How is this possible?? lol My sticks start with 0605 .. You ppl who are getting good results what does your says? And the ppl who are getting bad results?? Does this have to do anything with these numbers? Or BIOS maybe ? Help anyone...
there is nothing to do with SN i think
it is all luck!!!!
What do you think about this?????
http://img95.imageshack.us/img95/858/265pr7.th.jpg
3-3-2-5, 265 1:1 :woot:
http://img.photobucket.com/albums/v3...admz/a64-0.jpg
Well can someone help me or no?
hi
i have the G.SKILL F1-4000USU2-2GBHZ kit
my board is the ASrock 939DUAL SATA II with BIOS 2.20ADV
my max stable memory clock is 250MHz 3-4-4-5 @1T with 2,6V (normal)
is that the maximum for this modules?
with 2T oder other timings i have lots of errors in memtest 86+ V3.2
can anyone help me please ?
Funny when S.hit started to hit the fan on this set of ram G.S Technician was nowhere to be found. My set has problems even doing 255 on any possible setting whatsoever. orderd some mushkin redline hope they get here soon.so i can get rid of this crap
the setting for any mobo other than DFi i really can't help for timing recommend. if you can't run with with rated speed it is welcome to do the rma!
overclock is not guarantee! if all stick can do 275 why don't we just sell for 275......
I have 2GBHX running on my ASRock SLI32-eSata2 @ 250Mhz. 1T 3-3-3-7 without any problems.
3-3-2-5 1T is also possible but it gives me no more memory bandwith in the SiSoftSandra test.
I love those sticks,.. much much better then my PC4400LE I use to have.
Hi there!
i've got a Dfi ultra-d with bios 623-3 (tccd) but yesterday i bought 2gb of HZ setting the timngs posted in the 1st page of this thread by G.s Technician
I can't get stability at 270Mhz in sinc but I'm Rs in asinc (divider 9/10)
htt=3x
fsb=285
Cpu multiplier= 10x
vdimm= 2,7v
What is the best bios for my dfi ultra-d with UCCC??
Hi Triccio. I was using the 704-2BT A bios when I was using that motherboard and it ran quite well with all three different processors, the 3000+, FX-55 and FX-60. I was never quite able to hit incredibly high numbers with this ram, I don't know if it was the motherboard or the memory. But none of the three processors would get much above 275. If you seacrh the thread you cab see how I had it set up, maybe it will help.
Where did you pick up the memory, I did not know it still existed. I would like to pick up a couple of sticks myself for another box I have laying around.
try lowering the vdimm to 2.5v it work for me when i lower the voltage...
