Originally posted by Lifeless
So the quality of a Creative Soundblaster Live! player 5.1 would be beter than the onboard sound? or is it another one you mean by audigy 1, because i cant find the "1".
grtz,
Frederick
The sound quality on my Live! was never that good. CPU utilization will be lower with the Live! installed, but I don't know about sound quality. I think sound quality takes precedence over performance. If you buy the DFI, try out both in gaming situations and music playing and see which one you like better. If both sound the same, use the Live. If you have a 6.1 or 7.1 speaker setup, the onboard sound would be a better option by default.
Originally posted by ugp
Ok, ok, I am going to continue to use my Audigy...my next thing I am getting is a god damn Liquid Cooling system....anyone know one...I posted a thread in the "Liquid Cooling" section. Please reply and help me out I am sick of heat.
The best kits are the ones you put together yourself. I bought a good pump, a top-of-the-line block, an awesome dual-fan radiator and made my own reservoir. I've experienced some pitfalls along the way (leaking), but I knew about that possibility going in. Goop and silicone sealant are your friend. Use lots of it :)
