Ha! thanks for the motivation!Quote:
Originally Posted by itznfb
So will better cooling help it out? It does quite well on air and mild volt @2.85
yea, im thinking that 3GHz is possible with my cpu because i can bench and browse, but prime fails in 1 second. gotta find a way to fix that, lol.
you may need to use some h2o. i would guess that if you can drop your current load temps to mid 40's, you might be able to reach 3ghz. although, your chip may just hit a wall before that. it would be tough to get your temps that low though. i definatly think you need to lower those temps quite a bit though.Quote:
Originally Posted by Mastactor
yea, my chip does that at 2700mhz. i can play games for hours, run super pi all day long, but as soon as i run prime it fails immediatlyQuote:
Originally Posted by blazin-asian
where are the dual core gurus to help us with this problem? lol.
i don't know man, i figure that if prime fails immediatly, i probably shouldn't be able to play UT2004 for 2 hours after taht.Quote:
Yes, I am working on getting a water cooling system together. I must say I was quite surprised when it was running prime all night, and the temp was 58°c by morning.Quote:
Oh I was wondering, is it normal to set the volts in bios at 1.45 and have it read 1.5 in windows?
i dont think its normal because usually, windows will under report your voltages not the other way around. check if you have any auto vid special or sumthing enabled. i think thats what its called.Quote:
yea, its funny because i can boot and bench @ 1.525v and 1.55v but fails prime after 1 second on both cores. currently burning in for 2.85 @ 1.475v. slowly working my way up :)Quote:
Could be the high temps that dual priming brings.. gaming isn't necessarily tough on the CPU, like primeQuote:
I could play CS:S for a half hour when prime failed in a minute. It's all a matter of what you want to do with it.. though most likely bumping down 9-18MHz would make it quite a bit better
wouldn't gaming stress the memory controller? therefore causing a similar failure? especially with this CCBWE 0604.
Your memory controller funk on that one?Quote:
I was thinking mine is on CCBWE 0546. I can't get my ram to run at its max, if the cpu is clocked to its max. Even with a divider!
What do you mean?
Yeah it would stress the mem controller, that's not necessarily the part that's causing the failure in prime
(to itznfb)
well the small fft in prime stresses the cpu
large fft stresses more memory
blend stresses both pretty good. So if it fails blend and large, but not small fft, then it has more to do with your ram or memory controller.
i figure the main failure point on these chips would be the odmc. therefore, it would fail in games just as quick as prime. i may be wrong, i am admittedly an AMD nube.
Additional Comment:
plus it seems the majority of CCBWE have weak odmc
With some good h2o on a naked die you should be able to load in the high 30s, given a 20-22c ambient.Quote:
nah, that's not the case.. prime is way more stressful than games, 100% usage/load all the time. If you look at task manager graph for a games it ranges from 50-100%, on only one coreQuote:
Uh, just thought I'd post some useful info for anyone looking for a good Optys...if you type in opteron 165 in ebay search, you will see in the first 10 sellers(or around that figure) a 165 for sell for $303. It's a CCBBE 0610DPMW...good stepping, best price you'll find out there.
All the other sellers are trying to get between $380-$500 for this processor. I would hurry up and swoop them up before I get my hands on all of them.
Opteron 165 CCBBE 0610DPMW (Used to be Repoman's) WaterCooled with IHS On:
http://img.photobucket.com/albums/v6...2808SP2004.jpg
0610DPMW i assume?
Yeah, sorry :slap: It's Repoman's old CPU.Quote:
Originally Posted by CompGeek
Im hoping to pass 3.1ghz when I finally get a DFI :wasntme:
Y does everybody with a DFI have exceptionally low temps? No way the cpu is only 34c, especially with the opties even on water.
it can be as much as 8C under read.
I'm not sure. I just took out my 144 and put in my 165 and temps dropped 6-7C even though I just added another core :confused: It could be better contact with block or the fact that it's only getting <1.4V Either way, I doubt that the 34C is accurate, prolly about 5C higher.Quote:
Originally Posted by situman
The eXpert board seems to be the worst with under reporting cpu temp.
