Look this:Quote:
Originally Posted by i found nemo
http://forums.mushkin.com/phpbb2/viewtopic.php?t=2057
Maybe the HP3200 with green PCB on ebay is. Not confirmed yet.
I would say buy the Redline.
Look this:Quote:
know a place i could buy a stick of 512 for 60 bux?
Are your XBLK timings with command rate 1T or 2T?Quote:
Originally Posted by Perc
In general, do you guys think (keeping everything else the same) that 1T give 1%, 2%, 5%, or more, improvement in sustained memory bandwidth with a X2 3800 type cores.
And lastly some say that X2 3800 Toledo OC better than Manchester. But some say, because Manchester smaller die uses less power, it should OC as well or better. Which is correct?
Big update | 29/09/2005:
Updates\Corrections:
1GB XP3200 Dual Pack 2-2-2 (2x512MB) tccd/tcc5
1GB XP4400 Dual Pack 2.5-4-4 (2x512MB) tccd
1GB REDLINE 3200/3500/4000 (2x512mb) UTT/ch
PQI TURBO DDR550 is using Hynix D5 + Brainpower 815
OCZ VX PC3500
CORSAIR ALL Rev. 1.X
1GB Sticks List coming... any help is appreciated (not just words... you know I need facts to realize a reliable list)...
Bye! :D
Iwould like to know which core to gofor also..
I was thinkinmanchester but now I dunno
I have 2X1024 pdp 1024vv 3200 that has done 254 2.5-3-2-5 and 2.5-3-2-0-7-16 :)
Waiting onmy new mobo to try them out more
Im getting the ubber Asrock and will report results as soon as i can sell the dfi nf3 and afford the components, i might throw em inthe infinity and see what theyll dowith 2.5-3-3 or 4-3
Update:
Corsair XMS-PC3200C2 Rev4.3 (2-3-3-6-1T) --chip--> Samsung TCCD & TCC5 (Rev. F) ~ Brainpower PCB
Ok! Yeah, my mistake, OCZ corrected and the others signed on my .txt :D.Quote:
Originally Posted by babyelf
Thanks man! ;)
np ;)
I have not seen the new G.Skill Extreme Series DDR 500 PC 4000 on here yet. 2 @ 1GB Samsung UCCC 3-4-8-4. I just purchased and got them on Friday.. still trying to find out which bios works best for the DFI NF4 Ultra D board. The 623-3 bios works but I cannot figure out how to get above 250 FSB on it with those timings. Now the 704-2BTA bios I can am Prime95 stable as high as 280 FSB. Timings are the same in both, 1/01 E-3-4-8-4 with everything else set at whatever the bios defaults are. On the 704 bios I cannot seem to get it to run on a divider at all.. most likely something I am doing wrong. I am not saavy messing with memory unfortunately.. way too much to try and absorb and too much going on.
OCZ DIMM 1 GB DDR-400 (OCZ4001024ELPE, Platinum EL) with infineon Ram :(
Hi guys,
Did you see that - Mushkin xp 4400 512 MB for a very reasonable price :) click
Someone familiar with the chips of that memory modules. According to mushkin they no longer use TCCD chips. I wonder if these modules are with TCC5 or....
tcc5 last I checked.Quote:
Originally Posted by Billy_BAD_Boy
Incorrect: Most are listed as TCCX, which means Samsung didn't classify them.Quote:
Originally Posted by Punisher!
Incorrect as well. Multiple ICs from different manufacturers can be under the same version # (x.y).Quote:
Originally Posted by Micutzu
NEW Corsair IC Inquiry Thread
fyi, there's no such thing as unclassified samsung ic's.Quote:
Originally Posted by Wired-HoH
even ramguy doesn't say that:
TCCX = Is a down binned TCCD IC weather from Samsung or by us, so it can be a TCC3 or TCC4 or TCC5 or a TCCD marked on the IC, but it really does not matter what IC we use as long as the modules meet their tested spec.
Bah, was thinking Corsair, typed Samsung :0
In don't mind if Corsair didn't classify them. Their performance are assimilable to Samsung TCCD & TCC5, so it doesn't matter if it is written TCCX.Quote:
Ultra XL PC3200 Samsung TCCD 510 BP6U815
http://www.tigerdirect.com/applicati...071046&CatId=0
The other dude with samsung tccd sticky must be sleeping :D He hasn't add this one yet. So I'll post it here for you Punisher. :toast:
They are moderate overclockers...
Common guys....no one tried this extremely cheap memory (only $58 for a 512 MB stick). Keep in mind that the dual pack cost about $170.....what is indeed the difference?Quote:
Anyone know something about this
2x512 Corsair XMS3200C2PRO v4.3
XMS3202 V4.3
0518032-3
chipset... max fsb, timings etc.
thanks
ramguy at corsair support forums has reported c2 v4.3 multiple times as either samsung tccd/5 or promos.
you may post details there and wait for ramguys reply.
alternatively, you could try and see if your ram can do 2-2-2@200 using low vdimm. if it does, its should be samsung.
yes it does with 2.8
now i have 240 @ 2.5-3-3-8 can i lower timings anymore? cause i tried and it freezes.
is system faster with FSB default 200 (CPU @2Ghz)with 2-2-2-2-5 or FSB240 (CPU @2.4Ghz) with 2.5.-3-3-8
that looks like samsung tccd/5. those are typical timings for most tccd/5 @240. however, i believe you should be able to push your ram further, upto 260-270, maybe even more.
as for 200vs240, real time performance differences should be minimal, with slight advantage for higher frequency.
They are on the list... Pro means just "with LED" :D.Quote:
Originally Posted by Sparxxxy
ok, thanks...
