................... - Current[545]
Ch2 Clock Crossing Setting................ - Auto
DIMM 3 Clock fine delay................... - Current[89]
DIMM 4 Clock fine delay................... - Current[545]
Ch2 Command fine delay.................... - Current[801]
Ch2 Control fine delay.................... - Current[489]
Ch1Ch2 CommonClock Setting................ - Auto
Ch1 RDCAS GNT-Chip Delay.................. - Auto
Ch1 WRCAS GNT-Chip Delay.................. - Auto
Ch1 Command to CS Delay................... - Auto
Ch2 RDCAS GNT-Chip Delay.................. - Auto
Ch2 WRCAS GNT-Chip Delay.................. - Auto
Ch2 Command to CS Delay................... - Auto
Read delay phase adjust:
Channel 1 Phase 0 Pull-In................. - Enabled
Channel 1 Phase 1 Pull-In................. - Enabled
Channel 1 Phase 2 Pull-In................. - Enabled
Channel 1 Phase 3 Pull-In................. - Enabled
Channel 1 Phase 4 Pull-In................. - Enabled
Channel 2 Phase 0 Pull-In................. - Enabled
Channel 2 Phase 1 Pull-In................. - Enabled
Channel 2 Phase 2 Pull-In................. - Enabled
Channel 2 Phase 3 Pull-In................. - Enabled
Channel 2 Phase 4 Pull-In................. - Enabled
I have tried as high as 1.65V for NB and it only slightly makes it more stable. Im out of ideas, but as this problem has been with me quite long and I've had time to think it. Could it be the NB as the memory controller is there and it doesn't want to run my memory with 1:1 divider and with 2:3 it works great. Should I change mobo to something else because my goal was to get my E8200 @ 4ghz 24/7 and with this board I cant do it. ANY ADVICE AND HELPING WILL BE GREATLY APPRECIATED! I HAVE FAITH IN YOU PROS!!!!
